[应用方案]
NUC029xAN的ADC代码
464|6
benjaminka|  楼主 | 2023-7-14 21:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADC:
        配置ADC:
        /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
        配置ADC时一定要端口的数字输入功能禁止
    /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
    GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);        //0000 1111
    /* Configure the P1.0 - P1.3 ADC analog input pins */
    SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
GPIO  IP有个寄存器叫OFFD(OFF  Digital),关闭相应管脚的数字通路的意思。如果某个管脚配置
为模拟功能,例如:ADC、DAC、ACMP、SEG、COM、DH1、DH2、V1、V2、V3等功能,这
些管脚对应的OFFD  bit应该使能,关闭到数字区域的通路,避免内部数字器件不停的打开、关闭
而漏电
NUC029xAN  A/D转换器支持四种操作模式:  单次模式,  Burst模式,  单周期扫描模式和连续扫描模
ADC continuous scan mode sample code :
        //开启ADC
    /* Power on ADC module */
    ADC_POWER_ON(ADC);
    /* Set the ADC operation mode as continuous scan, input mode as single-end and
     enable the analog input channel 0, 1, 2 and 3 */
    ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0xF);
    /* clear the A/D interrupt flag for safe */
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
    /* start A/D conversion */
    ADC_START_CONV(ADC);
    /* Wait conversion done */
    while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
        //转换结束后的值会放在使能通道对应的A/D寄存器中。
    for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
     i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
     printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
    /* Wait conversion done */  ADC_ADF_INT: Convert complete interrupt flag
    /* Stop A/D conversion */
    ADC_STOP_CONV(ADC);
        //关闭ADC
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
tpgf| | 2024-2-4 16:48 | 只看该作者
ad转换的四种模式楼主选用的是哪种模式呢
晓伍| | 2024-2-4 17:27 | 只看该作者
关闭数字通路的功能应该在什么位置进行呢
wowu| | 2024-2-4 22:02 | 只看该作者
如何操作才可以动态的更改采样的频率呢
xiaoqizi| | 2024-2-4 22:38 | 只看该作者
相关引脚的配置代码好像没有贴上来啊
木木guainv| | 2024-2-4 23:07 | 只看该作者
如何通过软件对adc的采集数据进行滤波呢
磨砂| | 2024-2-4 23:46 | 只看该作者
关于adc的采集模式选取 有没有指导性的意见呢
