[研电赛技术支持]
IIC协议——OLED屏幕
854|1
chenci2013|  楼主 | 2023-11-19 20:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "intrins.h"
sbit sda=P0^3;
sbit scl=P0^1;
void i2c_start(void);
void i2c_stop(void);
char ack(void);
void send_messege_i2c(char messege);
void w_cmd_i2c(char cmd);
void w_data_i2c(char data1);
void init_i2c(void);
void clear_oled(void);
code char tx[]={
0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x01,0x03,0x03,0x03,0x07,0x07,0x05,0x07,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x01,
0x05,0x0F,0x0F,0x0F,0x07,0x05,0x07,0x05,0x07,0x07,0x07,0x0F,0x0F,0x0F,0x0F,0x0F,
0x0F,0x4F,0x0F,0x0F,0x0F,0x0F,0x0F,0x1F,0x1F,0x1F,0x0F,0x0F,0x1F,0x1F,0x1F,0x1F,
0x1F,0x3F,0x1F,0x1F,0x7F,0x1F,0x1F,0x9F,0x9F,0x3F,0x7F,0x6F,0x6F,0x5F,0x9F,0xBF,
0xBF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x03,0x1F,0x1F,0x1F,0x3F,0x3F,0x1F,
0xCF,0xEF,0xF7,0xD7,0xDF,0xFB,0xFF,0x9F,0x9E,0x9F,0x8F,0x8F,0x9F,0x9F,0x9F,0xBF,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,0xF0,0xF0,0xF8,0xF8,0xF8,0xF8,0xFC,0xFC,
0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFC,0xE0,0xC0,0x80,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x0C,0x44,0x60,0xF5,0xE0,0xC0,0xC0,0xC0,0xC0,0xC0,0xD8,0xFE,0xE7,0xE5,
0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0x80,0x80,0x00,0x08,0x08,
0xC8,0x98,0x98,0x88,0x80,0x80,0xC0,0x81,0x81,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xDF,0x87,0x87,0xC3,0xC3,0xA3,0x91,0x91,0x11,0x11,0x19,0x99,0x89,0x09,0x09,
0x01,0x83,0xC3,0xC2,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x03,0x37,0x3D,0xBF,0xBF,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0x00,0x00,0x20,0x40,0x40,0x40,0x40,0x06,0x06,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1E,0x3E,0x7C,0x70,0xE0,0xC3,0x1F,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,
0x7F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0x1F,0x00,0x00,0x40,0x70,0x3C,0x1C,0x00,0x00,0x00,0x00,0x00,
0x00,0xC0,0xA0,0xC0,0xC0,0x00,0xC5,0xFF,0xFF,0xFF,0xFF,0xFD,0xFD,0xFF,0xFF,0xFF,
0xFF,0xFF,0x00,0x00,0x00,0x80,0x00,0x80,0x00,0x00,0xC0,0xC0,0x00,0xC0,0xC0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x0F,0x3F,0x7F,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xDF,0x9F,0x9F,0x1F,0x1F,0x1E,0x9E,0xDE,0xDE,0xDE,0xDE,0xDE,
0xDE,0x1E,0x1C,0x1C,0x1F,0x1F,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x3F,0x1F,
0x1F,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,
0x40,0x40,0x00,0x00,0x00,0x00,0x30,0x08,0x08,0x03,0x80,0x80,0x80,0xF8,0xF8,0xFE,
0xEF,0xC7,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFD,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0x00,0x00,0xE0,0xEF,0xE0,0xEF,0xE0,0x80,0x0F,0x6F,0x60,0xCF,0xAF,0xBF,
0x23,0x84,0xC0,0xA0,0xE0,0xE0,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,
0x02,0x04,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x07,0x0F,0x1F,0x3F,0x3F,0x7F,0x7C,0x7C,0xF8,0xF9,0xFB,0xFB,0xFB,0xFB,0xF9,
0xF9,0x78,0x78,0x7C,0x3E,0x3F,0x1F,0x1F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC1,0xE1,0xFF,0xFF,0xFE,0xFE,
0xFF,0xFF,0x00,0x00,0x9F,0xBF,0xDF,0xFF,0xFF,0xEF,0xE0,0x98,0x98,0x9A,0x87,0xA7,
0xA7,0x8F,0x8F,0x9F,0x9F,0x9A,0x9E,0x9C,0xFF,0xFB,0xFA,0xFC,0xFC,0xFC,0xEC,0xE8,
0xF8,0xF0,0xB0,0xB0,0xA0,0xE0,0xC0,0xC0,0xC0,0x80,0x80,0x80,0x80,0x00,0x00,0x20,
0x00,0x00,0x00,0x40,0xC0,0xC0,0x44,0x04,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xE0,0xE0,0xE0,0xE0,0xE0,
0xE0,0xD0,0xB0,0xF0,0xF8,0xF8,0xB8,0x9C,0xDC,0xDC,0x7E,0xFC,0xE4,0xEC,0xEC,0xF4,
0xF8,0xF8,0xFC,0xFC,0xF4,0xFE,0xFE,0xFE,0xFE,0xFF,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};    //这是page7的内容
void main(void)
        unsigned char i;
        unsigned int j;
        /*--  文字:  我  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
        init_i2c();
        clear_oled();   //清屏函数
        w_cmd_i2c(0x20);  //选择页寻址模式
        w_cmd_i2c(0x02);
        //w_cmd_i2c(0xB0);  //选择page  1011 0xxx
        //w_cmd_i2c(0x00);    //设置起始地址  低位
        //w_cmd_i2c(0x10);    //设置起始地址  高位
        //w_data_i2c(0x80);  //发送数据
        for(i=0;i<8;i++){
                w_cmd_i2c(0xB0+i);    //变换page  共有0-7 8个
                //i=3;
                for(j=128*i; j<(128*(i+1)); j++){   //变换的是tx中的数据
                        w_data_i2c(tx[j]);  //tx中的数据
        while(1){}
//下面是函数封装
        char i;  int j;
        for(i=0;i<8;i++){
                for(j=0;j<128;j++){
                        w_data_i2c(0x00);  //写0就行
void init_i2c(void)
        w_cmd_i2c(0xAE);//--display off
        w_cmd_i2c(0x00);//---set low column address
        w_cmd_i2c(0x10);//---set high column address
        w_cmd_i2c(0x40);//--set start line address
        w_cmd_i2c(0xB0);//--set page address
        w_cmd_i2c(0x81); // contract control
        w_cmd_i2c(0xFF);//--128
        w_cmd_i2c(0xA1);//set segment remap
        w_cmd_i2c(0xA6);//--normal / reverse
        w_cmd_i2c(0xA8);//--set multiplex ratio(1 to 64)
        w_cmd_i2c(0x3F);//--1/32 duty
        w_cmd_i2c(0xC8);//Com scan direction
        w_cmd_i2c(0xD3);//-set display offset
        w_cmd_i2c(0x00);//
        w_cmd_i2c(0xD5);//set osc division
        w_cmd_i2c(0x80);//
        w_cmd_i2c(0xD8);//set area color mode off
        w_cmd_i2c(0x05);//
        w_cmd_i2c(0xD9);//Set Pre-Charge Period
        w_cmd_i2c(0xF1);//
        w_cmd_i2c(0xDA);//set com pin configuartion
        w_cmd_i2c(0x12);//
        w_cmd_i2c(0xDB);//set Vcomh
        w_cmd_i2c(0x30);//
        w_cmd_i2c(0x8D);//set charge pump enable
        w_cmd_i2c(0x14);//
        w_cmd_i2c(0xAF);//--turn on oled panel
        i2c_start();
        send_messege_i2c(0x78);
        ack();
        send_messege_i2c(0x00);
        ack();
        send_messege_i2c(cmd);
        ack();
        i2c_stop();
        i2c_start();
        ack();
        send_messege_i2c(0x40);
        ack();
        send_messege_i2c(data1);
        ack();
        i2c_stop();
        scl=1;
        sda=0;
        sda=1;  //我的
        scl=0;  //老师的
        sda=1;
        scl=1;*/
        _nop_();   //
        sda=0;
        _nop_();   //
        scl=0;
void i2c_stop(void)
        scl=0;
        sda=0;
        scl=1;
        _nop_();   //
        sda=1;
        _nop_();   //
        sda=0;  //老师不要这个
char ack(void)      //应答信号
        char flag;
        sda=1;
        //_nop_();  //老师要的
        scl=1;
        _nop_();
        flag=sda;
        //_nop_();  //老师要的
        scl=0;
        _nop_();
        return flag;
        char i;
        for(i=0;i<8;i++){
                scl=0;
                _nop_();   //必要
                sda= messege & 0x80 ;
                //_nop_();  //老师要的
                scl=1;
                _nop_();
                scl=0;
                messege=messege<<1;
原文链接:https://blog.csdn.net/m0_67794575/article/details/130902543
chenqianqian| | 2023-11-22 08:39 | 只看该作者
IIC速率还是慢了点
