GD32F130 ADC + DMA的问题
352|5
xiong2088|  楼主 | 2023-8-7 15:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大神:
      我刚刚接触GD的MCU,在调试GD32F130C8 ADC + DMA的时候发现,DMA搬运数据内存地址没有增长,还有一个就是数据不对, 一直在0xff0~0xffc之间跳动。多方搜素都找不到答案,请各位大神解惑。
ADC只使用一路,PA0。
这是代码:
void ADC_Configuration(void)
        /* enable ADC clock */
    rcu_periph_clock_enable(RCU_ADC);
        /* config ADC clock */
    rcu_adc_clock_config(RCU_ADCCK_APB2_DIV6);
        /* ADC continuous function enable */
    adc_special_function_config(ADC_CONTINUOUS_MODE, ENABLE);
    /* ADC scan function enable */
    adc_special_function_config(ADC_SCAN_MODE, ENABLE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC_DATAALIGN_RIGHT);
    /* ADC channel length config */
    adc_channel_length_config(ADC_REGULAR_CHANNEL, 1);
    /* ADC regular channel config */
    adc_regular_channel_config(0, ADC_CHANNEL_1, ADC_SAMPLETIME_55POINT5);
    /* ADC trigger config */
    adc_external_trigger_source_config(ADC_REGULAR_CHANNEL, ADC_EXTTRIG_REGULAR_NONE);
    adc_external_trigger_config(ADC_REGULAR_CHANNEL, ENABLE);
    /* ADC DMA function enable */
    adc_dma_mode_enable();
    /* enable ADC interface */
    adc_enable();
    delay_ms(2);
    /* ADC calibration and reset calibration */
    adc_calibration_enable();
    /* ADC software trigger enable */
    adc_software_trigger_enable(ADC_REGULAR_CHANNEL);
void dma_config(void)
    /* ADC_DMA_channel configuration */
    dma_parameter_struct dma_data_parameter;
        /* enable DMA clock */
    rcu_periph_clock_enable(RCU_DMA);
    /* ADC DMA_channel configuration */
    dma_deinit(DMA_CH0);
    /* initialize DMA single data mode */
    dma_data_parameter.periph_addr  = (uint32_t)(&ADC_RDATA);
    dma_data_parameter.periph_inc   = DMA_PERIPH_INCREASE_DISABLE;
    dma_data_parameter.memory_addr  = (uint32_t)AD_Value;
    dma_data_parameter.memory_inc   = DMA_MEMORY_INCREASE_ENABLE;
    dma_data_parameter.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
    dma_data_parameter.memory_width = DMA_MEMORY_WIDTH_16BIT;
    dma_data_parameter.direction    = DMA_PERIPHERAL_TO_MEMORY;
    dma_data_parameter.number       = 1;
    dma_data_parameter.priority     = DMA_PRIORITY_HIGH;
    dma_init(DMA_CH0, &dma_data_parameter);
    dma_circulation_enable(DMA_CH0);
    /* enable DMA channel */
    dma_channel_enable(DMA_CH0);
请大神指点!
hfdy01| | 2023-10-22 10:24 | 只看该作者
这个 /* ADC DMA function enable */函数楼主检查下有没是啥问题
cr315| | 2024-1-31 10:52 | 只看该作者
内存地址问题
两只袜子| | 2024-1-31 10:52 | 只看该作者
检查ADC的配置是否正确
jcky001| | 2024-1-31 10:53 | 只看该作者
电源问题可能导致ADC和DMA的行为异常。
elephant00| | 2024-1-31 10:53 | 只看该作者
检查您的代码,确保DMA和ADC的初始化、启动和停止等操作都是正确的。
