发新帖本帖赏金 20.00元(功能说明)我要提问
返回列表
[AT32F423]
【AT-START-F423测评】多通道MODBUS测试
1081|1
aple0807|  楼主 | 2023-10-29 10:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
今天测试一下基于UART的MODBUS-RTU,AT32F423多大8路UART,做工业仪表是个不错的选择。
本次测试使用两个串口:
USART2配置为从机:9600,8N2, 站号1
USART3配置为主站:9600,8N2, 配置命令访问站号1
IO配置:
// U2
{GPIOA, GPIO_MODE_MUX, GPIO_DRIVE_STRENGTH_STRONGER, GPIO_OUTPUT_PUSH_PULL, GPIO_PULL_NONE, GPIO_MUX_7, GPIO_PINS_2 | GPIO_PINS_3},
// U3
{GPIOB, GPIO_MODE_MUX, GPIO_DRIVE_STRENGTH_STRONGER, GPIO_OUTPUT_PUSH_PULL, GPIO_PULL_NONE, GPIO_MUX_7, GPIO_PINS_10 | GPIO_PINS_11},
串口初始化:
* [url=home.php?mod=space&uid=247401]@brief[/url]           com modle init .
* @param   none
* [url=home.php?mod=space&uid=266161]@return[/url]  none
* [url=home.php?mod=space&uid=72445]@[/url] Pass/ Fail criteria: none
static void qc_port_Init(uu8 qcMode, uint32_t ulBaudRate, mb_parity_type eParity)
        usart_data_bit_num_type dat_bits;
        usart_stop_bit_num_type stop_bits;
        usart_parity_selection_type parity;
        qc_port_hal_cfg();
        qc_cb_set();
        qc_obj.mode = qcMode;
        qc_obj.dat_send = qc_port_send;
        qc_byte_send = qc_rtu_byte_send;
        // rtu mode
        if (MB_PAR_NONE == eParity)
                dat_bits = USART_DATA_8BITS;
                stop_bits = USART_STOP_2_BIT;
                parity = USART_PARITY_NONE;
        else if (MB_PAR_NONE_1S == eParity)
                stop_bits = USART_STOP_1_BIT;
        else if (MB_PAR_ODD == eParity)
                dat_bits = USART_DATA_9BITS;
                parity = USART_PARITY_ODD;
        else
                parity = USART_PARITY_EVEN;
        // rtu timer
        if (ulBaudRate > 19200)
                qc_obj.tim_sv = 3;
        else
                qc_obj.tim_sv = (com_timer_cal(ulBaudRate, (35 * 11 + 9) / 10, 300, 12000) + 99) / 100;
        usart_init(qc_port, ulBaudRate, dat_bits, stop_bits);
        usart_parity_selection_config(qc_port, parity);
        usart_enable(qc_port, TRUE);
        nvic_irq_set(qc_uart_irqn, 0x00, 1);
        qc_tx1_rx0_enable(0);
        UART_TX_EN();
中断处理:
* [url=home.php?mod=space&uid=247401]@brief[/url] UART interrupt routine.
* @param   none
void qc_isr()
        volatile uint32_t IntSt;
        volatile uint8_t Data;
        IntSt = qc_port->sts;
        if (IntSt & USART_RDBF_FLAG)
                Data = UART_RCV_DAT();
                if ((IntSt & UART_RX_ERR_FLAG) != 0)
                        if (qc_obj.rx_cnt >= 1)
                                qc_obj.err_hal = 1;
                        UART_RX_ERR_CLR();
                qc_data_rcv(&qc_obj, Data);
        else if ((qc_obj.tx_size <= qc_obj.tx_cnt) && (IntSt & USART_TDC_FLAG))
                qc_send_end(&qc_obj);
                UART_TX_TC_CLR();
        else if (IntSt & USART_TDBE_FLAG)
                if (qc_data_send(&qc_obj, qc_rtu_byte_send, 1))
                        UART_TX_TC_EN();
        else
U3主站命令:
void qc_init(void)
        // master config
        qc03_Init(QC_MODE_MASTER, 9600, MB_PAR_NONE);
        mb.qc03.os_event_send = mb_os_send;
        mcmd.id = 1;
        mcmd.wdat = &mb_input[0].uval;
        mcmd.rdat = &mb_input[0].uval;
        mcmd.wa = 0;
        mcmd.wn = 96;
        mcmd.ra = 0x1800;
        mcmd.rn = 1;
        mcmd.callback = qc_callback;
        mcmd.attr = QC_MB_ATTR_HOLD_MW;
        mqc_stc_cmd_req(&mb.qc03, 0, &mcmd);
        mcmd.wa = 96;
        mcmd.wn = 96;
        mqc_stc_cmd_req(&mb.qc03, 1, &mcmd);
        // slave config
        qc02_Init(QC_MODE_SLAVE, 9600, MB_PAR_NONE);
        mb.qc02.os_event_send = mb_os_send;
        mcmd.id = 1;
        mcmd.wa = 16;
        mcmd.wn = 16;
        mcmd.ra = 0;
        mcmd.rn = 8;
        mqc_stc_cmd_req(&mb.qc02, 0, &mcmd);
        mqc_stc_cmd_req(&mb.qc02, 1, &mcmd);
测试时,将评估板PA2连接PB10, PA3连接PB11可完成两个端口通信,运行结果如下:
为方便运行时观察,可以显示串口通信信息到OLED显示屏,效果如下:
任务资源信息:
至此,modbus移植测试成功,可以用来连接各种modbus接口的传感器和PLC设备了。
下面附上测试代码:
AT32F423_EVAL.rar (4.59 MB)
编译环境:IAR EW for Arm 9.40
打赏榜单
ArterySW 打赏了 20.00 元 2024-01-24
理由:作品优秀
wangwu1976@| | 2024-1-24 13:48 | 只看该作者
做得真不错,顶一个
发新帖 本帖赏金 20.00元(功能说明)我要提问
