[DemoCode下载]
ML51系列LCD操作示例
421|3
xinxianshi|  楼主 | 2024-2-20 10:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* SPDX-License-Identifier: Apache-2.0        */
/* Copyright(c) 2020 Nuvoton Technology Corp. All rights reserved.                                         */
//  File Function: ML51 GPIO toggle demo code
#include "ml51_iar.h"
void LCD_IO_Init(void)
/* Enable COM pin MFP */
    MFP_P25_LCD_COM0;
    MFP_P24_LCD_COM1;
    MFP_P23_LCD_COM2;
    MFP_P22_LCD_COM3;
    MFP_P45_LCD_COM4;
    MFP_P44_LCD_COM5;
    MFP_P43_LCD_COM6;
    MFP_P42_LCD_COM7;
/* Enable SEG pin MFP */
    MFP_P41_LCD_SEG27;
    MFP_P40_LCD_SEG26;
    MFP_P63_LCD_SEG25;
    MFP_P62_LCD_SEG24;
    MFP_P61_LCD_SEG23;
    MFP_P60_LCD_SEG22;
    MFP_P14_LCD_SEG21;
    MFP_P15_LCD_SEG20;
    MFP_P16_LCD_SEG19;
    MFP_P17_LCD_SEG18;
    MFP_P46_LCD_SEG17;
    MFP_P47_LCD_SEG16;
    MFP_P33_LCD_SEG15;
    MFP_P32_LCD_SEG14;
    MFP_P31_LCD_SEG13;
    MFP_P30_LCD_SEG12;
    MFP_P67_LCD_SEG11;
    MFP_P66_LCD_SEG10;
    MFP_P65_LCD_SEG9;
    MFP_P64_LCD_SEG8;
    MFP_P27_LCD_SEG7;
    MFP_P26_LCD_SEG6;
    MFP_P21_LCD_SEG5;
    MFP_P20_LCD_SEG4;
    MFP_P35_LCD_SEG3;
    MFP_P34_LCD_SEG2;
    MFP_P07_LCD_SEG1;
    MFP_P06_LCD_SEG0;
/* Enable DH1 DH2 pin MFP */  /* Only for LCD Charge pump mode */
    MFP_P11_LCD_DH1;
    MFP_P12_LCD_DH2;
void main (void)
/* As defaut all multi function define as GPIO */
  LCD_IO_Init();
  LCD_Clock_Setting(LIRC, LCD_FREQ_DIV2);
  LCD_Open(TYPE_B, Internal_VCP, LCD_CPVOL_4_6V, BIAS_1_4, LCD_8COM);
  LCD_Current_Mode(Buffer_PowerSave_Mode, TurnOn_1_4);
  LCD_Blink(Enable,4);
  LCD_PowerDown_Display(LCD_ON);
  LCD_Enable();
  LCD_SetAllPixels(Enable);
  Timer0_Delay(24000000,4000,1000);
  LCD_SetAllPixels(Disable);
  LCD_SetOnePixel(6,6,Enable);
  Timer0_Delay(24000000,400,1000);
  set_PCON_PD;
  while(1);
通过简单的设置即可使用库函数实现操作,非常方便
xinxianshi|  楼主 | 2024-2-20 10:36 | 只看该作者
还支持开源的SDCC编译器
#include "ml51_sdcc.h"
    MFP_P25_LCD_COM0;
    MFP_P24_LCD_COM1;
    MFP_P23_LCD_COM2;
    MFP_P22_LCD_COM3;
    MFP_P45_LCD_COM4;
    MFP_P44_LCD_COM5;
    MFP_P43_LCD_COM6;
    MFP_P42_LCD_COM7;
    MFP_P41_LCD_SEG27;
    MFP_P40_LCD_SEG26;
    MFP_P63_LCD_SEG25;
    MFP_P62_LCD_SEG24;
    MFP_P61_LCD_SEG23;
    MFP_P60_LCD_SEG22;
    MFP_P14_LCD_SEG21;
    MFP_P15_LCD_SEG20;
    MFP_P16_LCD_SEG19;
    MFP_P17_LCD_SEG18;
    MFP_P46_LCD_SEG17;
    MFP_P47_LCD_SEG16;
    MFP_P33_LCD_SEG15;
    MFP_P32_LCD_SEG14;
    MFP_P31_LCD_SEG13;
    MFP_P30_LCD_SEG12;
    MFP_P67_LCD_SEG11;
    MFP_P66_LCD_SEG10;
    MFP_P65_LCD_SEG9;
    MFP_P64_LCD_SEG8;
    MFP_P27_LCD_SEG7;
    MFP_P26_LCD_SEG6;
    MFP_P21_LCD_SEG5;
    MFP_P20_LCD_SEG4;
    MFP_P35_LCD_SEG3;
    MFP_P34_LCD_SEG2;
    MFP_P07_LCD_SEG1;
    MFP_P06_LCD_SEG0;
    MFP_P11_LCD_DH1;
    MFP_P12_LCD_DH2;
void main (void)
  LCD_IO_Init();
  LCD_Enable();
  set_PCON_PD;
  while(1);
wanduzi| | 2024-2-28 18:49 | 只看该作者
这个看着有点难懂,都是指令操作,而不是韩硕操作。
