[STM32F1]
stm32f103rb驱动max7219点阵无反应,代码如下
96|7
慢醇|  楼主 | 2024-4-11 06:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
**spi.c**
#include "bsp_spi_dot_matrix_led.h"
#include "bsp_usart.h"
  * [url=home.php?mod=space&uid=247401]@brief[/url]  SPI_FLASH初始化
  * @param  无
  * @retval 无
void SPI_DOT_LED_Init(void)
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE);
  /* 配置SPI的 CS引脚,普通IO即可 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
     /* 配置SPI的 CLK引脚,普通IO即可 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
     /* 配置SPI的 DIN引脚,普通IO即可 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
////功能:向MAX7219写入数据
////入口参数:address、dat
////出口参数:无
////说明:
//功能:向MAX7219(U3)写入字节
//入口参数:DATA
//出口参数:无
//说明:
void Write_Max7219_byte(uchar DATA)
            uchar i,w;
        Max7219_pinCS_LOW();
        for(i=8;i>=1;i--)
            Max7219_pinCLK_LOW();
                        w=DATA&0x80;
                        w=DATA>>7;
                      Max7219_pinDIN(w);
                        printf(" %d \n",w);
                DATA=DATA<<1;//八位的data从高到底把数据以此发送给Max7219_pinDIN
            Max7219_pinCLK_HIGH();
void Write_Max7219(uchar address,uchar dat)
       Write_Max7219_byte(address);           //写入地址,即数码管编号
     Write_Max7219_byte(dat);               //写入数据,即数码管显示数字
       Max7219_pinCS_HIGH();
void Init_MAX7219(void)
Write_Max7219(0x09, 0x00);       //译码方式:BCD码
Write_Max7219(0x0a, 0x03);       //亮度
Write_Max7219(0x0b, 0x07);       //扫描界限;8个数码管显示
Write_Max7219(0x0c, 0x01);       //掉电模式:0,普通模式:1
Write_Max7219(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
/*********************************************END OF FILE**********************/
main.c
#include "stm32f10x.h"
#include "bsp_SysTick.h"
/* disp1为需要显示字库*/ //其他字可以去网上下载  取模软件
uchar disp1[38][8]={
{0xB4,0x4A,0x8A,0xBE,0x4A,0x4A,0x41,0xFF},/*"迅",0*/
{0x40,0x88,0x7E,0x48,0x4C,0x52,0x7F,0x0},/*"达",0*/
{0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
{0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
{0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
{0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
{0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
{0x10,0x5B,0x24,0x24,0x28,0x18,0x18,0x24},/*"文",0*/
{0x00,0x7E,0x10,0x2C,0x24,0x3C,0x24,0x3C},/*"百",0*/
//{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
//{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
//{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
//{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
//{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
//{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
//{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
//{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
//{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
{0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
{0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
{0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
{0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
{0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
{0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
{0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
{0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
{0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
{0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
{0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
{0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
{0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
{0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
{0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
{0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
{0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
{0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
{0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//中
{0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//国
int main(void)
    SysTick_Init();//始终初始化
    SPI_DOT_LED_Init();//初始化传输用的GPIO
    Init_MAX7219();//初始化MAX7219
    while(1)
     uchar i,j;
   for(j=0;j<38;j++)
   for(i=1;i<9;i++)
    Write_Max7219(i,disp1[j][i-1]);
    SysTick_Delay_Ms( 1000);
laocuo1142| | 2024-4-11 09:11 | 只看该作者
STM32F103RB与MAX7219之间的连接是否有误,包括SPI接口、电源和地线。
flycamelaaa| | 2024-4-11 10:00 | 只看该作者
STM32F103RB的SPI接口是否已经正确初始化
powerantone| | 2024-4-11 10:45 | 只看该作者
检查MAX7219的初始化序列是否正确,包括设置亮度、扫描方式等。
stormwind123| | 2024-4-11 11:30 | 只看该作者
驱动代码问题
probedog| | 2024-4-11 12:59 | 只看该作者
可能是电源问题
两只袜子| | 2024-4-11 14:00 | 只看该作者
寄存器的值是否正确设置
jcky001| | 2024-4-11 15:00 | 只看该作者
尝试更换一个MAX7219芯片
