[STM32G4] 基于STM32G4系列对定时器双向断路输入Bidirectional break inputs的应用测试
1312|10
 楼主| qn7a12 发表于 2023-12-26 12:05 | 显示全部楼层 |阅读模式
测试描述
1.适用于STM32G474RETx Devices;
2.系统时钟设为170MHz,TIM1输入时钟选择APB2 clock (PCLK2),即TIM1CLK = HCLK = SystemCoreClock;
3.TIM1的计数频率设为85 MHz,即Prescaler = (TIM1CLK / TIM1 counter clock) – 1,Prescaler = ((SystemCoreClock) /85 MHz) – 1;
4.TIM1的输出频率设为85 KHz,即ARR = (TIM1 counter clock / TIM1 output clock) – 1=999;
5.设置TIM1通道占空比分别为:TIM1 Channel1 duty cycle = (TIM1_CCR1/ TIM1_ARR + 1)* 100 = 50%,TIM1 Channel2 duty cycle = (TIM1_CCR2/ TIM1_ARR + 1)* 100 = 37.5%,TIM1 Channel3 duty cycle = (TIM1_CCR3/ TIM1_ARR + 1)* 100 = 25%;
6.设置break触发源为TIM_BREAKINPUTSOURCE_COMP1和TIM_BREAKINPUTSOURCE_BKIN;
7.设置BKINP位为“1”,BKP位为“1”;
 楼主| qn7a12 发表于 2023-12-26 12:06 | 显示全部楼层
测试细节
设置break双向管脚
  1. void HAL_TIM_PWM_MspInit(TIM_HandleTypeDef* htim_pwm)
  3.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  4.   if(htim_pwm->Instance==TIM1)
  5.   {
  6.   /* USER CODE BEGIN TIM1_MspInit 0 */
  7.   /* USER CODE END TIM1_MspInit 0 */
  8.     /* Peripheral clock enable */
  9.     __HAL_RCC_TIM1_CLK_ENABLE();
  10.     __HAL_RCC_GPIOA_CLK_ENABLE();
  11.     /**TIM1 GPIO Configuration
  12.     PA6     ------> TIM1_BKIN
  13.     */
  14.     GPIO_InitStruct.Pin = GPIO_PIN_6;
  15.     GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
  16.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  17.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  18.     GPIO_InitStruct.Alternate = GPIO_AF6_TIM1;
  19.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  20.   /* USER CODE BEGIN TIM1_MspInit 1 */
  21.   /* USER CODE END TIM1_MspInit 1 */
  22.   }
  23. }
设置PWM输出管脚:
  1. void HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim)
  4.   if(htim->Instance==TIM1)
  5.   {
  6.   /* USER CODE BEGIN TIM1_MspPostInit 0 */
  7.   /* USER CODE END TIM1_MspPostInit 0 */
  8.
  9.     __HAL_RCC_GPIOA_CLK_ENABLE();
  10.     __HAL_RCC_GPIOB_CLK_ENABLE();
  12.     PB13     ------> TIM1_CH1N
  13.     PB15     ------> TIM1_CH3N
  14.     PA8     ------> TIM1_CH1
  15.     PA9     ------> TIM1_CH2
  16.     PA10     ------> TIM1_CH3
  17.     PB0     ------> TIM1_CH2N
  18.     */
  19.     GPIO_InitStruct.Pin = GPIO_PIN_13 | GPIO_PIN_0;
  20.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  21.     GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  22.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  23.     GPIO_InitStruct.Alternate = GPIO_AF6_TIM1;
  24.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  25.     GPIO_InitStruct.Pin = GPIO_PIN_15;
  26.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  27.     GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  28.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  29.     GPIO_InitStruct.Alternate = GPIO_AF4_TIM1;
  30.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  31.     GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10;
  32.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  33.     GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  34.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  35.     GPIO_InitStruct.Alternate = GPIO_AF6_TIM1;
  36.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  37.   /* USER CODE BEGIN TIM1_MspPostInit 1 */
  38.   /* USER CODE END TIM1_MspPostInit 1 */
  39.   }
  40. }
 楼主| qn7a12 发表于 2023-12-26 12:08 | 显示全部楼层
设置比较器输出管脚:
void HAL_COMP_MspInit(COMP_HandleTypeDef* hcomp)
  if(hcomp->Instance==COMP1)
  /* USER CODE BEGIN COMP1_MspInit 0 */
  /* USER CODE END COMP1_MspInit 0 */
    /**COMP1 GPIO Configuration
    PB1     ------> COMP1_INP
    GPIO_InitStruct.Pin = GPIO_PIN_1;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  /* USER CODE BEGIN COMP1_MspInit 1 */
  /* USER CODE END COMP1_MspInit 1 */
 楼主| qn7a12 发表于 2023-12-26 12:09 | 显示全部楼层
配置break输入源: sBreakInputConfig.Source = TIM_BREAKINPUTSOURCE_COMP1;
  sBreakInputConfig.Enable = TIM_BREAKINPUTSOURCE_ENABLE;
  sBreakInputConfig.Polarity = TIM_BREAKINPUTSOURCE_POLARITY_LOW;
  if (HAL_TIMEx_ConfigBreakInput(&htim1, TIM_BREAKINPUT_BRK, &sBreakInputConfig) != HAL_OK)
    Error_Handler();
  sBreakInputConfig.Source = TIM_BREAKINPUTSOURCE_BKIN;
    Error_Handler();
配置死区及break双向IO:  sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_ENABLE;
  sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_ENABLE;
  sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  sBreakDeadTimeConfig.DeadTime = 100;
  sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  sBreakDeadTimeConfig.BreakFilter = 0;
  sBreakDeadTimeConfig.BreakAFMode = TIM_BREAK_AFMODE_BIDIRECTIONAL;
  sBreakDeadTimeConfig.Break2State = TIM_BREAK2_DISABLE;
  sBreakDeadTimeConfig.Break2Polarity = TIM_BREAK2POLARITY_HIGH;
  sBreakDeadTimeConfig.Break2Filter = 0;
  sBreakDeadTimeConfig.Break2AFMode = TIM_BREAK_AFMODE_INPUT;
  sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_ENABLE;
  if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
    Error_Handler();
 楼主| qn7a12 发表于 2023-12-26 12:10 | 显示全部楼层
主函数:int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_TIM1_Init();
  MX_COMP1_Init();
  /* Start COMP1 */
  if(HAL_COMP_Start(&hcomp1) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
  /* Start channel 1 */
  if (HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1) != HAL_OK)
    /* PWM Generation Error */
    Error_Handler();
  /* Start channel 1N */
  if(HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_1) != HAL_OK)
    /* Starting Error */
    Error_Handler();
  /* Start channel 2 */
  if (HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
  /* Start channel 2N */
  if(HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
  /* Start channel 3 */
  if (HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3) != HAL_OK)
    /* PWM generation Error */
    Error_Handler();
  /* Start channel 3N */
  if(HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_3) != HAL_OK)
    Error_Handler();
  /* Enable TIM1 BREAK */
        MODIFY_REG(htim1.Instance->BDTR, TIM_BDTR_BKE, TIM_BREAK_ENABLE);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1) { }
测试过程与现象
Channel0~5分别为TIM1CH0,TIM1CH0N,TIM1CH1,TIM1CH1N,TIM1CH2,TIM1CH2N;Channel7为break双向IO;
 楼主| qn7a12 发表于 2023-12-26 12:11 | 显示全部楼层
 楼主| qn7a12 发表于 2023-12-26 12:13 | 显示全部楼层
3.将BKDSRM位置高,请求释放输出控制,等待所有系统断路请求消失,等待BKDSRM (BK2DSRM)位硬件清零。 35139658a52ee28295.png
