[i.MX] 修改mx53_loco_mfg.h疑难问题
4087|26
 楼主| yueyesighhz 发表于 2014-10-31 11:30 | 显示全部楼层 |阅读模式
板子是自己设计的,所以我要去编译一个mfgtool上可以使用的uboot,我的板子是mx53_loco的,与官方的区别就是只有2块DDR,我修改mx53_loco_mfg.h如下:
* MMC Configs
#ifdef CONFIG_CMD_MMC
        #define CONFIG_MMC                                1
        #define CONFIG_GENERIC_MMC
        #define CONFIG_IMX_MMC
        #define CONFIG_SYS_FSL_ESDHC_NUM        1
        #define CONFIG_SYS_FSL_ESDHC_ADDR       0
        #define CONFIG_SYS_MMC_ENV_DEV  0
        #define CONFIG_DOS_PARTITION        1
        #define CONFIG_CMD_FAT                1
        #define CONFIG_CMD_EXT2                1
        /* detect whether ESDHC1 or ESDHC3 is boot device */
        #define CONFIG_DYNAMIC_MMC_DEVNO
        #define CONFIG_EMMC_DDR_PORT_DETECT
        #define CONFIG_EMMC_DDR_MODE
        /* port 1 (ESDHC3) is 8 bit */
        #define CONFIG_MMC_8BIT_PORTS        0x2
#endif
* SATA Configs
#ifdef CONFIG_CMD_SATA
  #define CONFIG_DWC_AHSATA
  #define CONFIG_SYS_SATA_MAX_DEVICE      1
  #define CONFIG_DWC_AHSATA_PORT_ID       0
  #define CONFIG_DWC_AHSATA_BASE_ADDR     SATA_BASE_ADDR
  #define CONFIG_LBA48
  #define CONFIG_LIBATA
#endif
* Stack sizes
* The stack sizes are set up in start.S using the settings below
#define CONFIG_STACKSIZE        (128 * 1024)        /* regular stack */
* Physical Memory Map
#define CONFIG_NR_DRAM_BANKS        1
#define PHYS_SDRAM_1                CSD0_BASE_ADDR
#define PHYS_SDRAM_1_SIZE        (256 * 1024 * 1024)
#define PHYS_SDRAM_2                CSD1_BASE_ADDR
#define PHYS_SDRAM_2_SIZE        (256 * 1024 * 1024)
#define iomem_valid_addr(addr, size) \
        ((addr >= PHYS_SDRAM_1 && addr <= (PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE)))
//        || (addr >= PHYS_SDRAM_2 && addr <= (PHYS_SDRAM_2 + PHYS_SDRAM_2_SIZE)))
这里我是根据我的uboot进行的修改,PHYS_SDRAM_2不能注释,会编译出错。但是我烧录的时候还是出现了错误,错误如下
U-Boot 2009.08 (Oct 30 2014 - 20:10:47)
CPU:   Freescale i.MX53 family 2.1V at 800 MHz
mx53 pll1: 800MHz
mx53 pll2: 400MHz
mx53 pll3: 432MHz
mx53 pll4: 455MHz
ipg clock     : 66666666Hz
ipg per clock : 33333333Hz
uart clock    : 66666666Hz
cspi clock    : 108000000Hz
ahb clock     : 133333333Hz
axi_a clock   : 400000000Hz
axi_b clock   : 200000000Hz
emi_slow clock: 133333333Hz
ddr clock     : 400000000Hz
esdhc1 clock  : 80000000Hz
esdhc2 clock  : 80000000Hz
esdhc3 clock  : 80000000Hz
esdhc4 clock  : 80000000Hz
nfc clock     : 26666666Hz
Board: MX53-LOCO 1.0 Rev. A
Boot Reason: [POR]
Boot Device: SPI NOR
I2C:   ready
DRAM:  256 MB
MMC:   FSL_ESDHC: 0
MMC Device 1 not found
No MMC card found
In:    serial
Out:   serial
Err:   serial
Error: Dont't found mc34708 or da9052 on board.
Net:   FEC0
MX53-LOCO-MFG U-Boot >
然后就停在了jumping那里,请问我还需要修改哪些地方才能让DDR跑起来。由于是菜鸟,也没有可以询问的人,所以只能来论坛寻求帮助了。
FSL_TICS_Rita 发表于 2014-10-31 13:16 | 显示全部楼层
你好,由于你DDR和开发板的不一样,所以你首先要保证DDR设置是正确的,关于DDR参数配置和测试,你可以参考一下https://bbs.21ic.com/icview-792090-1-1.html
 楼主| yueyesighhz 发表于 2014-10-31 14:33 | 显示全部楼层
你好,由于你DDR和开发板的不一样,所以你首先要保证DDR设置是正确的,关于DDR参数配置和测试,你可以参考 ...
这个意思是说我要修改uboot里面的DDR配置,然后编译一个mfgtool使用的uboot文件吗?
 楼主| yueyesighhz 发表于 2014-10-31 14:35 | 显示全部楼层
另外可以麻烦你给我发一个mx53可以使用的mfgtool工具包吗?
FSL_TICS_Rita 发表于 2014-10-31 15:24 | 显示全部楼层
这个意思是说我要修改uboot里面的DDR配置,然后编译一个mfgtool使用的uboot文件吗? ...
是的,你要先设定好DDR的配置,再编译你板子上使用烧写工具mfgtool的firmware。
 楼主| yueyesighhz 发表于 2014-10-31 15:28 | 显示全部楼层
是的,你要先设定好DDR的配置,再编译你板子上使用烧写工具mfgtool的firmware。 ...
I.MX53 DDR3 Script Aid V0.01.xlsx我在你说的网站下载了这个文件,是按照这个文件来修改flash_hearder.S里面的DDR寄存器吗?
FSL_TICS_Rita 发表于 2014-10-31 15:51 | 显示全部楼层
I.MX53 DDR3 Script Aid V0.01.xlsx我在你说的网站下载了这个文件,是按照这个文件来修改flash_hearder.S ...
在这个脚本里你可以根据你的设计来设定相应DDR的参数,设定好后在该表格中有对应的代码的。
 楼主| yueyesighhz 发表于 2014-10-31 16:37 | 显示全部楼层
在这个脚本里你可以根据你的设计来设定相应DDR的参数,设定好后在该表格中有对应的代码的。 ...
我已经照着将DDR寄存器改过了,但是mfgtool还是停在jumping那里,日志
1 - Panel A Start processing MX53-Loco <LIST/>.
Panel A Start <CMD/> type="boot" body="BootStrap" file="u-boot.bin" timeout="10" onError="" text="Read from DDR script from U-Boot to init DDR Memory.".
1 - Panel A Finished <CMD/> type="boot" body="BootStrap" file="u-boot.bin" timeout="10" onError="" text="Read from DDR script from U-Boot to init DDR Memory." SUCCESS code=0x0.
Panel A Start <CMD/> type="load" body="" file="uImage" timeout="10" onError="" text="Doing Kernel.".
1 - Panel A Finished <CMD/> type="load" body="" file="uImage" timeout="10" onError="" text="Doing Kernel." SUCCESS code=0x0.
Panel A Start <CMD/> type="load" body="" file="initramfs.cpio.gz.uboot" timeout="10" onError="" text="Doing Initramfs.".
1 - Panel A Finished <CMD/> type="load" body="" file="initramfs.cpio.gz.uboot" timeout="10" onError="" text="Doing Initramfs." SUCCESS code=0x0.
Panel A Start <CMD/> type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. ".
1 - Panel A Finished <CMD/> type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. " SUCCESS code=0x0.
Panel A Start <CMD/> type="find" body="Updater" file="" timeout="180" onError="" text="".
Panel A UtpUpdate Event: DeviceRemoval Msg: (null) DevState: Disconnected OpState: WAITING_FOR_DEVICE
Panel A: Reason is unknown,1 - Panel A Finished <CMD/> type="find" body="Updater" file="" timeout="180" onError="" text="" FAIL code=0xffffffff.
请问为什么一直连接不上设备呢
 楼主| yueyesighhz 发表于 2014-10-31 16:42 | 显示全部楼层
而且每次烧录会直接调到uboot命令行界面
Boot Reason: [POR]
I2C:   ready
DRAM:  256 MB
MMC:   FSL_ESDHC: 0
No MMC card found
In:    serial
Out:   serial
Err:   serial
Net:   FEC0
FSL_TICS_Rita 发表于 2014-10-31 16:55 | 显示全部楼层
1 - Panel A Start processing MX5 ...
还是DDR的问题,请问你有编译mfgtool使用的initramfs.cpio.gz.uboot,u-boot以及kernel文件了吗?
 楼主| yueyesighhz 发表于 2014-10-31 16:59 | 显示全部楼层
我只是替换了uboot,至于initramfs.cpio.gz.uboot我看你们有回复说是可以使用默认的
还是DDR的问题,请问你有编译mfgtool使用的initramfs.cpio.gz.uboot,u-boot以及kernel文件了吗? ...
FSL_TICS_Rita 发表于 2014-10-31 17:35 | 显示全部楼层
我只是替换了uboot,至于initramfs.cpio.gz.uboot我看你们有回复说是可以使用默认的 ...
如果DDR设计不一样的话,是要换掉的。
pei84 发表于 2014-10-31 17:48 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-11-3 15:34 | 显示全部楼层
楼主你好,请问你帖中问题解决了吗?如果没有的话,欢迎继续在这里讨论哈~~
 楼主| yueyesighhz 发表于 2014-11-3 15:44 | 显示全部楼层
如果DDR设计不一样的话,是要换掉的。
我还是有几个问题:
1、下载会自动进入uboot命令行,但是我通过uboot命令可以调到内核,那不是能说明DDR是正常运行的么?
2、mfgtool烧录需要3个文件,uboot,kernel还有inittramfs,其中jumping to OS image还是在uboot阶段吧,那这个时候跟文件系统inittram有联系吗?为什么这个也要定制呢?
3、mfgtool的jump指令,就是跳转到内存中的kernel去执行吧,为什么我手动运行bootm 70800000 可以跳转,而它自己却不能跳转嗯?这是不是说明它实际上是找不到内核呢?
FSL_TICS_Rita 发表于 2014-11-3 16:01 | 显示全部楼层
我还是有几个问题:
1、下载会自动进入uboot命令行,但是我通过uboot命令可以调到内核,那不是能说明DDR ...
我还是有几个问题:
答:进入u-boot说明DDR已经正常运行。
答:你DDR设计和开发板不一样的,要重新编译mfgtool的firmware,在重新编译mfgtool的firmware时候uboot,kernel还有inittramfs都会被重新生成的。
你好,你这里手动执行bootm 70800000是在哪里执行的?
 楼主| yueyesighhz 发表于 2014-11-3 16:14 | 显示全部楼层
我还是有几个问题:
烧录的时候在串口终端,会在jumping的时候跑到uboot的命令行,后面的烧录就没有跑了,然后我直接在uboot的命令行写命令是可以进入内核的,但是我不清楚为什么会导致烧录不能自动去加载内核
FSL_TICS_Rita 发表于 2014-11-3 16:51 | 显示全部楼层
烧录的时候在串口终端,会在jumping的时候跑到uboot的命令行,后面的烧录就没有跑了,然后我直接在uboot ...
楼主你好,你能把终端上打印的信息发给我看一下吗?
