pxy94 发表于 2010-10-9 17:55
WinCE6.0编译时出现以下错误
WinCE6.0编译时出现以下错误,它说CloseGestureInfoHandle,GetGestureInfo等函数没有定义,我查到这几个函数都在TileWindow.cpp这个文件里面,路径为D:\WINCE600\PUBLIC\IE\OAK\IESAMPLE_EXR\CORE,但这个文件是它自带的,怎么会出现没定义的情况呢,真是搞不明白,有知道的大虾指点一下。
commctrl.lib(prsht.obj) : error LNK2019: unresolved external symbol CloseGestureInfoHandle referenced in function "int __cdecl PropSheetDlgProc(struct HWND__ *,unsigned int,unsigned int,long)" (?PropSheetDlgProc@@YAHPAUHWND__@@IIJ@Z)
commctrl.lib(tab.obj) : error LNK2001: unresolved external symbol CloseGestureInfoHandle
commctrl.lib(tab.obj) : error LNK2019: unresolved external symbol GetGestureInfo referenced in function Tab_WndProc
commctrl_hpc.lib(lvlogic.obj) : error LNK2019: unresolved external symbol SetWindowAutoGesture referenced in function "void __cdecl ListView_UpdateAutoGestures(struct _LV *)" (?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z)
commctrl_hpc.lib(treeview_hpc.obj) : error LNK2001: unresolved external symbol SetWindowAutoGesture
commctrl_hpc.lib(lvlogic.obj) : error LNK2019: unresolved external symbol GetWindowAutoGesture referenced in function "void __cdecl ListView_UpdateAutoGestures(struct _LV *)" (?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z)
commctrl_hpc.lib(treeview_hpc.obj) : error LNK2019: unresolved external symbol GetAnimateMessageInfo referenced in function "int __cdecl TV_PlatformPreproc(struct HWND__ *,unsigned int,unsigned int,long,struct _TREE *)" (?TV_PlatformPreproc@@YAHPAUHWND__@@IIJPAU_TREE@@@Z)
commctrl.lib(lvgesture.obj) : error LNK2001: unresolved external symbol GetAnimateMessageInfo
commctrl.lib(lvgesture.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl TouchPerf::ReleaseSession(void)" (?ReleaseSession@TouchPerf@@SAXXZ) referenced in function "public: __cdecl GestureTriggeredScrollCtrl::~GestureTriggeredScrollCtrl(void)" (??1GestureTriggeredScrollCtrl@@QAA@XZ)
commctrl.lib(lvgesture.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl TouchPerf::AcquireSession(void)" (?AcquireSession@TouchPerf@@SAXXZ) referenced in function "public: __cdecl GestureTriggeredScrollCtrl::GestureTriggeredScrollCtrl(void)" (??0GestureTriggeredScrollCtrl@@QAA@XZ)
E:\PanXiaoya\eSOM9261CDROM\WINCE6.0\Project\OSDesignsAT91\EEIC08Full\Wince600\EEIC08_ARMV4I\cesysgen\oak\target\ARMV4I\retail\commctrl.dll : fatal error LNK1120: 7 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
NMAKE : fatal error U1077: 'D:\WINCE600\sdk\bin\i386\nmake.exe' : return code '0x2'
Stop.
gooogleman 发表于 2010-10-15 12:35
有可能是安装不好,
build and sysgen 一遍。
pxy94 发表于 2010-10-18 17:23
有可能是安装不好,
gooogleman 发表于 2010-10-15 12:35 https://bbs.21ic.com/images/common/back.gif
多谢,确实是这个原因,补丁顺序搞错了
页: [1]
查看完整版本: WinCE6.0编译时出现以下错误
