[DemoCode下载]
M031使用库函数读写EEPROM操作
108|1
mintspring|  楼主 | 2023-12-26 23:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 5 $
* $Date: 18/07/09 7:01p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to use I2C interface to access EEPROM.
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#define I2C_EEPROM_ADDRESS  0x50
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 48MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable UART0 clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable I2C0 clock */
    CLK_EnableModuleClock(I2C0_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and cyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Set I2C0 multi-function pins */
    SYS->GPC_MFPL = (SYS->GPC_MFPL & ~(SYS_GPC_MFPL_PC0MFP_Msk | SYS_GPC_MFPL_PC1MFP_Msk)) |
                    (SYS_GPC_MFPL_PC0MFP_I2C0_SDA | SYS_GPC_MFPL_PC1MFP_I2C0_SCL);
    /* Lock protected registers */
    SYS_LockReg();
void I2C0_Close(void)
    /* Disable I2C0 interrupt and clear corresponding NVIC bit */
    I2C_DisableInt(I2C0);
    NVIC_DisableIRQ(I2C0_IRQn);
    /* Disable I2C0 and close I2C0 clock */
    I2C_Close(I2C0);
    CLK_DisableModuleClock(I2C0_MODULE);
void I2C0_Init(void)
    /* Open I2C module and set bus clock */
    I2C_Open(I2C0, 100000);
    /* Get I2C0 Bus Clock */
    printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
int main()
    uint32_t i;
    uint8_t txbuf[10] = {0}, rDataBuf[10] = {0};
    SYS_Init();
    /* Init UART0 to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("+-------------------------------------+\n");
    printf("|    Level1 I2C EEPROM Sample Code    |\n");
    printf("+-------------------------------------+\n\n");
    printf("\n");
    /* Init I2C0 to access EEPROM */
    I2C0_Init();
    /* Prepare data for transmission */
    printf("Write Data: ");
    for (i = 0; i < 10; i++)
        txbuf[i] = (uint8_t) i + 3;
        printf("  %d",txbuf[i]);
    printf("\n");
    /* Write 10 bytes data to EEPROM */
    while(I2C_WriteMultiBytesTwoRegs(I2C0, I2C_EEPROM_ADDRESS, 0x0000, txbuf, 10) < 10);
    printf("Multi bytes Write access Pass.....\n\n");
    /* Use Multi Bytes Read from EEPROM (Two Registers) */
    while(I2C_ReadMultiBytesTwoRegs(I2C0, I2C_EEPROM_ADDRESS, 0x0000, rDataBuf, 10) < 10);
    printf("Read Data:  ");
    for(i = 0; i < 10; i++)
        printf("  %d",rDataBuf[i]);
    printf("\n");
    printf("Multi bytes Read access Pass.....\n\n");
    /* Compare TX data and RX data */
        if(txbuf[i] != rDataBuf[i])
            printf("Data compare fail... R[%d] Data: 0x%X\n", i, rDataBuf[i]);
            while(1);
    printf("Data compare done... [PASS]\n");
    while(1);
/*** (C) COPYRIGHT 2018 Nuvoton Technology Corp. ***/
mintspring|  楼主 | 2023-12-26 23:24 | 只看该作者
该芯片提供的BSP库函数更为好用。
