21ic电子技术开发论坛 单片机与嵌入式系统 ST MCU 【NUCLEO-U5A5ZJ-Q测评】-2-Keil开发环境搭建
发新帖我要提问
返回列表
[STM32U5]
741|3
YangTwo|  楼主 | 2023-11-11 13:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在Keil官网下载固件包:
双击安装:
安装完成后新建工程,可以选择芯片:STM32U5A5ZJT6Q
先运行一个最简单的GPIO翻转,初始化GPIO
  GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull  = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  GPIO_InitStruct.Pin = LED1_PIN;
  HAL_GPIO_Init(LED1_GPIO_PORT, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = LED2_PIN;
  HAL_GPIO_Init(LED2_GPIO_PORT, &GPIO_InitStruct);
延迟一定时间后,翻转LED状态
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
    HAL_GPIO_TogglePin(LED1_GPIO_PORT, LED1_PIN);
    /* Insert delay 1000 ms */
    HAL_Delay(1000);
    HAL_GPIO_TogglePin(LED2_GPIO_PORT, LED2_PIN);
    HAL_Delay(1000);
编译:
Rebuild started: Project: GPIO_IOToggle
*** Using Compiler 'V6.16', folder: 'D:\ProgramFiles\Keil_v5\ARM\ARMCLANG\Bin'
Rebuild target 'GPIO_IOToggle'
assembling startup_stm32u5a5xx.s...
compiling main.c...
compiling stm32u5xx_hal_exti.c...
compiling stm32u5xx_hal_cortex.c...
compiling stm32u5xx_hal.c...
compiling stm32u5xx_hal_msp.c...
compiling stm32u5xx_hal_dma.c...
compiling stm32u5xx_hal_gtzc.c...
compiling stm32u5xx_hal_icache.c...
compiling stm32u5xx_hal_pwr_ex.c...
compiling stm32u5xx_hal_i2c.c...
compiling stm32u5xx_hal_tim.c...
compiling stm32u5xx_it.c...
compiling stm32u5xx_hal_pwr.c...
compiling stm32u5xx_hal_i2c_ex.c...
compiling stm32u5xx_hal_flash_ex.c...
compiling stm32u5xx_nucleo.c...
compiling stm32u5xx_hal_gpio.c...
compiling stm32u5xx_hal_tim_ex.c...
compiling stm32u5xx_hal_dma_ex.c...
compiling stm32u5xx_hal_flash.c...
compiling system_stm32u5xx.c...
compiling stm32u5xx_hal_rcc.c...
compiling stm32u5xx_hal_rcc_ex.c...
linking...
Program Size: Code=6448 RO-data=832 RW-data=12 ZI-data=1660
FromELF: creating hex file...
"GPIO_IOToggle\GPIO_IOToggle.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:03
Load "GPIO_IOToggle\\GPIO_IOToggle.axf"
Erase Done.
Programming Done.
Verify OK.
Flash Load finished at 13:40:15
还有一个选项需要注意:“RESET AND RUN”,这样下载后程序会自动运行。
lajfda003| | 2023-12-11 18:52 | 只看该作者
现在的主流开发环境还是KEIL,用IAR的越来越少了。
kjkujkj22| | 2023-12-11 19:07 | 只看该作者
支持用keil仿真STM32
yujielun| | 2023-12-12 15:01 | 只看该作者
论坛有keil的石皮解的工具。
