[DemoCode下载]
MG51 I2C使用方法
200|1
huahuagg|  楼主 | 2023-12-16 17:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* SPDX-License-Identifier: Apache-2.0        */
/* Copyright(c) 2023 Nuvoton Technology Corp. All rights reserved.                                         */
//  File Function: MG51 I2C master mode demo code, the Slave address = 0xA4
//   ____________            _____________
//  |            |   SDA    |             |
//  |MG51(M)     |          | MG51(S)     |
//  |(I2C_Master)|          | (I2C_Slave) |
//  |            |   SCL    |             |
//  |____________|          |_____________|
//  The protocol of I2C is master: start -> write 10 byte(ACK) ->stop -> start ->read 10 byte(ACK) -> stop
//  Setting break point in I2C slave to check time out function
#include "MG51.H"
#define I2C_CLOCK                 14
#define I2C_SLAVE_ADDRESS         0xA4
#define I2C_WR                    0
#define I2C_RD                    1
#define LOOP_SIZE                 10
BIT   i2cErrorFlag=0;
void I2C_ISR(void) interrupt 6
   if (I2TOC&SET_BIT0)
      while(1);                     /* When into this loop means I2C transmit time out */
void Init_I2C(void)
    P13_OPENDRAIN_MODE;          // Modify SCL pin to Open drain mode. don't forget the pull high resister in circuit
    P14_OPENDRAIN_MODE;          // Modify SDA pin to Open drain mode. don't forget the pull high resister in circuit
    P13_ST_ENABLE;
    P14_ST_ENABLE;
    /* Set I2C clock rate */
    I2CLK = I2C_CLOCK;
   /* Enable I2C time out divier as clock base is Fsys/4, the time out is about 4ms when Fsys = 16MHz */
    set_I2TOC_DIV;
    clr_I2TOC_I2TOF;
   /* Enable I2C intterupt for I2C time out */
    set_EIE_EI2C;                               //enable I2C interrupt by setting IE1 bit 0
    set_IE_EA;
    /* Enable I2C */
    set_I2CON_I2CEN;
void I2C_Error(void)
    while (1);
//----  Page Write----------------------------------------------------------------------------
void I2C_Write_Process(UINT8 u8DAT)
    unsigned char  u8Count;
    set_I2TOC_I2TOCEN;                           /* Enable I2C time out */
    /* Write Step1 */
    set_I2CON_STA;                              /* Send Start bit to I2C EEPROM */
    clr_I2CON_SI;
    while (!SI);                                /*Check SI set or not  */
    if (I2STAT != 0x08)                         /*Check status value after every step   */
        i2cErrorFlag=1;
        goto I2CWRSTOP;
    /* Write Step2 */
    clr_I2CON_STA;                              /*STA=0*/
    I2DAT = (I2C_SLAVE_ADDRESS | I2C_WR);
    clr_I2CON_SI;
    if (I2STAT != 0x18)
        i2cErrorFlag=1;
        goto I2CWRSTOP;
    /* Write Step3 */
    for (u8Count = 0; u8Count < LOOP_SIZE; u8Count++)
        I2DAT = u8DAT;
        clr_I2CON_SI;
        while (!SI);                            /*Check SI set or not*/
        if (I2STAT != 0x28)
            i2cErrorFlag=1;
            goto I2CWRSTOP;
        u8DAT = ~u8DAT;
    /* Write Step4 */
    I2CWRSTOP:
    set_I2CON_STO;
    clr_I2CON_SI;
    while (STO);                                /* Check STOP signal */
    if  (i2cErrorFlag)
      printf ("\n I2C write error !");
//----  Page Read ----------------------------------------------------------------------------
void I2C_Read_Process(UINT8 u8DAT)
    /* Read Step1 */
    set_I2CON_STA;
    clr_I2CON_SI;
    while (!SI);                                //Check SI set or not
    if (I2STAT != 0x08)                         //Check status value after every step
        i2cErrorFlag=1;
        goto I2CRDSTOP;
    /* Step13 */
    clr_I2CON_STA;                                    //STA needs to be cleared after START codition is generated
    I2DAT = (I2C_SLAVE_ADDRESS | I2C_RD);
    clr_I2CON_SI;
    if (I2STAT != 0x40)
        i2cErrorFlag=1;
        goto I2CRDSTOP;
    /* Step14 */
    for (u8Count = 0; u8Count <LOOP_SIZE; u8Count++)
        set_I2CON_AA;
        clr_I2CON_SI;
        if (I2STAT != 0x50)
            i2cErrorFlag=1;
            goto I2CRDSTOP;
        if (I2DAT != u8DAT)
            i2cErrorFlag=1;
            goto I2CRDSTOP;
        u8DAT = ~u8DAT;
    /* Step15 */
    clr_I2CON_AA;
    clr_I2CON_SI;
    if (I2STAT != 0x58)
        i2cErrorFlag=1;
        goto I2CRDSTOP;
    /* Step16 */
    I2CRDSTOP:
    set_I2CON_STO;
    clr_I2CON_SI;
      printf ("\n I2C read error !");
void main(void)
    /* UART0 settting for printf function */
    MODIFY_HIRC(HIRC_24);
    Enable_UART0_VCOM_printf_24M_115200();
    printf ("\n Test start ...");
    Init_I2C();                                 /* initial I2C circuit  */
    I2C_Write_Process(0x55);                    /* I2C Master will send 10 byte 0x55,0xAA,.... to slave */
    I2C_Read_Process(0x55);
    while (1);
21mengnan| | 2023-12-17 11:35 | 只看该作者
clr_I2CON_SI 这个SI是什么。
