求大神指导 adc0804测电压在12864上显示的C程序
1034|0
 楼主| 阳光下的雨珠 发表于 2015-4-27 17:33 | 显示全部楼层 |阅读模式
//测出的电压经0804转换后在12864上显示
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
#define port P1 //DB0~DB7数据口
sbit e=P2^0;//使能
sbit rw=P2^1;//读写
sbit rs=P2^2;//数据/命令
sbit cs2=P2^3;//片选
sbit cs1=P2^4;
sbit busy=P1^7;//检测忙
#define date  P0
sbit cs=P2^5;    //片选信号,控制芯片的启动,低电平有效
sbit rd=P2^6;   //读数据控制,低电平有效
sbit rw1=P2^7;  //AD转换启动控制,上升沿有效
sbit intr=P3^3; //AD转换结束输出低电平
uchar code hz[][16]={
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},
//"0",0
{0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},
//"1",1
{0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},
//"2",2
{0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00},
//"3",3
{0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00},
//"4",4
{0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00},
//"5",5
{0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00},
//"6",6
{0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00},
//"7",7
{0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},
//"8",8
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00} //"9",9
//延时
void delay(uint n)
  uint i;
  for(;n>0;n--)
    for(i=200;i>0;i--);
void check()
      rs=0;rw=1;
          port=0x00;
          e=1;
          while(busy);
          e=0;
//写指令
void wreg(uchar c)
    check();
rs=0;  //指令
rw=0;  //写 e=0;
port=c;
e=1;
e=0; //写入指令
//写数据
void wdata(uchar dat)
    check();
rs=1;    //数据
rw=0;
port=dat;
e=1;
e=0;
//选屏幕 0--全屏,1--左屏,2--右屏;
void select(uint n)
    switch(n)
    case 0:cs1=0;cs2=0;break;   //低电平选中
    case 1:cs1=0;cs2=1;break;   //cs1左屏
    case 2:cs1=1;cs2=0;break;   //cs2右屏
//页
void setpage(uchar page)
   //page=page&0x07;
   page=page|0xb8;
   check();
   wreg(page);
//列
void setcolumn(uchar column)
  // column=column&0x3f;
   column=column|0x40;
   wreg(column);
//清屏 0--全屏,1--左屏,2--右屏;
void clear(uint n)
   uchar i,j;
   select(n);
   //wreg(0x3f);
   for(i=0;i<8;i++)
      setpage(i);
     setcolumn(0);
   for(j=0;j<64;j++)
     wdata(0x00);  //置0清空
void show16(uchar page,uchar column,uchar screen,uchar*s)
  uchar i,j;
  select(screen);
  j=0;
  setpage(page);
  setcolumn(column);
  for(i=0;i<16;i++)
        wdata(s[j++]);
   setpage(page+1);
   setcolumn(column);
   for(i=0;i<16;i++)
     wdata(s[j++]);
void show8(uchar page,uchar column,uchar screen,uchar *str)
  uchar i,j;
select(screen);j=0;
setpage(page);
setcolumn(column);
for(i=0;i<8;i++)
{            wdata(str[j++]);
setpage(page+1);
setcolumn(column);
  for(i=0;i<8;i++)
  {       wdata(str[j++]);
//  ad   转换
void start_ad( )
   date=0xff;
    cs=0;
    rw1=0;
        rd=1;
    delay(3);
        cs=1;
    rw1=1;
        rd=1;
uint ad_read( )
  uint temp;
  cs=0;
  rd=0;
  delay(3);
  temp=date;
  rd=1;
  cs=1;
  return(temp);
void ad_init( )
  cs=1;rw1=1;rd=1;
main( )
  uint  a1,a2,a3,a4;
  uint ad_data;
  ad_init( );
  start_ad( ) ;
  while(intr==1);
  ad_data=ad_read();
  ad_data=ad_data*196;
a1=ad_data/10000; //第四位数码管(最高位)
a2=ad_data%10000/1000;//第三位数码管?
a3=ad_data%1000/100;//第二位数码管?
a4=ad_data%100/10;//第一位数码管(最低位)
   clear(0);
   show8(0,8,1,hz[a1]);
   show8(0,16,1,hz[a2]);
   show8(0,24,1,hz[a3]);
   show8(0,32,1,hz[a4]);
   show8(0,8,2,hz[5]);
   show8(0,16,2,hz[6]);
   show8(0,24,2,hz[7]);
   show8(0,32,2,hz[8]);
   delay(5000);
   while(1);
