[DemoCode下载]
从机模拟AT24C02
1218|5
febgxu|  楼主 | 2023-5-27 08:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#define EEPROM_SLA              0xA0   //AT24C02
UINT8 data_received[64]= 0;    //change to 256 if the rom space is enough
UINT8 data_num = 0;
UINT8 irxdata =0;
UINT8 isubaddr =0;
void I2C_ISR(void) interrupt 6
    static UINT8 islavecount=0;
    switch (I2STAT)
        case 0x00:
            STO = 1;
            break;
        case 0x60:
            AA = 1;
            islavecount=0;
            break;
        case 0x68:
                                P02 = 0;
            while(1);
            break;
        case 0x80:
            if(islavecount==0)
               isubaddr = I2DAT;
               AA = 1;
               islavecount++;
               data_num = isubaddr;
            else
               irxdata = I2DAT;
               AA = 1;
               data_received[data_num++]=irxdata;
               islavecount++;
            break;
        case 0x88:
            data_received[data_num] = I2DAT;
            data_num = 0;
            AA = 1;
            break;
        case 0xA0:
            AA = 1;
            break;
        case 0xA8:
            data_num=isubaddr;
            I2DAT = data_received[data_num];
            data_num++;
            AA = 1;
            break;
        case 0xB8:
            data_num++;
            AA = 1;
            break;
        case 0xC0:
            AA = 1;
            break;
        case 0xC8:
            AA = 1;
            break;
    SI = 0;
void Init_I2C_SLAVE(void)
    P13_Quasi_Mode;                         //set SCL (P13) is Quasi mode
    P14_Quasi_Mode;                         //set SDA (P14) is Quasi mode
    SDA = 1;                                //set SDA and SCL pins high
    SCL = 1;
    //--set_P0SR_6;                             //set SCL (P06) is  Schmitt triggered input select.
    set_EI2C;                               //enable I2C interrupt by setting IE1 bit 0
    set_EA;
    I2ADDR = EEPROM_SLA;                    //define own slave address
    set_I2CEN;                              //enable I2C circuit
    set_AA;
void main(void)
   Set_All_GPIO_Quasi_Mode;
   Init_I2C_SLAVE();
   while (1);
pmp| | 2023-6-6 13:53 | 只看该作者
使用I2C总线使用AT24C02?
tifmill| | 2023-6-6 14:20 | 只看该作者
单片机可以同时使用一个AT24C02芯片吗
kkzz| | 2023-6-6 14:36 | 只看该作者
如何修改 at24c02数据
maqianqu| | 2023-6-6 17:09 | 只看该作者
有多少个字节可以用来存数据?
Bowclad| | 2023-6-8 18:10 | 只看该作者
kkzz 发表于 2023-6-6 14:36
如何修改 at24c02数据
用iic通信
