| #include <msp430g2553.h> #include"lcd.h"
 uchar table[]="小型风扇检测仪";
 uchar table1[]="转速";
 uchar table2[]="r/min";
 uchar table3[]="线速度";
 uchar table4[]="m/s";
 uint n,m,overflowcut;
 float speed,r=0.055;
 void display(uint speed);
 void displayini();
 void display1(uint speed);
 void main (void)
 WDTCTL = WDTPW + WDTHOLD;  //关闭看门狗定时器
 ini();
 displayini();
 BCSCTL1 = CALBC1_8MHZ;
 DCOCTL = CALDCO_8MHZ;  // 设置DCO模式
 P1DIR&=~BIT5;//P1.2为输入
 P1REN|=BIT5;//上拉电阻
 P1IES|=BIT5;//选择第2功能
 P1IE|=BIT5;
 TACTL|=TASSEL_2+MC_2+TAIE+TACLR;
 _EINT();
 uchar bb,cc,dd,ee;
 bb=speed%10000/1000;
 cc=speed%1000/100;
 dd=speed%100/10;
 ee=speed%10;
 writedata(0x30+bb);
 writedata(0x30+cc);
 writedata(0x30+dd);
 writedata(0x30+ee);
 uchar bb,cc,dd,ee;
 cc=speed%1000/100;
 dd=speed%100/10;
 ee=speed%10;
 writedata(0x30+bb);
 writedata(0x30+cc);
 writedata('.');
 writedata(0x30+dd);
 writedata(0x30+ee);
 void displayini()
 uchar i=0;
 setwindow(0,0);
 for(;table[i]!='\0';i++)
 writedata(table[i]);
 i=0;
 setwindow(1,0);
 for(;table1[i]!='\0';i++)
 writedata(table1[i]);
 i=0;
 setwindow(1,4);
 for(;table2[i]!='\0';i++)
 writedata(table2[i]);
 i=0;
 setwindow(2,0);
 for(;table3[i]!='\0';i++)
 writedata(table3[i]);
 i=0;
 setwindow(2,5);
 for(;table4[i]!='\0';i++)
 writedata(table4[i]);
 i=0;
 #pragma vector=PORT1_VECTOR
 __interrupt void port2_4()
 uint i;
 _BIC_SR(SCG0);
 for(i=0;i<600;i++);
 if((P1IN&BIT5)==BIT5)
 P1IFG=0;
 return;
 if(P1IFG&BIT5)
 n=8000000*60/((overflowcut*65535+TAR)*7);
 speed=(float)(3.141592654*r*8000000/(7*(overflowcut*65535+TAR)));
 m=(int)(speed*100);//转换  把speed化为m
 overflowcut=0;
 TACTL|=TACLR;
 setwindow(1,2);
 display(n);
 setwindow(2,2);
 display1(m);
 P1IFG=0;
 #pragma vector=TIMER0_A1_VECTOR
 __interrupt void TA_ISR(void)
 switch(TAIV)
 case 2: break;
 case 4: break;
 case 10: overflowcut++;
 if(~TAR)
 setwindow(1,2);
 display(0);
 setwindow(2,2);
 display1(0);
 break;
