[STM32F3]
请问stm32 f3外拓AD5313R如何配置和发数据?
228|11
stormwind123|  楼主 | 2024-1-18 15:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是我写的代码:
SPI3_DAC :static void SPI3_Config(void)
        SPI_InitTypeDef  SPI_InitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_6);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_6);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;                                        //СDA_SYNC
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;                                        //SPI3_SCK
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        /* Configure SPI3 pins:  MISO and MOSI ---------------------------------*/
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11;                                        //SPI3_MISO
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12;                                        //SPI3_MOSI
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI3, &SPI_InitStructure);
        SPI_CalculateCRC(SPI3, ENABLE);
        SPI_Cmd(SPI3, ENABLE);
        SPI_I2S_ITConfig(SPI3, SPI_I2S_IT_TXE, ENABLE);
        SPI_SendData8(SPI3, 0X00);
利用中断发送数据:
u8 TxBuffer[3] = {0x21,0xff,0x30};
void SPI3_IRQHandler(void)
        static uint32_t Tx_Idx = 0;
  GPIO_ResetBits(GPIOA, GPIO_Pin_15);
        GPIO_SetBits(GPIOC, GPIO_Pin_10);
  if (SPI_I2S_GetITStatus(SPI3, SPI_I2S_IT_TXE) == SET)
    SPI_SendData8(SPI3, TxBuffer[Tx_Idx++]);
      if (Tx_Idx ==2)
        SPI_I2S_ITConfig(SPI3, SPI_I2S_IT_TXE, DISABLE);
                                Tx_Idx = 0;
                                GPIO_SetBits(GPIOA, GPIO_Pin_15);
                                GPIO_ResetBits(GPIOC, GPIO_Pin_10);
求助 是为什么DAC_OUT无法输出电压。
elephant00| | 2024-1-22 16:36 | 只看该作者
建议查阅AD5313R的数据手册和STM32F3的参考手册
夜阑风雨| | 2024-3-21 09:10 | 只看该作者
你就正常配置呗,一般是使用SPI的吧
远山寻你| | 2024-3-21 12:00 | 只看该作者
你要是使用SPI3的话,好像NSS引脚也得接对,不然好像使用不了
光辉梦境| | 2024-3-21 14:00 | 只看该作者
你现在是发不了数据还是配置不对啊?
三生万物| | 2024-3-21 16:00 | 只看该作者
硬件SPI的话好像也不用配置时序的吧
淡漠安然| | 2024-3-21 18:00 | 只看该作者
建议使用逻辑分析仪看看时序,看看数据都对不对
暖了夏天蓝了海| | 2024-3-21 20:00 | 只看该作者
你用啥检测的,查不到电压?
江河千里| | 2024-3-21 22:00 | 只看该作者
我觉得没有输出电压可以看看硬件接的都对不对,看看还有啥没有配置的
冰春彩落下| | 2024-3-22 01:00 | 只看该作者
有没有可能DAC变化太快了,用万用表测不出来?
别乱了阵脚| | 2024-3-22 05:00 | 只看该作者
一般DAC很容易弄得啊,而且STM32本身就带有DAC的功能吧
一秒落纱| | 2024-3-22 11:00 | 只看该作者
仿真看看,看程序都进中断了没有
