449|8
Steven941407|  楼主 | 2023-9-19 10:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
------ Build started: Project: basic_read_fifo, Configuration: Release ARM ------
Build started.
Project "basic_read_fifo.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "F:\2-InvenSence\Motion sensor\Consumer\45系列\驱动\invn.firmware.emd-mcu.icm45686_examples-atmel.arm-gnu-toolchain-cm4-fpu-1.3.0\sources\examples\basic_read_fifo\basic_read_fifo.cproj" (target "Build" depends on it):
        Task "RunCompilerTask"
                Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
                C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 16 --output-sync
                make: *** No rule to make target '../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/source/templates/gcc/startup_samg55.c', needed by 'ASF/startup_samg55.o'.  Stop.
                make: *** Waiting for unfinished jobs....
                Building file: ../../../../sources/examples/basic_read_fifo/basic_read_fifo.c
                Invoking: ARM/GNU C Compiler : 6.3.1
                "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe"  -x c -mthumb -D__SAMG55J19__ -DINV_MSG_ENABLE -DASSERT -DNDEBUG -DINV_UART_SENSOR_CTRL_TX_BUFFER_SIZE=2048 -DINV_UART_SENSOR_CTRL_RX_BUFFER_SIZE=256 -DINV_UART_LOG_TX_BUFFER_SIZE=512 -DICM45686 -DSM_BOARD_REV=SM_REVI -DBOARD=SAMG55_XPLAINED_PRO -D__SAMG55J19__  -I"../../../../sources" -I"../../../../sources/Invn" -I"../../../../sources/Invn/EmbUtils" -I"../../../../sources/board_hal" -I"../../../../sources/board_hal/ASF/common/boards" -I"../../../../sources/board_hal/ASF/common/services/clock" -I"../../../../sources/board_hal/ASF/common/services/clock/samg" -I"../../../../sources/board_hal/ASF/common/services/ioport" -I"../../../../sources/board_hal/ASF/common/services/ioport/sam" -I"../../../../sources/board_hal/ASF/common/services/serial" -I"../../../../sources/board_hal/ASF/common/services/serial/sam_uart" -I"../../../../sources/board_hal/ASF/common/services/sleepmgr" -I"../../../../sources/board_hal/ASF/common/services/sleepmgr/sam" -I"../../../../sources/board_hal/ASF/common/services/sleepmgr/sam/module_config" -I"../../../../sources/board_hal/ASF/common/utils" -I"../../../../sources/board_hal/ASF/common/utils/interrupt" -I"../../../../sources/board_hal/ASF/common/utils/stdio" -I"../../../../sources/board_hal/ASF/common/utils/stdio/stdio_serial" -I"../../../../sources/board_hal/ASF/sam/boards" -I"../../../../sources/board_hal/ASF/sam/boards/samg55_xplained_pro" -I"../../../../sources/board_hal/ASF/sam/boards/samg55_xplained_pro/board_config" -I"../../../../sources/board_hal/ASF/sam/drivers/efc" -I"../../../../sources/board_hal/ASF/sam/drivers/flexcom" -I"../../../../sources/board_hal/ASF/sam/drivers/pdc" -I"../../../../sources/board_hal/ASF/sam/drivers/pio" -I"../../../../sources/board_hal/ASF/sam/drivers/pmc" -I"../../../../sources/board_hal/ASF/sam/drivers/rtc" -I"../../../../sources/board_hal/ASF/sam/drivers/spi" -I"../../../../sources/board_hal/ASF/sam/drivers/supc" -I"../../../../sources/board_hal/ASF/sam/drivers/tc" -I"../../../../sources/board_hal/ASF/sam/drivers/twi" -I"../../../../sources/board_hal/ASF/sam/drivers/usart" -I"../../../../sources/board_hal/ASF/sam/utils" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/include" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/include/Core" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/include/component" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/include/instance" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/include/pio" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/source/templates" -I"../../../../sources/board_hal/ASF/sam/utils/cmsis/samg/samg55/source/templates/gcc" -I"../../../../sources/board_hal/ASF/sam/utils/fpu" -I"../../../../sources/board_hal/ASF/sam/utils/header_files" -I"../../../../sources/board_hal/ASF/sam/utils/preprocessor" -I"../../../../sources/board_hal/ASF/sam/utils/syscalls/gcc" -I"../../../../sources/board_hal/ASF/services" -I"../../../../sources/drivers" -I"../../../../sources/drivers/icm45686" -I"../../../../sources/drivers/icm45686/imu" -I"../../../../sources/examples" -I"../../../../sources/examples/basic_read_fifo" -I"../../../../sources/examples/system_interface" -I"../../../board_hal/ASF/common/services/serial/sam_uart/module_config"  -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -Wextra -fsigned-char -std=c99 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wno-unused-parameter -Wl,-static,--gc-sections,-Map=output.map -D__inline=inline -Werror -MD -MP -MF "Source/basic_read_fifo.d" -MT"Source/basic_read_fifo.d" -MT"Source/basic_read_fifo.o"   -o "Source/basic_read_fifo.o" "../../../../sources/examples/basic_read_fifo/basic_read_fifo.c"
                Finished building: ../../../../sources/examples/basic_read_fifo/basic_read_fifo.c
        Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "basic_read_fifo.cproj" -- FAILED.
Done building project "basic_read_fifo.cproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
大佬们知道这是怎么回事吗
tpgf| | 2024-2-5 11:04 | 只看该作者
感觉好像缺少一些相关的引用文件
renzheshengui| | 2024-2-5 11:40 | 只看该作者
楼主好像是跑系统了?版本不匹配?
paotangsan| | 2024-2-5 20:07 | 只看该作者
好像是没有具体的错误 但是都没有编译成功
wakayi| | 2024-2-5 20:43 | 只看该作者
楼主的这个错误都没有错误码报送啊
wowu| | 2024-2-5 21:17 | 只看该作者
查看一下芯片型号  引用的头文件等等是不是对的
xiaoqizi| | 2024-2-5 21:51 | 只看该作者
好像是很多任务都没有编译成功啊
SophiaOP| | 2024-2-21 16:00 | 只看该作者
缺了个头文件吧
OliviaSH| | 2024-2-25 22:11 | 只看该作者
有未包含的头文件
