[STM8]
STM8S103F3+hs6200编程AutoACK功能实现不了
1310|1
埋头看路|  楼主 | 2015-5-11 22:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STM8S103F3+hs6200实现无线通信,接收端能够接收得到信号,但是发送端一直收不到ack信号。且重发次数一直都为0。哪个大大给帮忙看下,非常感谢。
//发送端
void HS6200_Init(void)
  uint8_t temp[5];
  uint8_t TmpLastFrequence = GetLastFrequenceIndex();
  printf("HS6200_Init\r\n");
  /* calibration */
  HS6200_Calibration();
  /* analog init */
  HS6200_Analog_Init();
        /* the same to nRF24L01  */
  HS6200_Bank0_Activate();
  /* PRX POWER Up, 2Byte CRC.      */
  rf_write_reg(HS6200_BANK0_CONFIG, 0x0F);
  rf_write_reg(HS6200_BANK0_EN_RXADDR, 0x01);
  /* 5Bytes Address width */
  rf_write_reg(HS6200_BANK0_SETUP_AW, 0x03);
  /* Rf channel     */
  printf("It is transimit ending, ChannelFrequence:\r\n");
  printf_hex(ChannelFrequence[TmpLastFrequence]);
  printf("\r\n");
  rf_write_reg(HS6200_BANK0_EN_AA, 0x01);  //edit by jerry
  hal_nrf_set_auto_retr(RF_RETRANSMITS, RF_RETRANS_DELAY);
  rf_write_reg(HS6200_BANK0_RF_CH, ChannelFrequence[TmpLastFrequence]);
  #if HS6200_DR_2M
  temp[0] = 0x4F;       /* 2MHz 5dBm    */
  #elif HS6200_DR_1M
  temp[0] = 0x47;       /* 1MHz 5dBm. */
  #else
  temp[0] = 0x6F;       /* 500K 5DBm */
  #endif
  HS6200_Write_Reg(HS6200_BANK0_RF_SETUP, temp, 1);
  temp[0] = 0x46;
  temp[1] = 0x0B;
  temp[2] = 0xAF;
  temp[3] = 0x43;
  temp[4] = 0x98;
  HS6200_Write_Reg(HS6200_BANK0_RX_ADDR_P0, temp, 5);   /* set address  */
  HS6200_Write_Reg(HS6200_BANK0_TX_ADDR, temp, 5);   /* set address   */
  rf_write_reg(HS6200_BANK0_DYNPD, 0x3F);       /* dynamic length */
  rf_write_reg(HS6200_BANK0_FEATURE, 0x04);
  HS6200_Flush_Rx_Fifo();
  HS6200_Flush_Tx_Fifo();
  rf_write_reg(HS6200_BANK0_STATUS, 0x70);
  temp[0] = 0x52;
  temp[1] = 0x95;
  temp[2] = 0x29;
  temp[3] = 0x01;
  temp[4] = 0x03;
  HS6200_Write_Reg(HS6200_BANK0_SETUP_VALUE, temp, 5);
//接收端
  uint8_t temp[5];
  uint8_t TmpFrequence = GetLastFrequenceIndex();
  /* calibration */
        /* analog init */
  /* ENAA */
  /* Rf channel     */
  printf("It is receive ending, ChannelFrequence:\r\n");
  printf_hex(ChannelFrequence[TmpFrequence]);
  printf("\r\n");
  rf_write_reg(HS6200_BANK0_RF_CH, ChannelFrequence[TmpFrequence]);
  rf_write_reg(HS6200_BANK0_SETUP_RETR, 0x00);
  #if HS6200_DR_2M
  #elif HS6200_DR_1M
  #else
  #endif
  temp[0] = 0x46;
  temp[1] = 0x0B;
  temp[2] = 0xAF;
  temp[3] = 0x43;
  temp[4] = 0x98;
  temp[0] = 0x52;
  temp[1] = 0x95;
  temp[2] = 0x29;
  temp[3] = 0x01;
  temp[4] = 0x03;
lulugl| | 2017-6-22 08:51 | 只看该作者
大神,你的问题解决了吗?
