赛普拉斯 PSoC Designer 中文用户模块数据手册集锦
楼主: Go_PSoC
建议传些基础资料
Go_PSoC|  楼主 | 2013-2-20 17:08 | 只看该作者
shibalihuandao 发表于 2013-2-19 23:21
建议传些基础资料
比方说呢?
Go_PSoC|  楼主 | 2013-2-20 17:38 | 只看该作者
小苑 发表于 2013-2-17 16:24
可以上传些更基础的吗?比方说引脚,isr,LCD_CHAR等等,嘿嘿,不好意思啊 我是新手 ...
LCD_CHAR找到了,争取明天上传
someontime| | 2013-2-20 21:11 | 只看该作者
楼主加油 顶一个
specialfrin| | 2013-2-20 21:18 | 只看该作者
好给力 期待版主再接再厉
justbybing| | 2013-2-20 21:37 | 只看该作者
搜集这些资料真是一个大工程 太感谢你了
someonewho| | 2013-2-20 21:45 | 只看该作者
顶一下 加油
waitingf| | 2013-2-20 22:09 | 只看该作者
强烈支持 顶你
Go_PSoC|  楼主 | 2013-2-21 14:48 | 只看该作者
一些新的,先把网址贴上来
I2C  MASTER DATASHEET, I2CM V 1.4 (CY8C29/27/24/22/21XXX, CY7C603XX, CY7C64215,  CYWUSB6953, CY8C23X33, CY8CLED0XD, CY8CLED0XG, CY8CLED02/04/08/16,  CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120, CY8CTMA120, CY8C21X45,  CY8C22X45, CY8C28X45, CY8CPLC20, CY8CLED16P01, CY8C28XXX, CY8C21X12)
CHARACTER LCD DATASHEET, LCD V 1.60  (CY8C29/27/26/25/24/22/21XXX, CY8C23X33, CY7C603XX/64215, CYWUSB6953,  CY8C20X34, CY8CLED02/04/08/16, CY8C21X45, CY8C22X45, CY8C28X45, CY8CPLC20,  CY8CLED16P01, CY8C28XXX, CY8C21X12)http://www1.cypress.com/?rID=3043
LED DATASHEET, LED V 1.40 (ALL PSOC DEVICES)
http://www1.cypress.com/?rid=3058
7-SEGMENT LED CONTROLLER DATASHEET, LED7SEG V 1.20  (CY8C29/27/24/22/21XXX, CY8C23X33, CY8C28XXX, CY8CLED02/04/08/16, CY7C64215,  CY8CPLC20, CY8CLED16P01, CYWUSB6953)http://www1.cypress.com/?rID=3063
24-BIT TIMER DATASHEET, TIMER24 V 2.6 (CY8C29/27/24/22/21XXX,  CY8C23X33, CYWUSB6953, CY7C64215, CY8CLED02/04/08/16, CY8CLED0XD, CY8CLED0XG,  CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120, CY8CTMA120, CY8CTMA140,  CY8C21X45, CY8CTMA30XX, CY8C28X45, CY8CPLC20, CY8CLED16P01, CY8C28XXX)http://www1.cypress.com/?rID=3102
32-BIT TIMER DATASHEET, TIMER32 V 2.6 (CY8C29/27/24/22/21XXX,  CY8C23X33, CYWUSB6953, CY7C64215, CY8CLED02/04/08/16, CY8CLED0XD, CY8CLED0XG,  CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120, CY8CTMA120, CY8CTMA140,  CY8C21X45, CY8CTMA30XX, CY8C28X45, CY8CPLC20, CY8CLED16P01, CY8C28XXX)http://www1.cypress.com/?rID=3103
8-BIT TIMER DATASHEET, TIMER8 V 2.70 (CY8C29/27/24/22/21XXX,  CY8C23X33, CYWUSB6953, CY7C64215, CY8CLED02/04/08/16, CY8CLED0XD, CY8CLED0XG,  CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120, CY8CTMA120, CY8CTMA140,  CY8C21X45, CY8CTMA30XX, CY8C28X45, CY8CPLC20, CY8CLED16P01, CY8C28XXX,  CY8C21X12)http://www1.cypress.com/?rID=3100
COMPARATOR DATASHEET, COMP V 2.10 (CY8C28X45, CY8C28X52,  CY8C28X33, CY8C28X43,CY8C28X23, CY8C29X66,CY8C27X43, CY8C24X94,CY8C24X23A,  CY8C24X33, CY8C23X33, CY8CLED0XD, CY8CLED0XG, CY8CLED04/08/16,  CY8CTST/TMG/TMA120)
24-BIT COUNTER DATASHEET, COUNTER24 V 2.5  (CY8C29/27/24/22/21XXX, CY8C23X33, CYWUSB6953, CY7C64215, CY8CLED02/04/08/16,  CY8CLED0XD, CY8CLED0XG, CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120,  CY8CTMA120, CY8CTMA140, CY8C21X45, CY8C22X45, CY8CTMA30XX, CY8C28X45,  CY8CPLC20, CY8CLED16P01)http://www1.cypress.com/?rID=3131
32-BIT COUNTER DATASHEET, COUNTER32 V 2.5  (CY8C29/27/24/22/21XXX, CY8C23X33, CYWUSB6953, CY7C64215, CY8CLED02/04/08/16,  CY8CLED0XD, CY8CLED0XG, CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120,  CY8CTMA120, CY8CTMA140, CY8C21X45, CY8C22X45, CY8CTMA30XX, CY8C28X45,  CY8CPLC20, CY8CLED16P01)http://www1.cypress.com/?rID=3109
6-BIT VOLTAGE OUTPUT MULTIPLYING DAC DATASHEET, MDAC6 V 2.2  (CY8C29/27/24/22XXX, CY8C23X33, CY8CLED04/08/16, CY8CLED0XD, CY8CLED0XG,  CY8CTST120, CY8CTMG120, CY8CTMA120, CY8C28X45, CY8CPLC20, CY8CLED16P01,  CY8C28X43, CY8C28X52)http://www1.cypress.com/?rID=34614
I2C HARDWARE BLOCK DATASHEET, I2CHW V 1.90  (CY8C29/27/24/22/21XXX, CY8C23X33, CY7C603XX, CY7C64215, CYWUSB6953,  CY8CLED02/04/08/16, CY8CLED0XD, CY8CLED0XG, CY8CTST110, CY8CTMG110,  CY8CTST120, CY8CTMG120, CY8CTMA120, CY8C21X45, CY8C22X45, CY8C28X45, CY8CPLC20,  CY8CLED16P01, CY8C28XXX, CY8C21X12)http://www1.cypress.com/?rID=3030
DIGITAL BUFFERS DATASHEET, DIGBUF V 1.3 (CY8C29/27/24/22/21XXX,  CY8C23X33, CY8CLED02/04/08/16, CY8CLED0XD, CY8CLED0XG, CY8CTST110,  CY8CTMG110, CY8CTST120, CY8CTMG120, CY8CTMA120, CY8CTMA140, CY8C21X45,  CY8C22X45, CY8CTMA30XX, CY8C28X45, CY8CPLC20, CY8CLED16P01, CY8C28XXX)http://www1.cypress.com/?rID=3114
DIGITAL INVERTER DATASHEET, DIGINV V 1.5 (CY8C29/27/24/22/21XXX,  CY8C23X33, CY8CLED02/04/08/16, CY8CLED0XD, CY8CLED0XG, CY8C21X45, CY8C22X45,  CY8CTMA140, CY8CTMA30XX, CY8C28X45, CY8CPLC20, CY8CLED16P01, CY8C28XXX)http://www1.cypress.com/?rID=3113
16-BIT PWM DEAD BAND GENERATOR DATASHEET, PWMDB16 V 2.5  (CY8C29/27/24/22/21XXX, CY8C23X33, CYWUSB6953, CY8CLED02/04/08/16,  CY8CLED0XD, CY8CLED0XG, CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120,  CY8CTMA120, CY8CTMA140, CY8C21X45, CY8C22X45, CY8CTMA30XX, CY8C28X45,  CY8CPLC20, CY8CLED16P01, CY8C28XXX)http://www1.cypress.com/?rID=3080
kwb| | 2013-2-21 18:38 | 只看该作者
楼主 有激情..好
kwb| | 2013-2-21 18:40 | 只看该作者
再回复一个看能不能加分;P
Go_PSoC|  楼主 | 2013-2-22 11:00 | 只看该作者
LCD模块来了
LCD_001-13569.pdf
249.31 KB
评分
参与人数 1威望 +1 收起 理由
小苑 + 1 很给力!
53
Go_PSoC|  楼主 | 2013-2-22 11:26 | 只看该作者
上面那个是英文的,附件上传错了,不过也不用删了,也许有人喜欢看英文呢,呵呵
这次是中文的
LCD_V_1.60_001-84321.pdf
284.05 KB
小苑| | 2013-2-27 16:38 | 只看该作者
不知道可不可以有I2C实例的中文档呢?~~~例如:DelSig_I2CS   Example Project 等等.....在学 I2C 呀~~~
小苑| | 2013-2-27 16:39 | 只看该作者
这次是中文的 ...
:D楼主雄起!
Go_PSoC|  楼主 | 2013-2-27 19:56 | 只看该作者
小苑 发表于 2013-2-27 16:38
不知道可不可以有I2C实例的中文档呢?~~~例如:DelSig_I2CS   Example Project 等等.....在学 I2C 呀~~~[em ...
帮你找找
Go_PSoC|  楼主 | 2013-2-28 13:27 | 只看该作者
http://www.cypress.com/?app=sear ... icationID=0&l=3
CY网站上中文用户模块手册有更新,欢迎下载
Go_PSoC|  楼主 | 2013-2-28 13:31 | 只看该作者
http://china.cypress.com/?rID=3030
I2CHW
I2CHW_V1.90_ZH001-13563.pdf
424.42 KB
Go_PSoC|  楼主 | 2013-2-28 14:47 | 只看该作者
EzI2C Slave
功能和概述
行业标准 Philips I2C 总线兼容接口
仿真通用 I2C EEPROM 接口
只需两个引脚(SDA 和 SCL)来连接 I2C 总线
标准数据速率为 100/400 kbps
高级 API 只需少量用户编程
001-45841_EzI2Cs.pdf
346.94 KB
Go_PSoC|  楼主 | 2013-2-28 14:49 | 只看该作者
I2Cm V 1.4
http://china.cypress.com/?rID=3049
I2CM_001-84320.pdf
284.68 KB
