[MM32软件]
c语言几大基本算法
295|1
mmbs|  楼主 | 2024-4-24 18:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
// 冒泡排序
void bubbleSort(int arr[], int n) {
    int i, j, temp;
    for (i = 0; i < n - 1; i++)
        for (j = 0; j < n - i - 1; j++)
            if (arr[j] > arr[j + 1]) {
                temp = arr[j];
                arr[j] = arr[j + 1];
                arr[j + 1] = temp;
// 选择排序
void selectionSort(int arr[], int n) {
    int i, j, min_idx;
    for (i = 0; i < n - 1; i++) {
        min_idx = i;
        for (j = i + 1; j < n; j++)
            if (arr[j] < arr[min_idx])
                min_idx = j;
        swap(&arr[min_idx], &arr[i]);
// 插入排序
void insertionSort(int arr[], int n) {
    int i, j, key;
    for (i = 1; i < n; i++) {
        key = arr[i];
        j = i - 1;
        while (j >= 0 && arr[j] > key) {
            arr[j + 1] = arr[j];
            j = j - 1;
        arr[j + 1] = key;
// 快速排序
int partition (int arr[], int low, int high) {
    int pivot = arr[high];
    int i = (low - 1);
    for (j = low; j <= high - 1; j++) {
        if (arr[j] < pivot) {
            i++;
            swap(&arr[i], &arr[j]);
    swap(&arr[i + 1], &arr[high]);
    return (i + 1);
void quickSort(int arr[], int low, int high) {
    if (low < high) {
        int pi = partition(arr, low, high);
        quickSort(arr, low, pi - 1);
        quickSort(arr, pi + 1, high);
// 归并排序
void merge(int arr[], int l, int m, int r) {
    int i, j, k;
    int n1 = m - l + 1;
    int n2 = r - m;
    int L[n1], R[n2];
    for (i = 0; i < n1; i++)
        L[i] = arr[l + i];
    for (j = 0; j < n2; j++)
        R[j] = arr[m + 1 + j];
    i = 0;
    j = 0;
    k = l;
    while (i < n1 && j < n2) {
        if (L[i] <= R[j]) {
            arr[k] = L[i];
            i++;
        else {
            arr[k] = R[j];
            j++;
        k++;
    while (i < n1) {
        arr[k] = L[i];
        i++;
        k++;
    while (j < n2) {
        arr[k] = R[j];
        j++;
        k++;
void mergeSort(int arr[], int l, int r) {
    if (l < r) {
        int m = l + (r - l) / 2;
        mergeSort(arr, l, m);
lidi911| | 2024-4-24 23:50 | 只看该作者
这不就是C语言10大常用算法之一吗
