[DemoCode下载]
M031使用PWM控制LED
366|6
wahahaheihei|  楼主 | 2024-2-19 20:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 10 $
* $Date: 18/07/17 6:05p $
* @brief
*           Change duty cycle of output waveform to show different brightness of
                         Red LED.
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
/* Macro, type and constant definitions        */
/* Global variables        */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable PWM1 module clock */
    CLK_EnableModuleClock(PWM1_MODULE);
    /* PWM clock frequency configuration        */
    /* Set PLL clock as 96 MHz from HIRC/4 */
    CLK_EnablePLL(CLK_PLLCTL_PLLSRC_HIRC_DIV4, 96000000);
    /* Waiting for PLL clock ready */
    CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
    /* Select HCLK clock source as PLL and and HCLK clock divider as 2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(2));
    /* PWM clock frequency can be set equal or double to HCLK by choosing case 1 or case 2 */
    /* case 1.PWM clock frequency is set equal to HCLK: select PWM module clock source as PCLK */
//    CLK_SetModuleClock(PWM1_MODULE, CLK_CLKSEL2_PWM1SEL_PCLK0, 0);
    /* case 2.PWM clock frequency is set double to HCLK: select PWM module clock source as PLL */
    CLK_SetModuleClock(PWM1_MODULE, CLK_CLKSEL2_PWM1SEL_PLL, NULL);
    /* Reset PWM1 module */
    SYS_ResetModule(PWM1_RST);
    /* Update System Core Clock */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PC.4 multi-function pins for PWM1 Channel 1 for Red of LED */
    SYS->GPC_MFPL = (SYS->GPC_MFPL & (~SYS_GPC_MFPL_PC4MFP_Msk)) |
                    SYS_GPC_MFPL_PC4MFP_PWM1_CH1;
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Set frequency and duty of PWM1 Channel 1 to control Red LED */
    PWM_ConfigOutputChannel(PWM1, 1, 1, 50);
    /* Enable PWM1 Output path for channel 1 */
    PWM_EnableOutput(PWM1, BIT1);
    /* Start PWM1 Counter */
    PWM_Start(PWM1, BIT1);
    while(1);
wahahaheihei|  楼主 | 2024-2-19 20:36 | 只看该作者
官方的BSP库写的非常棒,配置通道,频率,占空比,然后使能输出。
真好用。
wahahaheihei|  楼主 | 2024-2-19 20:37 | 只看该作者
PWM_ConfigOutputChannel(PWM_T *pwm, uint32_t u32ChannelNum, uint32_t u32Frequency, uint32_t u32DutyCycle);
yangxiaor520| | 2024-2-19 20:42 | 只看该作者
PWM可以实现呼吸灯效果
wahahaheihei|  楼主 | 2024-2-19 20:55 | 只看该作者
yangxiaor520 发表于 2024-2-19 20:42
PWM可以实现呼吸灯效果
这是实现跑马灯,周期只有1Hz
捉虫天师| | 2024-2-27 22:20 | 只看该作者
另类的闪灯方法。
xixi2017| | 2024-2-28 11:03 | 只看该作者
PWM太重要了,驱动很多东西可以用。
