[DemoCode下载]
PWM触发ADC采样,通过PDMA传输采样结果
485|7
gejigeji521|  楼主 | 2023-10-30 09:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to trigger ADC by PWM and transfer conversion data by PDMA.
* SPDX-License-Identifier: Apache-2.0
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2020 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
/* Define global variables and constants        */
volatile uint32_t g_u32AdcIntFlag, g_u32COVNUMFlag = 0;
volatile uint32_t g_u32IsTestOver = 0;
int16_t  g_i32ConversionData[6] = {0};
uint32_t g_u32SampleModuleNum = 0;
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM0 module clock */
    CLK_EnableModuleClock(PWM0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* ADC clock source is PCLK1, set divider to 1 */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL2_ADCSEL_PCLK1, CLK_CLKDIV0_ADC(1));
    /* Enable PDMA clock source */
    CLK_EnableModuleClock(PDMA_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function                                              */
    /* Set PB multi-function pins for UART0 RXD=PB.6 and TXD=PB.4 */
    SYS->GPB_MFP1 = (SYS->GPB_MFP1 & ~(SYS_GPB_MFP1_PB4MFP_Msk | SYS_GPB_MFP1_PB6MFP_Msk)) |
                    (SYS_GPB_MFP1_PB4MFP_UART0_TXD | SYS_GPB_MFP1_PB6MFP_UART0_RXD);
    /* Set PA.2, PC.0 to input mode */
    GPIO_SetMode(PA, BIT2, GPIO_MODE_INPUT);
    GPIO_SetMode(PC, BIT0, GPIO_MODE_INPUT);
    /* Configure the PA.2, PC.0 ADC analog input pins.  */
    SYS->GPA_MFP0 = (SYS->GPA_MFP0 & ~(SYS_GPA_MFP0_PA2MFP_Msk)) |
                    (SYS_GPA_MFP0_PA2MFP_ADC0_CH2);
    SYS->GPC_MFP0 = (SYS->GPC_MFP0 & ~(SYS_GPC_MFP0_PC0MFP_Msk)) |
                    (SYS_GPC_MFP0_PC0MFP_ADC0_CH3);
    /* Disable the PA.2, PC.0 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PA, BIT2);
    GPIO_DISABLE_DIGITAL_PATH(PC, BIT0);
    /* Lock protected registers */
    SYS_LockReg();
void PWM0_Init()
    /* Set PWM0 timer clock prescaler */
    PWM_SET_PRESCALER(PWM0, 0, 0);
    /* Set up counter type */
    PWM0->CTL1 &= ~PWM_CTL1_CNTTYPE0_Msk;
    /* Set PWM0 timer duty */
    PWM_SET_CMR(PWM0, 0, 108);
    /* Set PWM0 timer period */
    PWM_SET_CNR(PWM0, 0, 216);
    /* PWM period point trigger ADC enable */
    PWM_EnableADCTrigger(PWM0, 0, PWM_TRIGGER_ADC_EVEN_PERIOD_POINT);
    /* Set output level at zero, compare up, period(center) and compare down of specified channel */
    PWM_SET_OUTPUT_LEVEL(PWM0, BIT0, PWM_OUTPUT_HIGH, PWM_OUTPUT_LOW, PWM_OUTPUT_NOTHING, PWM_OUTPUT_NOTHING);
    /* Enable output of PWM0 channel 0 */
    PWM_EnableOutput(PWM0, BIT0);
void PDMA_Init()
    /* Configure PDMA peripheral mode form ADC to memory */
    /* Open Channel 1 */
    PDMA_Open(PDMA, BIT1);
    /* transfer width is half word(16 bit) and transfer count is 6 */
    PDMA_SetTransferCnt(PDMA, 1, PDMA_WIDTH_16, 6);
    /* Set source address as ADC PDMA Current Transfer Data register (no increment) and destination address as g_i32ConversionData array (increment) */
    PDMA_SetTransferAddr(PDMA, 1, (uint32_t)&ADC->ADPDMA, PDMA_SAR_FIX, (uint32_t)g_i32ConversionData, PDMA_DAR_INC);
    /* Select PDMA request source as ADC RX */
    PDMA_SetTransferMode(PDMA, 1, PDMA_ADC_RX, FALSE, 0);
    /* Set PDMA as single request type for ADC */
    PDMA_SetBurstType(PDMA, 1, PDMA_REQ_SINGLE, PDMA_BURST_4);
    PDMA_EnableInt(PDMA, 1, PDMA_INT_TRANS_DONE);
    NVIC_EnableIRQ(PDMA_IRQn);
void ReloadPDMA()
void ADC_FunctionTest()
    uint8_t  u8Option;
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|   PWM trigger mode and transfer ADC conversion data by PDMA test     |\n");
    printf("\nIn this test, software will get 6 conversion result from the specified channel.\n");
    /* Enable ADC converter */
    ADC_POWER_ON(ADC);
    while(1)
        /* reload PDMA configuration for next transmission */
        ReloadPDMA();
        printf("Select input mode:\n");
        printf("  [1] Single end input (channel 2 only)\n");
        printf("  [2] Differential input (channel pair 1 only (channel 2 and 3))\n");
        printf("  Other keys: exit single mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set input mode as single-end, Single mode, and select channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE, BIT2);
            /* Configure the sample module and enable PWM0 trigger source */
            ADC_EnableHWTrigger(ADC, ADC_ADCR_TRGS_PWM, 0);
            /* ADC enable PDMA transfer */
            ADC_ENABLE_PDMA(ADC);
            printf("Conversion result of channel 2:\n");
            /* Enable PWM0 channel 0 counter */
            PWM_Start(PWM0, PWM_CH_0_MASK);
            while(1)
                /* Wait PDMA interrupt (g_u32IsTestOver will be set at IRQ_Handler function) */
                while(g_u32IsTestOver == 0);
                break;
            /* Disable PWM0 channel 0 counter */
            PWM_ForceStop(PWM0, BIT0);  /* PWM0 counter stop running. */
            for(g_u32COVNUMFlag = 0; (g_u32COVNUMFlag) < 6; g_u32COVNUMFlag++)
                printf("                                0x%X (%d)\n", g_i32ConversionData[g_u32COVNUMFlag], g_i32ConversionData[g_u32COVNUMFlag]);
        else if(u8Option == '2')
            /* Set input mode as differential, Single mode, and select channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, BIT2);
            while(1)
                break;
            /* Disable EPWM0 channel 0 counter */
        else
            return;
void PDMA_IRQHandler(void)
    uint32_t status = PDMA_GET_INT_STATUS(PDMA);
    if(status & PDMA_INTSTS_ABTIF_Msk)    /* abort */
        if(PDMA_GET_ABORT_STS(PDMA) & PDMA_ABTSTS_ABTIF1_Msk)
            g_u32IsTestOver = 2;
        PDMA_CLR_ABORT_FLAG(PDMA, PDMA_ABTSTS_ABTIF1_Msk);
    else if(status & PDMA_INTSTS_TDIF_Msk)      /* done */
        if(PDMA_GET_TD_STS(PDMA) & PDMA_TDSTS_TDIF1_Msk)
            g_u32IsTestOver = 1;
        PDMA_CLR_TD_FLAG(PDMA, PDMA_TDSTS_TDIF1_Msk);
    else
        printf("unknown PDMA interrupt !!\n");
/* Init UART0                                                           */
void UART0_Init(void)
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
int32_t main(void)
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init PWM for ADC */
    PWM0_Init();
    /* Init PDMA for ADC */
    PDMA_Init();
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* ADC function test */
    ADC_FunctionTest();
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable PWM0 IP clock */
    CLK_DisableModuleClock(PWM0_MODULE);
    /* Disable PDMA clock source */
    CLK_DisableModuleClock(PDMA_MODULE);
    /* Disable PDMA Interrupt */
    NVIC_DisableIRQ(PDMA_IRQn);
    printf("Exit ADC sample code\n");
    while(1);
tpgf| | 2024-1-5 12:08 | 只看该作者
通过pwm的哪个参数来触发adc的采集呢
aoyi| | 2024-1-5 13:10 | 只看该作者
可以通过不同的pwm触发不同采样频率的adc吗
tfqi| | 2024-1-5 21:29 | 只看该作者
可以使用一路pwm同时触发多路adc吗
gwsan| | 2024-1-5 22:00 | 只看该作者
这个是以哪个功能作为主要功能呢
zljiu| | 2024-1-5 22:31 | 只看该作者
pwm波形是自身产生的波形吗
nawu| | 2024-1-5 23:12 | 只看该作者
这两个的节奏如何能配合好呢
AloneKaven| | 2024-1-10 09:00 | 只看该作者
应该可以用不同的pwm触发
