[PSoC™]
PSOC4000T Debug报错
241|6
CY8CPROTO-040T开发板,采用MTB开发环境,例程采用如下截图的方式生成,Debug时会报如下错误,请帮忙看看,谢谢。
Started by GNU MCU Eclipse
Open On-Chip Debugger 0.12.0+dev-5.0.0.2401 (2023-05-16-04:28)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
adapter speed: 2000 kHz
** Auto-acquire enabled, use "set PSOC4_USE_ACQUIRE 0" to disable
cortex_m reset_config sysresetreq
Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf155, serial=1C09187D031C2400
Info : CMSIS-DAP: SWD supported
Info : CMSIS-DAP: Atomic commands supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 2.50.1383
Info : KitProg3: Pipelined transfers enabled
Info : KitProg3: Asynchronous USB transfers enabled
Info : VTarget = 4.708 V
Info : kitprog3: acquiring the device (mode: reset)...
Info : clock speed 2000 kHz
Info : SWD DPIDR 0x0bc11477
Info : [psoc4.cpu] Cortex-M0+ r0p1 processor detected
Info : [psoc4.cpu] target has 4 breakpoints, 2 watchpoints
** Silicon: 0x3612, Family: 0xC6, Rev.: 0x22 (B1)
** Detected Family: PSoC4A-SF2
** Detected Device: CY8C4046LQI-T452
** Detected Main Flash size, kb: 64
** Chip Protection: OPEN
Info : gdb port disabled
Info : starting gdb server for psoc4.cpu on 3333
Info : Listening on port 3333 for gdb connections
Error: Error connecting DP: cannot read IDR
Error: [psoc4.cpu] DP initialisation failed
[psoc4.cpu] halted due to debug-request, current mode: Thread
xPSR: 0xa1000000 pc: 0x10000040 msp: 0x20001fe8
** Device acquired successfully
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : accepting 'gdb' connection on tcp/3333
Info : New GDB Connection: 1, Target psoc4.cpu, state: halted
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
Error: Failed to read memory at 0x10000040
semihosting is enabled
Warn : No RTOS could be auto-detected!
Verifying region (0x00000000,     24684)... Match
Info : All data matches, Flash programming skipped
xPSR: 0xa1000000 pc: 0x10000040 msp: 0x20001fe8, semihosting
Info : psoc4.cpu: bkpt @0x0000039D, issuing SYSRESETREQ
xPSR: 0x61000000 pc: 0x0000039c msp: 0x20002000, semihosting
===== arm v7m registers
(0) r0 (/32): 0x40100004
(1) r1 (/32): 0x0000039d
(2) r2 (/32): 0x00000000
(3) r3 (/32): 0x00000000
(4) r4 (/32): 0x20002000
(5) r5 (/32): 0x08000000
(6) r6 (/32): 0x0ffff060
(7) r7 (/32): 0x00000000
(8) r8 (/32): 0x30006000
(9) r9 (/32): 0x01280049
(10) r10 (/32): 0x1fff2000
(11) r11 (/32): 0x00000000
(12) r12 (/32): 0x00000002
(13) sp (/32): 0x20002000
(14) lr (/32): 0x1000012d
(15) pc (/32): 0x0000039c
(16) xpsr (/32): 0x61000000
(17) msp (/32): 0x20002000
(18) psp (/32): 0x1a06280c
(20) primask (/1): 0x00
(21) basepri (/8): 0x00
(22) faultmask (/1): 0x00
(23) control (/3): 0x00
===== Cortex-M DWT registers
Warn : target psoc4.cpu is not halted (gdb fileio)
Polling target psoc4.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Error: Failed to read memory and, additionally, failed to find out where
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Examination failed, GDB will be halted. Polling again in 1500ms
Examination failed, GDB will be halted. Polling again in 3100ms
Examination failed, GDB will be halted. Polling again in 6300ms
IFXJone 2024-5-17 14:13 回复TA
请尝试参考以下链接试试看呢:https://community.infineon.com/t5/AIROC-Bluetooth/Error-DAP-CYW20820A1-cpu-initialization-failed-check-connection-power-transport/td-p/381126
classroom| | 2024-5-20 17:18 | 只看该作者
检查硬件连接是否有误
laocuo1142| | 2024-5-20 18:00 | 只看该作者
更新IDE至最新版本
flycamelaaa| | 2024-5-21 17:00 | 只看该作者
检查时钟设置、引脚分配等是否正确。
IFX-LeiSUN| | 2024-5-21 18:23 | 只看该作者
请问debug的是哪个code example?
我记得有些代码默认没有打开debug功能。需要确认一下Device Configurator里面,Debug功能是否打开,是否分配了正确的debug pin脚。
小小蚂蚁举千斤| | 2024-5-31 16:44 | 只看该作者
报错是跟软件配置以及下载相关
