[其他ST产品]
stm32+FSMC+CH376设计程序u8Result始终返回0x5f,该如何解决?
52|0
七毛钱|  楼主 | 2023-12-20 11:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
接口连接:#CS-------FSMC_NE1
              #INT-------FSMC_NWAIT
                 A0--------FSMC_A15
              #RD--------FSMC_NOE
              #WR-------FSMC_NWE
接口配置:GPIO_InitTypeDef GPIO_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
        /* ʹÄÜ FSMC, GPIOD, GPIOE, GPIOF, GPIOG ºÍ AFIO ʱÖÓ */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                             RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG |
                             RCC_APB2Periph_AFIO, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
  /*FSMCÊý¾ÝÏßFSMC_D[0:7]³õʼ»¯£¬ÍÆÍ츴ÓÃÊä³ö*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_14 |GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 |GPIO_Pin_10;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        /*FSMCµØÖ·ÏßFSMC_A15³õʼ»¯£¬ÍÆÍ츴ÓÃÊä³ö*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
        GPIO_Init(GPIOG, &GPIO_InitStructure);
        /*FSMC NOEºÍNWE³õÊÔ»¯£¬ÍÆÍ츴ÓÃÊä³ö*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_5;
        /*FSMC NE1³õÊÔ»¯£¬ÍÆÍ츴ÓÃÊä³ö*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
        /*FSMC_NWAIT³õÊÔ»¯£¬ÊäÈë*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOAtiNG;
FSMC配置:
FSMC_NORSRAMInitTypeDef  init;
        FSMC_NORSRAMTimingInitTypeDef  timing;
        /*-- FSMC Configuration ------------------------------------------------------*/
        /*----------------------- SRAM Bank 1 ----------------------------------------*/
        /* FSMC_Bank1_NORSRAM1 configuration */
        timing.FSMC_AddressSetupTime = 0;
        timing.FSMC_AddressHoldTime = 0;
        timing.FSMC_DataSetupTime = 2;
        timing.FSMC_BusTurnAroundDuration = 0;
        timing.FSMC_CLKDivision = 0;
        timing.FSMC_DataLatency = 0;
        timing.FSMC_AccessMode = FSMC_AccessMode_A;
        init.FSMC_Bank = FSMC_Bank1_NORSRAM1;
        init.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
        init.FSMC_MemoryType = FSMC_MemoryType_SRAM;
        init.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
        init.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
        init.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;        /* ×¢Òâ¾É¿âÎÞÕâ¸ö³ÉÔ± */
        init.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
        init.FSMC_WrapMode = FSMC_WrapMode_Disable;
        init.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
        init.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
        init.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
        init.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
        init.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
        init.FSMC_ReadWriteTimingStruct = &timing;
        init.FSMC_WriteTimingStruct = &timing;
        FSMC_NORSRAMInit(&init);
        /* - BANK 1 (of NOR/SRAM Bank 1~4) is enabled */
        FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
地址配置:#define CH376_DAT_PORT        (*( vu32 *)0x60000000) // A15 = 0, CS = 0
        #define CH376_CMD_PORT        (*( vu32 *)0x60008000) // A15 = 1, CS = 0
配置完后测试通信
/* 测试单片机与CH376之间的通讯接口 */
// 发送测试命令
xWriteCH376Cmd(CMD11_CHECK_EXIST);
// 发送测试数据
xWriteCH376Data(0x65);
// 读数据
u8Result = xReadCH376Data();
u8Result 始终返回0x5f   求教有没有人遇到同样问题,怎么解决的啊
从上往下1:WR
            2:RD
            3:A0
            4:NE1
            5:D1(其中一位数据)
写一个数据时,写信号产生了几个周期 ,不正常。。。。。。这是怎么回事?
CH376并口时序参数:
