哪位GGJJ有标准的5*7的英文点阵字库?
项目需要用到5*7的英文点阵字库,在网上百度、谷歌都没找到。请有用过这个字库的GGJJ们帮帮忙,谢谢! 找个1602液晶规格书,看一下就好了。 找个批量生成的字库软件转一下 /*! \file font5x7.h \brief Graphic LCD Font (Ascii Characters). */
// File Name : 'font5x7.h'
// Title : Graphic LCD Font (Ascii Charaters)
// Author : Pascal Stang
// Date : 10/19/2001
// Revised : 10/19/2001
// Version : 0.1
// Target MCU : Atmel AVR
// Editor Tabs : 4
// standard ascii 5x7 font
// defines ascii characters 0x20-0x7f (32-127)
//static unsigned char __attribute__ ((progmem))
const unsigned char code Fonts[] = {
0x00, 0x00, 0x00, 0x00, 0x00,// ' '
0x00, 0x00, 0x5F, 0x00, 0x00,// !
0x00, 0x07, 0x00, 0x07, 0x00,// "
0x14, 0x7F, 0x14, 0x7F, 0x14,// #
0x24, 0x2A, 0x07, 0x2A, 0x12,// $
0x23, 0x13, 0x08, 0x64, 0x62,// %
0x37, 0x49, 0x55, 0x22, 0x50,// &
0x00, 0x05, 0x03, 0x00, 0x00,// '
0x00, 0x1C, 0x22, 0x41, 0x00,// (
0x00, 0x41, 0x22, 0x1C, 0x00,// )
0x08, 0x2A, 0x1C, 0x2A, 0x08,// *
0x08, 0x08, 0x3E, 0x08, 0x08,// +
0x00, 0x50, 0x30, 0x00, 0x00,// ,
0x08, 0x08, 0x08, 0x08, 0x08,// -
0x00, 0x60, 0x60, 0x00, 0x00,// .
0x20, 0x10, 0x08, 0x04, 0x02,// /
0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
0x00, 0x42, 0x7F, 0x40, 0x00,// 1
0x42, 0x61, 0x51, 0x49, 0x46,// 2
0x21, 0x41, 0x45, 0x4B, 0x31,// 3
0x18, 0x14, 0x12, 0x7F, 0x10,// 4
0x27, 0x45, 0x45, 0x45, 0x39,// 5
0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
0x01, 0x71, 0x09, 0x05, 0x03,// 7
0x36, 0x49, 0x49, 0x49, 0x36,// 8
0x06, 0x49, 0x49, 0x29, 0x1E,// 9
0x00, 0x36, 0x36, 0x00, 0x00,// :
0x00, 0x56, 0x36, 0x00, 0x00,// ;
0x00, 0x08, 0x14, 0x22, 0x41,// <
0x14, 0x14, 0x14, 0x14, 0x14,// =
0x41, 0x22, 0x14, 0x08, 0x00,// >
0x02, 0x01, 0x51, 0x09, 0x06,// ?
0x32, 0x49, 0x79, 0x41, 0x3E,// @
0x7E, 0x11, 0x11, 0x11, 0x7E,// A
0x7F, 0x49, 0x49, 0x49, 0x36,// B
0x3E, 0x41, 0x41, 0x41, 0x22,// C
0x7F, 0x41, 0x41, 0x22, 0x1C,// D
0x7F, 0x49, 0x49, 0x49, 0x41,// E
0x7F, 0x09, 0x09, 0x01, 0x01,// F
0x3E, 0x41, 0x41, 0x51, 0x32,// G
0x7F, 0x08, 0x08, 0x08, 0x7F,// H
0x00, 0x41, 0x7F, 0x41, 0x00,// I
0x20, 0x40, 0x41, 0x3F, 0x01,// J
0x7F, 0x08, 0x14, 0x22, 0x41,// K
0x7F, 0x40, 0x40, 0x40, 0x40,// L
0x7F, 0x02, 0x04, 0x02, 0x7F,// M
0x7F, 0x04, 0x08, 0x10, 0x7F,// N
0x3E, 0x41, 0x41, 0x41, 0x3E,// O
0x7F, 0x09, 0x09, 0x09, 0x06,// P
0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
0x7F, 0x09, 0x19, 0x29, 0x46,// R
0x46, 0x49, 0x49, 0x49, 0x31,// S
0x01, 0x01, 0x7F, 0x01, 0x01,// T
0x3F, 0x40, 0x40, 0x40, 0x3F,// U
0x1F, 0x20, 0x40, 0x20, 0x1F,// V
0x7F, 0x20, 0x18, 0x20, 0x7F,// W
0x63, 0x14, 0x08, 0x14, 0x63,// X
0x03, 0x04, 0x78, 0x04, 0x03,// Y
0x61, 0x51, 0x49, 0x45, 0x43,// Z
0x00, 0x00, 0x7F, 0x41, 0x41,// [
0x02, 0x04, 0x08, 0x10, 0x20,// "\"
0x41, 0x41, 0x7F, 0x00, 0x00,// ]
0x04, 0x02, 0x01, 0x02, 0x04,// ^
0x40, 0x40, 0x40, 0x40, 0x40,// _
0x00, 0x01, 0x02, 0x04, 0x00,// `
0x20, 0x54, 0x54, 0x54, 0x78,// a
0x7F, 0x48, 0x44, 0x44, 0x38,// b
0x38, 0x44, 0x44, 0x44, 0x20,// c
0x38, 0x44, 0x44, 0x48, 0x7F,// d
0x38, 0x54, 0x54, 0x54, 0x18,// e
0x08, 0x7E, 0x09, 0x01, 0x02,// f
0x08, 0x14, 0x54, 0x54, 0x3C,// g
0x7F, 0x08, 0x04, 0x04, 0x78,// h
0x00, 0x44, 0x7D, 0x40, 0x00,// i
0x20, 0x40, 0x44, 0x3D, 0x00,// j
0x00, 0x7F, 0x10, 0x28, 0x44,// k
0x00, 0x41, 0x7F, 0x40, 0x00,// l
0x7C, 0x04, 0x18, 0x04, 0x78,// m
0x7C, 0x08, 0x04, 0x04, 0x78,// n
0x38, 0x44, 0x44, 0x44, 0x38,// o
0x7C, 0x14, 0x14, 0x14, 0x08,// p
0x08, 0x14, 0x14, 0x18, 0x7C,// q
0x7C, 0x08, 0x04, 0x04, 0x08,// r
0x48, 0x54, 0x54, 0x54, 0x20,// s
0x04, 0x3F, 0x44, 0x40, 0x20,// t
0x3C, 0x40, 0x40, 0x20, 0x7C,// u
0x1C, 0x20, 0x40, 0x20, 0x1C,// v
0x3C, 0x40, 0x30, 0x40, 0x3C,// w
0x44, 0x28, 0x10, 0x28, 0x44,// x
0x0C, 0x50, 0x50, 0x50, 0x3C,// y
0x44, 0x64, 0x54, 0x4C, 0x44,// z
0x00, 0x08, 0x36, 0x41, 0x00,// {
0x00, 0x00, 0x7F, 0x00, 0x00,// |
0x00, 0x41, 0x36, 0x08, 0x00,// }
0x02, 0x01, 0x02, 0x04, 0x02,// ~
0xff, 0xff, 0xff, 0xff, 0xff //black block//
}; 纵向排列的。 谢谢wangkj! wangkj 发表于 2009-11-5 16:26
纵向排列的。
老大这个怎么生成的,我需要横向生成5*7的字库 0x00,0x04,0x0C,0x04,0x04,0x04,0x0E,0x00,//’1’ 0
0x0E,0x11,0x01,0x02,0x04,0x08,0x1F,0x00,//’2’ 1
0x1F,0x02,0x04,0x02,0x01,0x11,0x0E,0x00,//’3’ 2
0x02,0x06,0x0A,0x12,0x1F,0x02,0x02,0x00,//’4’ 3
0x1F,0x10,0x1E,0x01,0x01,0x11,0x0E,0x00,//’5’ 4
0x06,0x08,0x10,0x1E,0x11,0x11,0x0E,0x00,//’6’ 5
0x1F,0x01,0x02,0x04,0x08,0x08,0x08,0x00,//’7’ 6
0x0E,0x11,0x11,0x0E,0x11,0x11,0x0E,0x00,//’8’ 7
0x0E,0x11,0x11,0x0F,0x01,0x02,0x0C,0x00,//’9’ 8
0x0E,0x11,0x13,0x15,0x19,0x11,0x0E,0x00,//’0’ 9
0x0E,0x11,0x11,0x11,0x1F,0x11,0x11,0x00,//’A’ 10
0x1E,0x11,0x11,0x1E,0x11,0x11,0x1E,0x00,//’B’11
0x0E,0x11,0x10,0x10,0x10,0x11,0x0E,0x00,//’C’12
0x1C,0x12,0x11,0x11,0x11,0x12,0x1C,0x00,//’D’13
0x1F,0x10,0x10,0x1E,0x10,0x10,0x1F,0x00,//’E’ 14
0x1F,0x10,0x10,0x1E,0x10,0x10,0x10,0x00,//’F’ 15
0x0E,0x11,0x10,0x17,0x11,0x11,0x0F,0x00,//’G’ 16
0x11,0x11,0x11,0x1F,0x11,0x11,0x11,0x00,//’H’ 17
0x0E,0x04,0x04,0x04,0x04,0x04,0x0E,0x00,//’I’ 18
0x07,0x02,0x02,0x02,0x02,0x12,0x0C,0x00,//’J’ 19
0x11,0x12,0x14,0x18,0x14,0x12,0x11,0x00,//’K’ 20
0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0x00,//’L’ 21
0x11,0x1B,0x15,0x15,0x11,0x11,0x11,0x00,//’M’ 22
0x11,0x11,0x19,0x15,0x13,0x11,0x11,0x00,//’N’ 23
0x0E,0x11,0x11,0x11,0x11,0x11,0x0E,0x00,//’O’ 24
0x1E,0x11,0x11,0x1E,0x10,0x10,0x10,0x00,//’P’ 25
0x0E,0x11,0x11,0x11,0x15,0x12,0x0D,0x00,//’Q’ 26
0x1E,0x11,0x11,0x1E,0x14,0x12,0x11,0x00,//’R’ 27
0x0F,0x10,0x10,0x0E,0x01,0x01,0x1E,0x00,//’S’ 28
0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//’T’ 29
0x11,0x11,0x11,0x11,0x11,0x11,0x0E,0x00,//’U’ 30
0x11,0x11,0x11,0x11,0x11,0x0A,0x04,0x00,//’V’ 31
0x11,0x11,0x11,0x15,0x15,0x15,0x0E,0x00,//’W’ 32
0x11,0x11,0x0A,0x04,0x0A,0x11,0x11,0x00,//’X’ 33
0x11,0x11,0x11,0x0A,0x04,0x04,0x04,0x00,//’Y’ 34
0x1F,0x01,0x02,0x04,0x08,0x10,0x1F,0x00,//’Z’ 35
0x00,0x00,0x0E,0x01,0x0F,0x11,0x0F,0x00,//’a’ 36
0x10,0x10,0x16,0x19,0x11,0x11,0x1E,0x00,//’b’ 37
0x00,0x00,0x0E,0x10,0x10,0x11,0x0E,0x00,//’c’ 38
0x01,0x01,0x0D,0x13,0x11,0x11,0x0F,0x00,//’d’ 39
0x00,0x00,0x0E,0x11,0x1F,0x10,0x0E,0x00,//’e’ 40
0x00,0x06,0x09,0x08,0x1C,0x08,0x08,0x00,//’f’ 41
0x10,0x10,0x16,0x19,0x11,0x11,0x11,0x00,//’h’ 42
0x04,0x00,0x0C,0x04,0x04,0x04,0x0E,0x00,//’i’ 43
0x02,0x00,0x06,0x02,0x02,0x12,0x0C,0x00,//’j’ 44
0x08,0x08,0x09,0x0A,0x0C,0x0A,0x09,0x00,//’k’ 45
0x0C,0x04,0x04,0x04,0x04,0x04,0x0E,0x00,//’l’ 46
0x00,0x00,0x1E,0x15,0x15,0x11,0x11,0x00,//’m’ 47
0x00,0x00,0x16,0x19,0x11,0x11,0x11,0x00,//’n’ 48
0x00,0x00,0x0E,0x11,0x11,0x11,0x0E,0x00,//’o’ 49
0x00,0x00,0x1E,0x11,0x1E,0x10,0x10,0x00,//’p’ 50
0x00,0x00,0x0D,0x13,0x0F,0x01,0x01,0x00,//’q ’ 51
0x00,0x00,0x16,0x19,0x10,0x10,0x10,0x00,//’r’ 52
0x00,0x00,0x0E,0x10,0x0E,0x01,0x0E,0x00,//’s’ 53
0x00,0x08,0x08,0x1C,0x08,0x09,0x06,0x00,//’t ’ 54
0x00,0x00,0x11,0x11,0x11,0x13,0x0D,0x00,//’u’ 55
0x00,0x00,0x11,0x11,0x11,0x0A,0x04,0x00,//’v’ 56
0x00,0x00,0x11,0x11,0x15,0x15,0x0A,0x00,//’w’ 57
0x00,0x00,0x11,0x0A,0x04,0x0A,0x11,0x00,//’x’ 58
0x00,0x00,0x11,0x11,0x0F,0x01,0x0E,0x00,//’y’ 59
0x00,0x00,0x1F,0x02,0x04,0x08,0x1F,0x00,//’z’ 60
页:
[1]
