[PIC®/AVR®/dsPIC®产品]
比例积分微分(PID)控制器和闭环控制
470|6
huahuagg|  楼主 | 2024-4-14 22:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CE019_PID.zip (13.33 KB)
* � 2005 Microchip Technology Inc.
* FileName:        main.c
* Dependencies:    Header (.h) files if applicable, see below
* Processor:       dsPIC30Fxxxx
* Compiler:        MPLAB� C30 v3.00 or higher
* IDE:             MPLAB� IDE v7.52 or later
* Dev. Board Used: dsPICDEM 1.1 Development Board
* Hardware Dependencies: None
* SOFTWARE LICENSE AGREEMENT:
* Microchip Technology Incorporated ("Microchip") retains all ownership and
* intellectual property rights in the code accompanying this message and in all
* derivatives hereto.  You may use this code, and any derivatives created by
* any person or entity by or on your behalf, exclusively with Microchip,s
* proprietary products.  Your acceptance and/or use of this code constitutes
* agreement to the terms and conditions of this notice.
* CODE ACCOMPANYING THIS MESSAGE IS SUPPLIED BY MICROCHIP "AS IS".  NO
* WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
* TO, IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE APPLY TO THIS CODE, ITS INTERACTION WITH MICROCHIP,S
* PRODUCTS, COMBINATION WITH ANY OTHER PRODUCTS, OR USE IN ANY APPLICATION.
* YOU ACKNOWLEDGE AND AGREE THAT, IN NO EVENT, SHALL MICROCHIP BE LIABLE, WHETHER
* IN CONTRACT, WARRANTY, TORT (INCLUDING NEGLIGENCE OR BREACH OF STATUTORY DUTY),
* STRICT LIABILITY, INDEMNITY, CONTRIBUTION, OR OTHERWISE, FOR ANY INDIRECT, SPECIAL,
* PUNITIVE, EXEMPLARY, INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, FOR COST OR EXPENSE OF
* ANY KIND WHATSOEVER RELATED TO THE CODE, HOWSOEVER CAUSED, EVEN IF MICROCHIP HAS BEEN
* ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE.  TO THE FULLEST EXTENT
* ALLOWABLE BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN ANY WAY RELATED TO
* THIS CODE, SHALL NOT EXCEED THE PRICE YOU PAID DIRECTLY TO MICROCHIP SPECIFICALLY TO
* HAVE THIS CODE DEVELOPED.
* You agree that you are solely responsible for testing the code and
* determining its suitability.  Microchip has no obligation to modify, test,
* certify, or support the code.
* REVISION HISTORY:
* Author            Date      Comments on this revision
* HV/SB             11/15/05  First release of source file
* ADDITIONAL NOTES:
#include <dsp.h>
Variable Declaration required for each PID controller in your application
/* Declare a PID Data Structure named, fooPID */
tPID fooPID;
/* The fooPID data structure contains a pointer to derived coefficients in X-space and */
/* pointer to controler state (history) samples in Y-space. So declare variables for the */
/* derived coefficients and the controller history samples */
fractional abcCoefficient[3] __attribute__ ((section (".xbss, bss, xmemory")));
fractional controlHistory[3] __attribute__ ((section (".ybss, bss, ymemory")));
/* The abcCoefficients referenced by the fooPID data structure */
/* are derived from the gain coefficients, Kp, Ki and Kd */
/* So, declare Kp, Ki and Kd in an array */
fractional kCoeffs[] = {0,0,0};
Main function demonstrating the use of PID(), PIDInit() and PIDCoeffCalc()
functions from DSP library in MPLAB C30 v3.00 and higher
int main (void)
Step 1: Initialize the PID data structure, fooPID
        fooPID.abcCoefficients = &abcCoefficient[0];    /*Set up pointer to derived coefficients */
        fooPID.controlHistory = &controlHistory[0];     /*Set up pointer to controller history samples */
        PIDInit(&fooPID);                               /*Clear the controler history and the controller output */
        kCoeffs[0] = Q15(0.7);
        kCoeffs[1] = Q15(0.2);
        kCoeffs[2] = Q15(0.07);
        PIDCoeffCalc(&kCoeffs[0], &fooPID);             /*Derive the a,b, & c coefficients from the Kp, Ki & Kd */
Step 2: Use the PID Controller
        fooPID.controlReference = Q15(0.74) ;           /*Set the Reference Input for your controller */
        fooPID.measuredOutput = Q15(0.453) ;            /*Typically the measuredOutput variable is a plant response*/
                                                        /*measured from an A/D input or a sensor. */
                                                        /*In this example we manually set it to some value for */
                                                        /*demonstration but the user should note that this value will */
                                                        /*keep changing in a real application*/
        while (1)                                       /*We use a while(1) loop here for demonstration purposes.*/
        {                                               /*Typically, the PID calculation may be triggered off a timer*/
                                                        /*or A/D interrupt */
                PID(&fooPID);                           /*Call the PID controller using the new measured input */
                                                        /*The user may place a breakpoint on "PID(&fooPID)", halt the debugger,*/
                                                        /*tweak the measuredOutput variable within the watch window */
                                                        /*and then run the debugger again */
zhuomuniao110| | 2024-4-15 21:48 | 只看该作者
这个系列自带的有DSP库函数吧。
呐咯密密| | 2024-4-17 20:48 | 只看该作者
就一个函数吗
yiy| | 2024-4-17 23:28 | 只看该作者
库函数呢,想看。
稳稳の幸福| | 2024-4-23 23:19 | 只看该作者
头文件在哪儿下载呢?
幸福小强| | 2024-4-26 22:43 | 只看该作者
利用DSP库做是容易很多。
yangxiaor520| | 2024-4-27 12:10 | 只看该作者
PID难就难在参数的调整优化
