贴个红外遥控的程序(已测试)
采用标准32位HT6121编码红外遥控器<br /><br />#include <reg51.h><br />#include <intrins.h><br /><br />#define uchar unsigned char<br />#define uint unsigned int<br />#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};<br /><br />void delay(uchar x); //x*0.14MS<br />void delay1(int ms);<br />void beep();<br /><br />sbit IRIN = P3^2; //红外接收器<br />sbit BEEP = P3^7; //蜂鸣器<br /><br />uchar IRCOM;<br /><br />sbit LCD_RS = P2^0; <br />sbit LCD_RW = P2^1;<br />sbit LCD_EN = P2^2;<br /><br />uchar code cdis1[ ] = {" REMOTE CONTROL "};<br />uchar code cdis2[ ] = {" IR-CODE: --H "};<br /><br />/*******************************************************************/<br />/* */<br />/*检查LCD忙状态 */<br />/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */<br />/* */<br />/*******************************************************************/<br /><br />uchar lcd_busy()<br />{ <br /> uchar result;<br /> LCD_RS = 0;<br /> LCD_RW = 1;<br /> LCD_EN = 1;<br /> delayNOP();<br /> result = (uchar)(P0&0x80);<br /> LCD_EN = 0;<br /> return(result); <br />}<br /><br />/*******************************************************************/<br />/* */<br />/*写指令数据到LCD */<br />/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */<br />/* */<br />/*******************************************************************/<br /><br />void lcd_wcmd(uchar cmd)<br /><br />{ <br /> while(lcd_busy());<br /> LCD_RS = 0;<br /> LCD_RW = 0;<br /> LCD_EN = 0;<br /> _nop_();<br /> _nop_(); <br /> P0 = cmd;<br /> delayNOP();<br /> LCD_EN = 1;<br /> delayNOP();<br /> LCD_EN = 0; <br />}<br /><br />/*******************************************************************/<br />/* */<br />/*写显示数据到LCD */<br />/*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */<br />/* */<br />/*******************************************************************/<br /><br />void lcd_wdat(uchar dat)<br />{ <br /> while(lcd_busy());<br /> LCD_RS = 1;<br /> LCD_RW = 0;<br /> LCD_EN = 0;<br /> P0 = dat;<br /> delayNOP();<br /> LCD_EN = 1;<br /> delayNOP();<br /> LCD_EN = 0; <br />}<br /><br />/*******************************************************************/<br />/* */<br />/* LCD初始化设定 */<br />/* */<br />/*******************************************************************/<br /><br />void lcd_init()<br />{ <br /> delay1(15); <br /> lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据<br /> delay1(5);<br /> lcd_wcmd(0x38); <br /> delay1(5);<br /> lcd_wcmd(0x38); <br /> delay1(5);<br /><br /> lcd_wcmd(0x0c); //显示开,关光标<br /> delay1(5);<br /> lcd_wcmd(0x06); //移动光标<br /> delay1(5);<br /> lcd_wcmd(0x01); //清除LCD的显示内容<br /> delay1(5);<br />}<br /><br />/*******************************************************************/<br />/* */<br />/* 设定显示位置 */<br />/* */<br />/*******************************************************************/<br /><br />void lcd_pos(uchar pos)<br />{ <br />lcd_wcmd(pos | 0x80); //数据指针=80+地址变量<br />}<br /><br />/*******************************************************************/<br />main()<br />{<br /> uchar m;<br /><br /> IE = 0x81; //允许总中断中断,使能 INT0 外部中断<br /> TCON = 0x01; //触发方式为脉冲负边沿触发<br /> <br /> IRIN=1; //I/O口初始化<br /> BEEP=1;<br /> RELAY=1; <br /><br /> delay1(10); //延时<br /> lcd_init(); //初始化LCD <br /> <br /> lcd_pos(0); //设置显示位置为第一行的第1个字符<br /> m = 0;<br /> while(cdis1 != '\0')<br /> { //显示字符<br /> lcd_wdat(cdis1);<br /> m++;<br /> }<br /><br /> lcd_pos(0x40); //设置显示位置为第二行第1个字符<br /> m = 0;<br /> while(cdis2 != '\0')<br /> {<br /> lcd_wdat(cdis2); //显示字符<br /> m++;<br /> }<br /><br /> while(1) ;<br /><br />} //end main<br />/**********************************************************/<br />void IR_IN() interrupt 0 using 0<br />{<br />unsigned char j,k,N=0;<br /> EX0 = 0; <br />delay(15);<br />if (IRIN==1) <br /> { EX0 =1;<br /> return;<br /> } <br /> //确认IR信号出现<br />while (!IRIN) //等IR变为高电平,跳过9ms的前导低电平信号。<br /> {delay(1);}<br /><br />for (j=0;j<4;j++) //收集四组数据<br />{ <br />for (k=0;k<8;k++) //每组数据有8位<br />{<br /> while (IRIN) //等 IR 变为低电平,跳过4.5ms的前导高电平信号。<br /> {delay(1);}<br /> while (!IRIN) //等 IR 变为高电平<br /> {delay(1);}<br /> while (IRIN) //计算IR高电平时长<br /> {<br /> delay(1);<br /> N++; <br /> if (N>=30)<br />{ EX0=1;<br />return;} //0.14ms计数过长自动离开。<br /> } //高电平计数完毕 <br /> IRCOM=IRCOM >> 1; //数据最高位补“0”<br /> if (N>=8) {IRCOM = IRCOM | 0x80;} //数据最高位补“1”<br /> N=0;<br />}//end for k<br />}//end for j<br /> <br /> if (IRCOM!=~IRCOM)<br /> { EX0=1;<br /> return; }<br /><br /> IRCOM=IRCOM & 0x0F; //取键码的低四位<br /> IRCOM=IRCOM >> 4; //右移4次,高四位变为低四位<br /><br /> if(IRCOM>9)<br /> { IRCOM=IRCOM+0x37;}<br /> else<br /> IRCOM=IRCOM+0x30;<br /><br /> if(IRCOM>9)<br /> { IRCOM=IRCOM+0x37;}<br /> else<br /> IRCOM=IRCOM+0x30;<br /><br /> lcd_pos(0x4b); <br /> lcd_wdat(IRCOM); //第一位数显示 <br /> lcd_pos(0x4c); <br /> lcd_wdat(IRCOM); //第二位数显示<br /><br /> beep();<br /> EX0 = 1; <br />}<br /><br />/**********************************************************/<br />void beep()<br />{<br />unsigned char i;<br />for (i=0;i<100;i++)<br /> {<br /> delay(4);<br /> BEEP=!BEEP; //BEEP取反<br /> } <br />BEEP=1; //关闭蜂鸣器<br />}<br />/**********************************************************/<br />void delay(unsigned char x) //x*0.14MS<br />{<br />unsigned char i;<br />while(x--)<br />{<br />for (i = 0; i<13; i++) {}<br />}<br />}<br /><br />/**********************************************************/<br />void delay1(int ms)<br />{<br />unsigned char y;<br />while(ms--)<br />{<br />for(y = 0; y<250; y++)<br />{<br /> _nop_();<br /> _nop_();<br /> _nop_();<br /> _nop_();<br />}<br />}<br />}<br /><br />/*<br />;================================<br />;****** 红外遥控器键值表 ******<br /><br />; 10 03 01 06<br />; 09 1D 1F 0D<br />; 19 1B 11 15<br />; 17 12 16 4C<br />; 40 48 04 00<br />; 02 05 54 4D<br />; 0A 1E 0E 1A<br />; 1C 14 0F 0C<br />;================================<br />*/<br />这个程序, 在中断里傻等信号跳变.
如果信号中断(中间突然消失), 会导致死锁fdfgffdg
sfddsfds
页:
[1]
