[DemoCode下载]
CRC-8应用
743|7
yiyigirl2014|  楼主 | 2023-11-15 22:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 2 $
* $Date: 20/05/28 4:41p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Implement CRC in CRC-8 mode and get the CRC checksum result.
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2020 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable UART0 clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable CRC clock */
    CLK_EnableModuleClock(CRC_MODULE);
    /* Update System Core Clock */
    SystemCoreClockUpdate();
    /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk))
                    |(SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
/*  MAIN function        */
int main(void)
    const uint8_t acCRCSrcPattern[] = {0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39};
    uint32_t i, u32TargetChecksum = 0x58, u32CalChecksum = 0;
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    SYS_LockReg();
    /* Init UART0 to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+-----------------------------------------+\n");
    printf("|    CRC-8 Polynomial Mode Sample Code    |\n");
    printf("+-----------------------------------------+\n\n");
    printf("# Calculate [0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39] CRC-8 checksum value.\n");
    printf("    - Seed value is 0x5A             \n");
    printf("    - CPU write data length is 8-bit \n");
    printf("    - Checksum complement disable    \n");
    printf("    - Checksum reverse disable       \n");
    printf("    - Write data complement disable  \n");
    printf("    - Write data reverse disable     \n");
    printf("    - Checksum should be 0x%X        \n\n", u32TargetChecksum);
    /* Configure CRC controller for CRC-8 CPU mode */
    CRC_Open(CRC_8, 0, 0x5A, CRC_WDATA_8);
    /* Start to execute CRC-8 CPU operation */
    for(i = 0; i < sizeof(acCRCSrcPattern); i++)
        CRC_WRITE_DATA(acCRCSrcPattern[i]);
    /* Get CRC-8 checksum value */
    u32CalChecksum = CRC_GetChecksum();
    printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
    /* Disable CRC function */
    CLK_DisableModuleClock(CRC_MODULE);
    while(1);
/*** (C) COPYRIGHT 2020 Nuvoton Technology Corp. ***/
tpgf| | 2024-1-5 14:45 | 只看该作者
crc8和crc16的差别是什么呢
coshi| | 2024-1-5 15:19 | 只看该作者
现在常用的串口调试工具上都找不到这种校验方式了吧
kxsi| | 2024-1-5 16:07 | 只看该作者
CRC8计算时遇到1才异或,不是1就移位
wiba| | 2024-1-5 16:43 | 只看该作者
把需要校验的数据与多项式进行循环异或
drer| | 2024-1-5 20:25 | 只看该作者
CRC-8具有多个标准的生成多项式
qcliu| | 2024-1-5 20:58 | 只看该作者
现在这种校验方式都应用在什么领域呢
AloneKaven| | 2024-1-10 08:59 | 只看该作者
crc用的多吗
