[STM32F1]
STM32外部中断进不去
2199|3
1456276911|  楼主 | 2015-1-23 14:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
stm32外部中断,配置完全看不出有什么问题,可是中断就是触发不了,用EXTI_GenerateSWInterrupt(EXTI_Line0);软件触发也不行,求大家帮看看,以下是配置程序:
//时钟配置
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  RCC_DeInit();
  RCC_HSEConfig(RCC_HSE_ON);
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    FLASH_SetLatency(FLASH_Latency_2);
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    RCC_PCLK2Config(RCC_HCLK_Div1);
    RCC_PCLK1Config(RCC_HCLK_Div2);
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource() != 0x08)
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_I2C1 | RCC_APB1Periph_CAN1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB  | RCC_APB2Periph_AFIO, ENABLE);
//IO口配置
void GPIO_Configuration(void)
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
void EXTI_Config(void)
        EXTI_InitTypeDef EXTI_InitStructure;
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource0);
        EXTI_InitStructure.EXTI_Line = EXTI_Line0;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
int main()
        RCC_Configuration();
        GPIO_Configuration();
        EXTI_Config();
        while(1)
                LEDRED_onoff(ON);
                Delay_ms(500);
                LEDRED_onoff(OFF);
                Delay_ms(500);
void EXTI0_IRQHandler(void)
         if(EXTI_GetITStatus(EXTI_Line9)!= RESET)
                  EXTI_ClearITPendingBit(EXTI_Line4);
                  LEDGREEN_onoff(ON);
紫宸| | 2015-1-23 16:11 | 只看该作者
NVIC没有配置
类似如下:
/* 使能中断线并配置中断优先级 */
        NVIC_InitStructure.NVIC_IRQChannel = NRF24L01_IRQ_EXTI_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x02;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
jar1866| | 2015-1-23 16:52 | 只看该作者
参考楼上, 或者在固件库中找到EXTI的example
mmuuss586| | 2015-1-23 18:15 | 只看该作者
配置下中断优先级;
另外中断程序也不对,有0,9,4呢;
