spi flash擦写次数的暴力测试
27692|14
 楼主| mei326 发表于 2014-8-15 22:41 | 显示全部楼层 |阅读模式
使用了华邦的SPI FLASH W25Q64 ,由于要经常性的更新Flash中的数据,初步估计平均每天更新100次左右,按照手册上的最高可大100,000次,也顶多只能用个3年。因此写了个测试程序来测试下。结果令人大跌眼镜~已经到了300,000+ 了,还没挂...有这么强大吗?这样就能用十年了...
   本来计划写个简单的算法,每个扇区擦写个五万次后就写入个故障标志再换个扇区继续...
附上测试程序
  1. union {
  2.         unsigned int wfcount;
  3.         unsigned char wfbuf[4];
  4. }RD_FLASH;
  5. unsigned char rdbuf[4096],wbuf[4096];
  6. #define TEST_FLASH_ADDR        0x6A6000
  7. /********************************************main function**************************************
  8. **************************************************************************************
  9. ********************************************************************************************/
  10. int main()
  11. {
  12.         unsigned int i;
  13.         unsigned char rbuf[2]="  ";
  14.         NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x4000);
  15.         BSP_Init();
  16.         STM_EVAL_LEDOff(LED3);
  17.         printf("\r\n Test flash start... \r\n" );
  18.         SPI_FLASH_BufferRead(rdbuf,TEST_FLASH_ADDR, 4096);
  19.         if((rdbuf[0] == 0xff)&&(rdbuf[1] == 0xff)
  20.                 &&(rdbuf[2] == 0xff)&&(rdbuf[3] == 0xff)){
  21.                         RD_FLASH.wfcount = 0;
  22.                         memcpy(wbuf, RD_FLASH.wfbuf, 4);
  23.                         SPI_FLASH_SectorErase(TEST_FLASH_ADDR);
  24.                         SPI_FLASH_BufferWrite(wbuf, TEST_FLASH_ADDR, 4096);
  25.                         SPI_FLASH_BufferRead(rdbuf, TEST_FLASH_ADDR, 4096);
  26.                         if(memcmp(wbuf,rdbuf,4096)==0){
  27.                                 RD_FLASH.wfcount ++;
  28.                                 printf("\r\n%d", RD_FLASH.wfcount );
  29.                         }else
  30.                                 printf("\r\n write flash error! " );
  31.         }else{
  32.                 memcpy(RD_FLASH.wfbuf, rdbuf, 4);
  33.                 while(1){
  34.                         RD_FLASH.wfcount ++;
  35.                         memcpy(wbuf, RD_FLASH.wfbuf, 4);
  36.                         SPI_FLASH_SectorErase(TEST_FLASH_ADDR);
  37.                         SPI_FLASH_BufferWrite(wbuf, TEST_FLASH_ADDR, 4096);
  38.                         SPI_FLASH_BufferRead(rdbuf,TEST_FLASH_ADDR, 4096);
  39.                         if(memcmp(wbuf,rdbuf,4096)==0){
  40.                                 printf("\r\n%d", RD_FLASH.wfcount );
  41.                         }else{
  42.                                 printf("\r\n write flash error! " );
  43.                                 break;
  44.                         }
  45.                         if(STM_EVAL_KeyGetState(Key1) == 0){        //有按键按下就退出测试
  46.                                 printf("\r\n write flash break! " );
  47.                                 break;
  48.                         }
  49.                 }
  50.         }
  51.         printf("\r\n Test flash flish... \r\n" );
  52.
  53.         STM_EVAL_LEDOn(LED3);
  54.         while(1)
  55.         {
  56.
  57.         }
  58. }
tuzihog 发表于 2014-8-16 08:19 | 显示全部楼层
楼主感觉FLASH中的嵌入式文件系统怎么样?手头上有个项目,也是担心读写寿命。想加个轻型文件系统(非LINUX下的文件系统),不知道楼主有这些的资料提供不?
lyjian 发表于 2014-8-16 08:51 来自手机 | 显示全部楼层
规格书上的100,000次可是最小次数,不是最大。
qq65411253 发表于 2014-8-16 12:18 | 显示全部楼层
这个次数不是说超过后立马歇菜,而是说数据保存时间不保证能达到手册注明的下限。
vavsz003 发表于 2014-8-16 14:26 | 显示全部楼层
规格书上的100,000次可是最小次数,不是最大。    楼主是高人。···如此搞法。
shell.albert 发表于 2014-8-16 17:53 | 显示全部楼层
这样测试未必不可,我的一块老PC机上机械硬件都20年了,现在依然工作正常。做何解释?
lyjian 发表于 2014-8-16 18:34 来自手机 | 显示全部楼层
这有关系吗?
chen_jhhb 发表于 2014-8-16 19:54 | 显示全部楼层
手册规定的是最低要求,一般都会有一定的余量,还和环境有关,如电压的稳定度,有没有干扰,温度多少,把他加到70~85度下,看看寿命会不会减少
xxlin1984 发表于 2014-8-18 09:34 | 显示全部楼层
Flash写坏了后并不是不能写,而是断电后不能保存或保存能力变差(时间、温度)
 楼主| mei326 发表于 2014-8-19 12:26 | 显示全部楼层
楼主感觉FLASH中的嵌 ...
文件系统并不带均衡算法,如fatfs.还是需要自己写均衡算法的
落叶行健ywm 发表于 2015-6-4 09:01 | 显示全部楼层
俺现在也在考虑spiflash的擦写次数问题呢。一直要记录数据就得擦写flash,由于经常掉电又不能保存在ram中后统一写入,蛋疼中。
幸福至上 发表于 2015-6-4 10:22 | 显示全部楼层
一般芯片手册上给出的次数是最保守的,超过此之后,芯片厂商就不保证一定能用,但可能能用。人家也是做过测试的。楼主需求的空间大不,不然可以考虑下FRAM存储芯片,就是贵了点~~~
dqgcs123 发表于 2015-6-4 10:58 | 显示全部楼层
像这种参数不可能是最大值,肯定是最小值
一般电子元器件的技术规格书里面都有最大电气参数值,以前有个领导老想让我测试这些参数究竟能达到多大,我就特别无语
大道至简 发表于 2015-6-4 19:54 | 显示全部楼层
疑似广告贴。。。。。。。。。。。。。。。。。。。。。。。。
TYZZD 发表于 2016-11-3 00:19 | 显示全部楼层
假如一页256个字节,我要经常写数据。那可不可以一下做法呢:
定义一个8位的数组,数组256个元素,初始值都赋值为0xFF,
要保存第一个8位数据data0,就把数组第一个元素赋值为data0,然后写入flash,后面的全是0XFF,写入后也不变
要保存第二个8位数据data1,就把数组第二个元素赋值为data1,然后写入flash,第一个数和开始一样的,再次写不会改变。
以后的以次类推,这样就不怕掉电了。如果等吧数据线保存在数组里一次写入,突然掉电数据就会丢失。
不知道这样可行不。如果可行,只有最开始执行一次擦除,然后写256次,那flash算擦写一次还是256次?
个人签名:与其等待机会,不如主动出击...
117
