[技术问答]
ML51系列的I2C库函数怎么没有读写操作
579|1
jiekou001|  楼主 | 2024-2-6 17:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void I2C_Open(unsigned char u8I2CSel, unsigned long u32SYSCLK, unsigned long u32I2CCLK);
void I2C_Close(unsigned char u8I2CSel);
void I2C_EnableInt(unsigned char u8I2CSel);
void I2C_DisableInt(unsigned char u8I2CSel);
unsigned char I2C_GetStatus(unsigned char u8I2CSel);
void I2C_SetSlaveAddrMask(unsigned char u8I2CSel, unsigned char u8SlaveNo, unsigned char u8SlaveAddrMask);
void I2C_EnableTimeout(unsigned char u8I2CSel);
void I2C_DisableTimeout(unsigned char u8I2CSel);
void I2C_ClearTimeoutFlag(unsigned char u8I2CSel);
void I2C_SLAVE_ADDRESS_MASK_ENABLE(unsigned char u8I2CSel, unsigned char u8I2CAddMaskBit);
void I2C_SLAVE_ADDRESS_MASK_DISABLE(unsigned char u8I2CSel, unsigned char u8I2CAddMaskBit);
只有这些函数,另外没看到有I2C的示例。
jasontu| | 2024-2-7 09:26 | 只看该作者
bsp中有i2c 读写的例程。
