[DemoCode下载]
时钟由IO输出的方法,实现定时器触发IO翻转
717|1
小灵通2018|  楼主 | 2024-5-19 19:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate the timer 0 toggle out function on TM0 pin.
* SPDX-License-Identifier: Apache-2.0
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2020 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable IP clock */
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_PCLK0, 0);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function                                              */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Set timer toggle out pin */
    SYS->GPB_MFPL = (SYS->GPB_MFPL & ~(SYS_GPB_MFPL_PB5MFP_Msk)) |
                    (SYS_GPB_MFPL_PB5MFP_TM0);
    /* Lock protected registers */
    SYS_LockReg();
/* Init UART0                                                           */
void UART0_Init(void)
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
int main(void)
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\nThis sample code use timer 0 to generate 500Hz toggle output to PB.5\n");
    /* To generate 500HZ toggle output, timer frequency must set to 1000Hz.
       Because toggle output state change on every timer timeout event */
    TIMER_Open(TIMER0, TIMER_TOGGLE_MODE, 1000);
    TIMER_SELECT_TOUT_PIN(TIMER0, TIMER_TOUT_PIN_FROM_TMX);
    TIMER_Start(TIMER0);
    while(1);
小灵通2018|  楼主 | 2024-5-19 19:38 | 只看该作者
这个方法有个好处,就是配置好,不需要CPU干扰,就会自动实现时钟信号输出,可以用于外部需要时钟信号的情况。用于给外设提供时钟信号。
