[PIC®/AVR®/dsPIC®产品]
PIC16F单片机与时钟源相关的配置字
245|1
gejigeji521|  楼主 | 2024-3-11 22:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//Oscillator Selection bits
FOSC = XT_XT            XT oscillator, XT used by USB
FOSC = XTPLL_XT         XT oscillator, PLL enabled, XT used by USB
FOSC = ECIO_EC          External clock, port function on RA6, EC used by USB
FOSC = EC_EC            External clock, CLKOUT on RA6, EC used by USB
FOSC = ECPLLIO_EC       External clock, PLL enabled, port function on RA6, EC used by USB
FOSC = ECPLL_EC         External clock, PLL enabled, CLKOUT on RA6, EC used by USB
FOSC = INTOSCIO_EC      Internal oscillator, port function on RA6, EC used by USB
FOSC = INTOSC_EC        Internal oscillator, CLKOUT on RA6, EC used by USB
FOSC = INTOSC_XT        Internal oscillator, XT used by USB
FOSC = INTOSC_HS        Internal oscillator, HS used by USB
FOSC = HS               HS oscillator, HS used by USB
FOSC = HSPLL_HS         HS oscillator, PLL enabled, HS used by USB
#pragma config  FOSC    =   HSPLL_HS
这下知道配置字的关键字是什么了吧。
