[通用8051核FLASH系列]
【芯圣电子HC89S105A测评报告】+HT1621
474|0
今天搞了一下HT1621段式液晶
DA接P3.6,WR接P3.4,CS接P3.2
代码:
#define ALLOCATE_EXTERN
#include "HC89S105AC8.h"
#define uchar unsigned char
#define uint unsigned int
/** @addtogroup 425_GPIO_led_toggle GPIO_led_toggle
#define DA_1 P3_6=1
#define DA_0 P3_6=0
#define WR_1 P3_4=1
#define WR_0 P3_4=0
#define CS_1 P3_2=1
#define CS_0 P3_2=0
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
unsigned int i;
void COMMAND_HT1621(unsigned char comm)
    //unsigned char i;
    CS_0;
    WR_0;
    for(i=0;i<3;i++)        //写命令
        if((0x04<<i)&0x04)  DA_1;    //100
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<9;i++)        //写命令数据
        if((comm<<i)&0x80)  DA_1;    //100
        else                DA_0;
        WR_0;
        WR_1;
    CS_1;
void HT1621_Display(void)
    //unsigned char i;
    CS_0;                        //片选CS
    WR_0;
        if((0x05<<i)&0x04)  DA_1;
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<6;i++)                   //写地址
        if((20<<i)&0x20)    DA_1;  //20对应 SEG地址
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<8;i++)                   //写数据
        if((DpyNum[5]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[4]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[3]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[2]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[1]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[0]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
    CS_1;                          //释放CS
void LCD_Init(void)
    COMMAND_HT1621(0x01);         //SYS EN
    COMMAND_HT1621(0x03);         //LCD ON
    COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
    HT1621_Display();             //clear screen
  * @实现效果        设置各个IO口的工作状态
void main(void)
/********************************系统初始化*******************************************/
        WDTCCR = 0x00;                           //关闭看门狗
                                                           //本例程为方便测试关闭看门狗,实际使用中,建议客户打开看门狗,详见WDT复位例程
        CLKCON = 0x02;                           //选择内部高频RC为系统时钟, Fosc=32MHz
        CLKDIV = 0x02;                           //Fosc 2分频得到Fcpu,Fcpu=16MHz
/***********************************设置IO口模式***************************************/
        P3M1 = 0xF8;                                 //P32设置为带上拉开漏输出
        P3M2 = 0xF8;                             //P34设置为推挽输出
        P3M3 = 0xF8;                             //P34设置为推挽输出
        LCD_Init();
    DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
    DpyNum[1] = SegCode[2];
    DpyNum[2] = SegCode[4];
    DpyNum[3] = SegCode[6];
    DpyNum[4] = SegCode[8];
    DpyNum[5] = SegCode[0];
    HT1621_Display();
        while(1)
效果图:
