求助:CCS3.1 F2812的simulator 时,出错
请问,我用CCS3.1 F2812的simulator 时,错现如下问题:<br /><br /> DevEmuRegs.M0RAMDFT = 0x0300;<br /> DevEmuRegs.M1RAMDFT = 0x0300;<br /> DevEmuRegs.L0RAMDFT = 0x0300;<br /> DevEmuRegs.L1RAMDFT = 0x0300;<br /> DevEmuRegs.H0RAMDFT = 0x0300;<br /> 当运行到上面几句时,提示如下错问:<br />Can't Run Target CPU: Can't write to data memory 0x950, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x951, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x952, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x953, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x954, check memory config [-2184]<br /><br />cmd文件中<br />MEMORY<br />{<br />PAGE 1 : <br /> /* Peripheral Frame 0: */<br /> DEV_EMU : origin = 0x000880, length = 0x000180<br />}<br />SECTIONS<br />{ <br /> DevEmuRegsFile : > DEV_EMU, PAGE = 1<br />}<br /><br /><br />请问这是什么原因啊<br />看一下memory map
看一下memory map,看你的DEV_EMU在不在有效区域内 请问楼主你的问题解决了吗?我也遇到同样问题,不知道该怎么办了
页:
[1]
