[DemoCode下载]
ML51通过PWM生成正弦波信号
754|3
xuanhuanzi|  楼主 | 2023-11-28 19:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ML51_PWM_SINE-main.zip (2.42 MB)
/*_____ I N C L U D E S ____________________________________________________*/
#include "ML51.h"
#include <math.h>
#include        "project_config.h"
/*_____ D E C L A R A T I O N S ____________________________________________*/
volatile uint8_t u8TH0_Tmp = 0;
volatile uint8_t u8TL0_Tmp = 0;
//UART 0
//bit BIT_TMP;
//bit BIT_UART;
//bit uart0_receive_flag=0;
//unsigned char uart0_receive_data;
/*_____ D E F I N I T I O N S ______________________________________________*/
#define SYS_CLOCK        (24000000ul)
#define PWM_FREQ        (24000ul)
#define PWM_CHANNEL                                   (2)
#define SINE_FREQ                                        (60)
#define SINE_RESOLUTION                                (360)
#define Pi_Value                                                       (3.14159)
volatile uint16_t PWM_Period = 0;
uint16_t g_u16Sine_Count_u = 0;
xdata uint16_t g_au16Sine[SINE_RESOLUTION] = {0};
/*_____ M A C R O S ________________________________________________________*/
volatile uint32_t BitFlag = 0;
uint32_t counter_tick = 0;
/*_____ F U N C T I O N S __________________________________________________*/
void tick_counter(void)
        counter_tick++;
uint32_t get_tick(void)
        return (counter_tick);
void set_tick(uint32_t t)
        counter_tick = t;
void compare_buffer(uint8_t *src, uint8_t *des, int nBytes)
    uint16_t i = 0;
    for (i = 0; i < nBytes; i++)
        if (src[i] != des[i])
            printf("error idx : %4d : 0x%2X , 0x%2X\r\n", i , src[i],des[i]);
                        set_flag(flag_error , Enable);
        if (!is_flag_set(flag_error))
            printf("compare_buffer finish \r\n");
                set_flag(flag_error , Disable);
void reset_buffer(void *dest, unsigned int val, unsigned int size)
    uint8_t *pu8Dest;
//    unsigned int i;
    pu8Dest = (uint8_t *)dest;
        #if 1
        while (size-- > 0)
                *pu8Dest++ = val;
        #else
        memset(pu8Dest, val, size * (sizeof(pu8Dest[0]) ));
        #endif
void copy_buffer(void *dest, void *src, unsigned int size)
    uint8_t *pu8Src, *pu8Dest;
    unsigned int i;
    pu8Src  = (uint8_t *)src;
        #if 0
          while (size--)
            *pu8Dest++ = *pu8Src++;
        #else
    for (i = 0; i < size; i++)
        pu8Dest[i] = pu8Src[i];
        #endif
void dump_buffer(uint8_t *pucBuff, int nBytes)
    uint16_t i = 0;
    printf("dump_buffer : %2d\r\n" , nBytes);
    for (i = 0 ; i < nBytes ; i++)
        printf("0x%2X," , pucBuff[i]);
        if ((i+1)%8 ==0)
            printf("\r\n");
    printf("\r\n\r\n");
void  dump_buffer_hex(uint8_t *pucBuff, int nBytes)
    int     nIdx, i;
    nIdx = 0;
    while (nBytes > 0)
        printf("0x%04X  ", nIdx);
        for (i = 0; i < 16; i++)
            printf("%02X ", pucBuff[nIdx + i]);
        printf("  ");
            if ((pucBuff[nIdx + i] >= 0x20) && (pucBuff[nIdx + i] < 127))
                printf("%c", pucBuff[nIdx + i]);
            else
                printf(".");
            nBytes--;
        nIdx += 16;
        printf("\n");
    printf("\n");
void delay(uint16_t dly)
        delay(100) : 14.84 us
        delay(200) : 29.37 us
        delay(300) : 43.97 us
        delay(400) : 58.5 us
        delay(500) : 73.13 us
        delay(1500) : 0.218 ms (218 us)
        delay(2000) : 0.291 ms (291 us)
        while( dly--);
void send_UARTString(uint8_t* Data)
        #if 1
        uint16_t i = 0;
        while (Data[i] != '\0')
                #if 1
                SBUF = Data[i++];
                #else
                UART_Send_Data(UART0,Data[i++]);
                #endif
        #endif
        #if 0
        uint16_t i = 0;
        for(i = 0;i< (strlen(Data)) ;i++ )
                UART_Send_Data(UART0,Data[i]);
        #endif
        #if 0
    while(*Data)
        UART_Send_Data(UART0, (unsigned char) *Data++);
        #endif
void send_UARTASCII(uint16_t Temp)
    uint8_t print_buf[16];
    uint16_t i = 15, j;
    *(print_buf + i) = '\0';
    j = (uint16_t)Temp >> 31;
    if(j)
        (uint16_t) Temp = ~(uint16_t)Temp + 1;
    do
        i--;
        *(print_buf + i) = '0' + (uint16_t)Temp % 10;
        (uint16_t)Temp = (uint16_t)Temp / 10;
    while((uint16_t)Temp != 0);
    if(j)
        i--;
        *(print_buf + i) = '-';
    send_UARTString(print_buf + i);
void SineTable_Create(void)
    uint16_t i = 0;
    /* Create sine table for lookup */
    for (i = 0; i < SINE_RESOLUTION; i++)
        /* Add 1.0 to offset sine result from [-1, 1] to [0, 2],
        and divide with 2.0 to compress to [0, 1] */
        g_au16Sine[i] = ((sin((i * Pi_Value) / 180.0) + 1.0) / 2.0) * PWM_Period;
void PWMx_Init(uint16_t ch , uint16_t uFrequency)
        uint32_t res = 0;
        switch(ch)
                case 2:
                MFP_P03_PWM0_CH2;
                P03_PUSHPULL_MODE;
                break;
    PWM0_IMDEPENDENT_MODE;
    PWM0_CLOCK_DIV_16;
        PWM frequency   = Fpwm/((PWMPH,PWMPL)+1) = (24MHz/2)/(PWMPH,PWMPL)+1) = 20KHz
        res = (SYS_CLOCK >> 4);                        // 2 ^ 4 = 16
        res = res/uFrequency;
        res = res - 1;
        PWM_Period = res;
        SFRS = 1;
    PWM0PH = HIBYTE(res);
    PWM0PL = LOBYTE(res);
        PWM0C2H = HIBYTE(g_au16Sine[g_u16Sine_Count_u]);
        PWM0C2L = LOBYTE(g_au16Sine[g_u16Sine_Count_u]);
    g_u16Sine_Count_u++;
    /* Load PWM new setting and start PWM */
    set_PWM0CON0_LOAD;
    set_PWM0CON0_PWMRUN;
void GPIO_Init(void)
//        P03_PUSHPULL_MODE;
//        P30_PUSHPULL_MODE;
void Timer1_IRQHandler(void)
        SFRS = 1;
    /* Reset sine array pointer */
    if (g_u16Sine_Count_u == SINE_RESOLUTION)
    set_PWM0CON0_LOAD;
void Timer1_ISR(void) interrupt 3        // Vector [url=home.php?mod=space&uid=72445]@[/url]  0x0B
    clr_TCON_TF1;
        Timer1_IRQHandler();
void Timer1_Init(void)
        uint16_t res = 0;
        uint16_t TIMER1_VALUE = 0;
        ENABLE_TIMER1_MODE2;
    TIMER1_FSYS_DIV12;
          Time-out period = (0xFF - TIMER1_VALUE) / clock frequency
                          = 1 / (sine wave frequency * sine wave resolution)
                  TIMER1_VALUE = 0xFF - ((24 MHz / 12) / (60 Hz * resolution)
        TIMER1_VALUE = 0xFF - (2000000ul/(SINE_FREQ*SINE_RESOLUTION));
    TH1 = TIMER1_VALUE;
    TL1 = TIMER1_VALUE;
    ENABLE_TIMER1_INTERRUPT;                       //enable Timer0 interrupt
    ENABLE_GLOBAL_INTERRUPT;                       //enable interrupts
    set_TCON_TR1;                                  //Timer0 run
void Timer0_IRQHandler(void)
        tick_counter();
        if ((get_tick() % 1000) == 0)
//                P03 ^= 1;
void Timer0_ISR(void) interrupt 1        // Vector @  0x0B
    TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
    clr_TCON_TF0;
        Timer0_IRQHandler();
void Timer0_Init(void)
        uint16_t res = 0;
        ENABLE_TIMER0_MODE1;
    TIMER0_FSYS_DIV12;
        u8TH0_Tmp = HIBYTE(TIMER_DIV12_VALUE_1ms_FOSC_240000);
        u8TL0_Tmp = LOBYTE(TIMER_DIV12_VALUE_1ms_FOSC_240000);
    TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
    ENABLE_TIMER0_INTERRUPT;                       //enable Timer0 interrupt
    set_TCON_TR0;                                  //Timer0 run
//void Serial_ISR (void) interrupt 4
//    _push_(SFRS);
//    if (RI)
//      uart0_receive_flag = 1;
//      uart0_receive_data = SBUF;
//      clr_SCON_RI;                                         // Clear RI (Receive Interrupt).
//    if  (TI)
//      if(!BIT_UART)
//          TI = 0;
//    _pop_(SFRS);
void UART0_Init(void)
        MFP_P31_UART0_TXD;                              // UART0 TXD use P1.6
        P31_QUASI_MODE;                                  // set P1.6 as Quasi mode for UART0 trasnfer
        UART_Open(SYS_CLOCK,UART0_Timer3,115200);        // Open UART0 use timer1 as baudrate generate and baud rate = 115200
        ENABLE_UART0_PRINTF;
//        printf("UART0_Init\r\n");
void SYS_Init(void)
        FsysSelect(FSYS_HIRC);
    ALL_GPIO_QUASI_MODE;
//    ENABLE_GLOBAL_INTERRUPT;                // global enable bit
void main (void)
    SYS_Init();
    UART0_Init();
        GPIO_Init();
        PWMx_Init(PWM_CHANNEL , PWM_FREQ);
        SineTable_Create();
        Timer0_Init();
        Timer1_Init();
    while(1)
heisexingqisi| | 2023-11-29 20:44 | 只看该作者
这是什么原理
捉虫天师| | 2023-11-30 16:02 | 只看该作者
有没有实现原理说明
EmmaTT| | 2023-12-6 10:46 | 只看该作者
能讲解一下元件吗
