[Atmel] Atmel Studio 6.2 说明
 楼主| ddllxxrr 发表于 2014-7-3 18:58 | 显示全部楼层 |阅读模式
发个Atmel Studio 6.2 的英文说明:
其实你看下特性就了解的差不多了。
Key Features
关键特性
•Support for 300+ Atmel AVR and SAM3, SAM4 and SAM D20 devices
支持300+ Atmel AVR SAM3,SAM4 SAMD20芯片
•Atmel Software Framework (ASF)
爱特梅尔公司软件框架
•Vast source code library including drivers, communication stacks, graphic services and touch functionality. ASF
enables customers to focus on application differentiation, and accelerates design time.
巨大的源代码库包括司机、通信栈、图形功能服务和联系。ASF   使客户专注于应用差异化和加速设计时间。
•More than 1,600 project examples with source code.
1600多个工程实例源代码。
•ASF Explorer for selecting and integrating ASF components into your own design.
ASF Explorer用于选择和集成ASF组件到您自己的设计。
•Atmel Gallery
Atmel Gallery
•Online apps store for development tools and embedded software from Atmel and third parties.
嵌入式软件开发工具在线应用商店从爱特梅尔公司和第三方提供。
•Easy and secure purchasing process from the Atmel Studio 6 platform.
容易和安全从Atmel Studio 6平台采购流程。
•Atmel QTouch® Composer
爱特梅尔公司QTouch®库
•Seamlessly ties together the tools required to edit the code in Atmel Studio 6 and to tune the touch design, making
it easier than ever to integrate capacitive touch functionality into applications.
无缝联系在一起的工具需要编辑Atmel Studio 6中的代码和优化触摸设计,制作  比以往更容易将电容触摸功能集成到应用程序。
•The validation wizard provides an easy and intuitive way of testing system performance.
验证向导提供了一个简单而直观的方式测试系统的性能。
•With the power analyzer, users can monitor power consumption of the microcontroller in real time.
随着功率分析仪,用户可以实时监控单片机的功耗。
•The real-time data graph and trace graph records data generated during debugging, storing it for later playback.
This allows the user to inspect recorded data sets.
实时数据图和跟踪图记录在调试的过程中生成的数据,存储后回放。  这使得用户检查记录的数据集。
•Wireless Composer 1.0
无线设计 1.0
•Provides a performance test application and contains easy-to-understand displays to configure, command, and monitor
information coming from the performance test application running on the target.
提供了一个性能测试应用程序,包含易于理解的显示配置,命令,并监控信息在目标系统上运行性能测试应用程序。
•Integrated C/C++ compiler
C / c++编译器集成
•Provides one seamless environment with everything the designer needs to write, build, program and debug C/C++ and
assembly code.
为设计师提供了一个无缝的环境,在写,构建、程序和调试C / c++和汇编代码。
•Customers can choose the coding style that best fits their project and generates the most optimal code for their
designs.
客户可以选择最适合他们的项目的编码风格和生成最优的代码设计。
•Advanced debugging features
高级调试功能
•Support for complex data breakpoints
支持复杂的数据断点
•Nonintrusive trace support for SAM3 and SAM4 family of devices, including:
专业不跟踪支持SAM3和SAM4的设备,包括:
•Statistical code profiling
统计代码分析
•Interrupt trace / monitoring
中断跟踪/监控
•Data trace
资料追踪
•Polled Data trace support for ARM Cortex M0+
调查数据跟踪支持ARM Cortex M0 +
•Real-time variable tracking with optional timestamp
实时变量跟踪与可选的时间戳
•Integration of Percepio Tracealyzer technology for providing leading-edge visualization of debug data and RTOS
awareness
 整合Percepio Tracealyzer提供前沿技术的可视化调试数据和操作系统  意识
•Integrated editor with visual assist
综合编辑器与视觉辅助
•Write code faster with visual assist code completion tools
编写代码更快的使用视觉辅助代码完成工具
•New project wizard
新项目向导
•Easily create a new project from scratch or from a large library of example designs.
轻松地从头开始创建一个新项目或大型库的设计例子
•In-system programming and debugging
在系统编程和调试
•Provides a seamless interface to all Atmel in-circuit programmers and debuggers.
所有爱特梅尔公司提供了一个无缝接口软件编程和调试器。
•Full debug views
完整的调试视图
•Creates a transparent view into CPU and peripherals, enabling easy code development and debugging.
创建一个透明的视图到CPU和外围设备,使简单的代码开发和调试。
•Full chip simulation
全芯片软件仿真
•Delivers an accurate model of CPU, interrupts and peripherals.
提供一个精确的模型,CPU、中断和外围设备
•Support for external stimuli.
支持外部激励
•Atmel Spaces
Atmel 空间
•Cloud-based collaborative workspace for securely sharing embedded design and tracking progress of projects with
your peers.
基于云计算的协作工作空间和你的同行安全地共享嵌入式设计和跟踪项目的进展
dan92 发表于 2014-8-13 15:45 | 显示全部楼层
啃英文开始了~
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2403
快速回复 返回顶部 返回列表
