[DemoCode下载]
NUC131在Arduino下的Button操作
189|2
稳稳の幸福|  楼主 | 2024-2-28 10:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  Button
Turns on and off a light emitting diode(LED) connected to digital
LED1 is light, when pressing a pushbutton attached to SW1. It work for NuEdu-NUC240, NuEdu-NANO130 and NuEdu-M451.
LED3 is light, when pressing a pushbutton attached to SW2. It work for NuEdu-NUC240, NuEdu-NANO130 and NuEdu-M451.
LED5 is light, when pressing a pushbutton attached to SW3. It work for NuEdu-NUC240, NuEdu-NANO130 and NuEdu-M451.
LED7 is light, when pressing a pushbutton attached to SW4. It work for NuEdu-NUC240, NuEdu-NANO130 and NuEdu-M451.
Note: This sample does not support NuEdu-NUC131.
This example code is in the public domain.
// constants won't change. They're used here to
// set pin numbers:
#define NUM 4
const int buttonPin[NUM] = {44, 39, 24, 25 };     // the number of the pushbutton pin,  SW1, SW2, SW3, SW4
const int ledPin[NUM]    = {34, 36, 38, 27 };     // the number of the LED pin, LED1, LED3, LED5, LED7
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
void setup() {
  // initialize the LED pin as an output:
  for(int i=0;i<NUM;i++)
   pinMode(ledPin[i], OUTPUT);
  // initialize the pushbutton pin as an input:
    pinMode(buttonPin[i], INPUT);
void loop(){
  // read the state of the pushbutton value:
      buttonState = digitalRead(buttonPin[i]);
      // check if the pushbutton is pressed.
      // if it is, the buttonState is HIGH:
      if (buttonState == HIGH) {
        // turn LED on:
        digitalWrite(ledPin[i], HIGH);
      else {
        // turn LED off:
        digitalWrite(ledPin[i], LOW);
对比KEIL下的开发,这个怎么样?
xixi2017| | 2024-2-28 10:52 | 只看该作者
按键操作确实很方便了。
天灵灵地灵灵| | 2024-2-28 15:04 | 只看该作者
发现用这个开发板,会提高移植性,因为代码是一致的。
