[STM32F3]
请问stm32f303串口不能正常工作收不到任何数据是什么原因?
174|14
onlycook|  楼主 | 2024-1-5 09:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不能正确接收数据(RDR里面能接收数据,但不正确),我PC端发送3,RDR显示是0x0FE,波特率都是115200啊;发送的时候,TDR里能够显示正确的发送数据,但是IO口那收不到任何数据,IO口配置应该没什么问题啊,要不然怎么能够对PC端发送的数据有反映呢,请大家帮忙,谢谢了!
void tiaoshi(void)
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStruct;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_6 | GPIO_Pin_7);   //USART2对应的RX,TX引脚
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;             //复用模式
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;         //推挽输出
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    //配置复用功能
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_7);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_7);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStruct);
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_DeInit(USART1);
    USART_Init(USART1, &USART_InitStructure);
    //USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);//使能中断
    USART_ClearFlag (USART1,USART_FLAG_TC);
    USART_Cmd(USART1, ENABLE);    //打开串口
    while(1)
        USART_SendData(USART1,4);
        // USART in mode Tramitter ------------------------------------------------
        if (USART_GetITStatus(USART1, USART_IT_TXE) == SET)
            USART_SendData(USART1, Receive);
            //Disable the USARTx transmit data register empty interrupt
            USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
        //* USART in mode Receiver --------------------------------------------------
        if ((USART_GetITStatus(USART1, USART_IT_RXNE) == SET)||(USART_GetITStatus(USART1, USART_IT_ORE) == SET))
            //Receive = USART_ReceiveData(USART1);
            //USART_SendData(USART1, Receive);
            USART_SendData(USART1,USART_ReceiveData(USART1));
            while (!USART_GetFlagStatus(USART1,USART_FLAG_TC));
laocuo1142| | 2024-1-9 10:35 | 只看该作者
首先检查硬件,特别是串口硬件本身是否存在故障。此外,检查串口连接线是否正常,如接触是否良好、有无断路等。
flycamelaaa| | 2024-1-9 10:36 | 只看该作者
可能是电源问题,电源不足可能导致串口无法正常工作。
powerantone| | 2024-1-9 10:36 | 只看该作者
检查串口的配置参数,如波特率、数据位、停止位等设置是否正确。
stormwind123| | 2024-1-9 10:37 | 只看该作者
可能是串口驱动程序出现问题,或存在软件冲突。
可以试试更新一下驱动
在曼谷的春| | 2024-1-13 10:35 | 只看该作者
就算你波特率写的是115200,实际也可能不是115200,因为外部时钟不一定对哦
未说出口的像你| | 2024-1-13 10:40 | 只看该作者
建议先用demo试试,这样能好一些
我吃小朋友| | 2024-1-13 13:00 | 只看该作者
你要是用UDP的话,端口啥的,配置了没
月亮一键变蓝| | 2024-1-13 13:00 | 只看该作者
看看你的时钟配置吧,也许是这里的问题
失物招領| | 2024-1-13 15:00 | 只看该作者
我记得F107有关于UDP的例程了吧
她已醉| | 2024-1-13 15:00 | 只看该作者
你的串口助手咋弄的?比如数据位,停止位都对应上了没
春日负喧| | 2024-1-13 17:00 | 只看该作者
你用STM32搞UDP 服务?
温室雏菊| | 2024-1-13 19:00 | 只看该作者
Lwip确实比较难学,感觉这种lib得有点基础才能去触碰
春日负喧| | 2024-1-13 19:00 | 只看该作者
建议直接拿逻辑分析仪抓一下看看
故意相遇| | 2024-1-13 21:00 | 只看该作者
你这是不是时钟配置错了啊
将爱藏于深海| | 2024-1-13 23:00 | 只看该作者
是不是因为缺项了,导致连不上啊
一只眠羊| | 2024-1-13 23:00 | 只看该作者
网上应该有关于F303的例程吧,直接跑个串口例程看看呗
白马过平川| | 2024-1-14 01:00 | 只看该作者
这种都是需要看例程的,主要串口涉及的地方比较多,比如时钟,各种串口配置都是有的
她已醉| | 2024-1-14 02:00 | 只看该作者
你试试仿真,看看UDP通信部分,走到哪儿走不进去的
