[STM8]
STM8L单片机(STM8L101)独立看门狗(IWDG)使用注意事项
5417|1
电子云图|  楼主 | 2014-5-18 10:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  最近在用STM8L单片机(STM8L101)做一个低功耗的产品,在调试独立看门狗(IWDG)时,我先用库(V1.2.0)提供的例程进行实验,发现喂不了狗,后来在将IWDG_Enable();函数移到static void IWDG_Config(void)的最前面就OK了,如下图
/*原文件*/
static void IWDG_Config(void){
  /* IWDG timeout equal to 214 ms (the timeout may varies due to LSI frequency
     dispersion) */
  /* Enable write access to IWDG_PR and IWDG_RLR registers */
  IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
  /* IWDG configuration: IWDG is clocked by LSI = 38KHz */
  IWDG_SetPrescaler(IWDG_Prescaler_32);
  /* IWDG timeout equal to 214.7 ms (the timeout may varies due to LSI frequency dispersion) */
  /* IWDG timeout = (RELOAD_VALUE + 1) * Prescaler / LSI
                  = (254 + 1) * 32 / 38 000
                  = 214.7 ms */
  IWDG_SetReload((uint8_t)RELOAD_VALUE);
  /* Reload IWDG counter */
  IWDG_ReloadCounter();
  /* Enable IWDG (the LSI oscillator will be enabled by hardware) */
  IWDG_Enable();
/*更改后*/
  IWDG_Enable();
     dispersion) */
                  = 214.7 ms */
在此发此贴,希望后面的人不要走弯路,同时希望香主把情况反映给STM, 让其更改此BUG.  thanks ---- Happy every day。
mmuuss586| | 2014-5-18 12:25 | 只看该作者
谢谢分享经验
