[技术讨论]
单片机红外传感器模块
133|0
Chenxinyes|  楼主 | 2023-7-2 12:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "zf_common_headfile.h"
#include "hal_device_registers.h"
#include "zf_driver_timer.h"
#include "isr.h"
#include "zf_driver_adc.h"
#include "zf_driver_gpio.h"
#include "hal_tim.h"
//#define IR_SENSOR_PIN GPIO_Pin_4 // 替换为实际连接到红外传感器的引脚
//#define BUZZER_PIN GPIO_Pin_9 // 替换为实际连接到蜂鸣器的引脚
#define BEEP                (E9 )
#define sensor              (B4 )
static ADC_Type *adc_module = ADC1;
static adc_channel_enum adc_channel = ADC1_CH0_A0;
void adc_module_init()
    RCC_EnableAPB2Periphs(RCC_APB2_PERIPH_ADC1, true);
    ADC_Init_Type adc_init;
    adc_init.Resolution = ADC_8BIT;
    adc_init.ConvMode = ADC_ConvMode_SingleSlot;
    adc_init.Align = ADC_Align_Right;
    ADC_Init(adc_module, &adc_init);
    ADC_Enable(adc_module, true);
    ADC_DoAutoCalib(adc_module);
uint16 adc_module_convert()
    uint32_t data = 0;
    ADC_EnableSeqSlot(adc_module, 0, 1);
    ADC_DoSwTrigger(adc_module, true);
    while ((ADC_STATUS_CONV_SLOT_DONE | ADC_STATUS_CONV_SAMPLE_DONE) !=
           (ADC_GetStatus(adc_module) & (ADC_STATUS_CONV_SLOT_DONE | ADC_STATUS_CONV_SAMPLE_DONE)));
    ADC_ClearStatus(adc_module, (ADC_STATUS_CONV_SLOT_DONE | ADC_STATUS_CONV_SAMPLE_DONE));
    data = ADC_GetSlotConvResult(adc_module, 0, NULL);
    return (data >> ADC_8BIT);
int main(void)
    clock_init(SYSTEM_CLOCK_120M);
    debug_init();
          adc_init(ADC1_CH0_A0,ADC_8BIT);
    gpio_init(B4, GPI, GPIO_LOW, GPI_FLOATING_IN);
    gpio_init(E9, GPO, GPIO_HIGH, GPO_PUSH_PULL);
    adc_module_init();
          timer_init(TIM_1, TIMER_MS);
//    uint32_t start_time = 0;
//    bool buzzer_triggered = false;
          timer_start(TIM_1);
    while (1)
        uint16_t distance = adc_module_convert();
        if (distance >= 20 && distance <= 80)
            if (gpio_get_level(BEEP)==GPIO_HIGH)
//                start_time = timer_get(TIM_1);
                gpio_set_level(BEEP, GPIO_HIGH);
            uint32_t current_time = timer_get(TIM_1);
            if ((current_time - start_time) >= 5000)
                gpio_high(BEEP);
                system_delay_ms(1000);
                gpio_low(BEEP);
//              gpio_set_level(BEEP, GPIO_LOW);
        else
#include "isr.h"
    uint32_t data = 0;
int main(void)
    debug_init();
    gpio_init(B4, GPI, 0, GPI_FLOATING_IN);
    gpio_init(E9, GPO, 0, GPO_PUSH_PULL);
    adc_module_init();
    while (1)
            uint32_t start_time = timer_get(TIM_1);
            while (distance >= 20 && distance <= 80)
                    gpio_low(E9);
                    gpio_high(E9);
                    break;
}有没有大佬能看看这段代码逻辑有没有问题啊,功能一直实现不了
