[STM32F2]
STM32F207的can1发送不好用。帮忙看看
856|1
xlsbz|  楼主 | 2015-7-8 15:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "stm32f2xx.h"
int main(void)
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* Enable GPIO clock */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  /* Configure CAN RX and TX pins */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* CAN configuration ********************************************************/
  /* Enable CAN clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  /* CAN Baudrate = 1MBps (CAN clocked at 30 MHz) */
  CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
  CAN_InitStructure.CAN_Prescaler = 2;
  CAN_Init(CAN1, &CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* Enable FIFO 0 message pending Interrupt */
//  CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
  while(1) {
      static uint16_t i = 0;
      CanTxMsg TxMessage;
      i = 10000;
      while(i--) {;}
      /* Transmit Structure preparation */
      TxMessage.StdId = 0x321;
      TxMessage.ExtId = 0x01;
      TxMessage.RTR = CAN_RTR_DATA;
      TxMessage.IDE = CAN_ID_STD;
      TxMessage.DLC = 8;
      TxMessage.Data[0]++;
      CAN_Transmit(CAN1, &TxMessage);
misra| | 2015-7-8 20:37 | 只看该作者
是硬件本身的bug,这个碰见过
