[STM32F0]
USART2接收不到数据
752|2
钱愈玉|  楼主 | 2015-3-23 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用USART2发送数据到串口上是可以的,接收却不行,RXNE和RDR一直为0。我用的是轮询检测if(USART_GetFlagStatus(USART2,USART_FLAG_RXNE) != RESET)    求助
钱愈玉|  楼主 | 2015-3-23 15:56 | 只看该作者
//这是我的程序。
#include "stm32f0xx.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
static __IO uint32_t TimingDelay;          //_IOÊÇviolateµÄºê¶¨Òå  ÊÇÔÚCORE_CM0.H STM32F0XX.MISC.HÖж¨ÒåµÄ
//UINT32_T ÊÇUNSIGNED INT µÄºê¶¨ÒåÔÚSTDINT.H STM32F0XX.MISC.HÖж¨ÒåµÄ
void Delay(__IO uint32_t nTime);      //ÉùÃ÷
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef        GPIO_InitStructure;           //Óù¹Ô캯Êý¶¨ÒåÒ»¸ö¹¹Ô캯ÊýµÄ±äÁ¿
USART_InitTypeDef       USART_InitStructure;
NVIC_InitTypeDef        NVIC_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
uint8_t Res = 0xAA;
int main(void)
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);     //¿ªÆôGPIOʱÖÓ
        USART_DeInit(USART2);   //¸´Î»´®¿Ú2
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;              //UART_TXD
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;           //
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;         //ÍÆÍì
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_1);     // ÕâÊÇ´íµÄ===GPIO_PinAFConfig(GPIOA,GPIO_PinSource2|GPIO_PinSource3,GPIO_AF_1);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;              //UART_RXD
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;           //ÊäÈë
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;           //¸¡¿Õ
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_1);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 , ENABLE);
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;         //ÉèÖÃУÑéλ
  USART_InitStructure.USART_Mode |= USART_Mode_Tx;      //·¢ËÍ¿ÕÏÐλ×÷ΪµÚÒ»´ÎÊý¾Ý·¢ËÍ
        USART_InitStructure.USART_Mode |= USART_Mode_Rx;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;    //Á÷¿Ø
        USART_Init(USART2,&USART_InitStructure);
//        USART_ITConfig(USART2, USART_IT_TXE, ENABLE);   //ʹÄÜ·¢ËÍÖжÏ
//        USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);    //½ÓÊÕµ½USART_IT_RXNEÊý¾Ý£¬ÖжϿªÆô
        USART_Cmd(USART2,ENABLE);     //ʹÄÜ´®¿Ú
  while (1)
                GPIO_ResetBits(GPIOA,GPIO_Pin_8);
                if(USART_GetFlagStatus(USART2,USART_FLAG_RXNE) != RESET) //if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_3) == 0x00)
                                USART_ClearFlag(USART2,USART_FLAG_RXNE);
                                USART_SendData(USART2,Res);
                                while(USART_GetFlagStatus(USART2,USART_FLAG_TC) == RESET);
                                USART_ClearFlag(USART2,USART_FLAG_TC);
void Delay(__IO uint32_t nCount)
  while(nCount--)
钱愈玉|  楼主 | 2015-3-24 15:18 | 只看该作者
解决了。要把PIN3的模式定义成GPIO_Mode_AF
