PSOC1 的加密
3178|11
huwr|  楼主 | 2012-11-13 19:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我有个样机给客户试用,但是我担心里面的内容会很容易读出来,请问各位是不是有什么加密设置的
我用PSOC MiniProg 和 PSOC Programmer 3.12 灌程序的。
huanghuac| | 2012-11-13 19:37 | 只看该作者
PSoC Designer 中project file里有一个flashsecurity.txt文件
huwr|  楼主 | 2012-11-13 19:39 | 只看该作者
都能设置哪些保护级别?
huanghuac| | 2012-11-13 19:41 | 只看该作者
Unprotected
Factory upgrade
Field upgrade
Full protection
huwr|  楼主 | 2012-11-13 19:43 | 只看该作者
不懂,如何设置?
Unprotected
Factory upgrade
Field upgrade
Full protection
分别是什么功能?
; @Id: flashsecurity.txt#2 @
; Edit this file to adjust the Flash security for this project.
; Flash security is provided by marking a 64 byte block with a character
; that corresponds to the type of security for that block, given:
; W: Full (Write protected)
; R: Field Upgrade (Read protected)
; U: Unprotected
; F: Factory
; Note #1: Protection characters can be entered in upper or lower case.
; Note #2: Refer to the Flash Program Memory Protection section in the Data Sheet.
; Comments may be added similar to an assembly language comment, by
; Using the semicolon (;) followed by your comment.  The comment extends
; to the end of the line.
; 0 40 80 C0 100 140 180 1C0 200 240 280 2C0 300 340 380 3C0 (+) Base Address
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 0
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 400
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 800
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address C00
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 1000
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 1400
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 1800
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 1C00
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 2000
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 2400
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 2800
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 2C00
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 3000
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 3400
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 3800
  W  W  W  W  W   W   W   W   W   W   W   W   W   W   W   W ;    Base Address 3C00
; End 16K parts
; Copyright (c) Cypress Semiconductor 2009. All Rights Reserved.
huanghuac| | 2012-11-13 19:45 | 只看该作者
你现在是W,就是 Full (Write protected)
huwr|  楼主 | 2012-11-13 19:47 | 只看该作者
如果允许重新多次灌程序,但不能让其他人读出我的代码,我该设置成那种呢?
huanghuac| | 2012-11-13 19:55 | 只看该作者
除了U以外,其他都不能外部读
R可以内部写,F可以内部和外部写
huwr|  楼主 | 2012-11-13 19:57 | 只看该作者
哦,懂了,多谢你啊
可惜只有20分,呵呵
Go_PSoC| | 2012-11-13 22:56 | 只看该作者
相信大家是不会太在意分数的:)
