FCCdsp 发表于 2017-10-14 11:36
一个DSP TMS320 F28035的串口驱动程序
[*]    标题:MySci.h
[*]    软件平台:DSP.com/forum.php?mod=forumdisplay&fid=58" target="_blank" class="relatedlink">CCS v5.2
[*]    硬件平台:TMS320F28035coreboard
[*]    主频:60M
[*]    author:小船
[*]    data:2013-01-22
[*]#ifndef MySci_H_
[*]#define MySci_H_
[*]#include "PeripheralHeaderIncludes.h"
[*]#include <stdbool.h>
[*]#define RECEIVER_BUFF_SIZE 50
[*]struct Sci_send_data{
[*]char *AddPtr;
[*]char length;
[*]extern char receiver_counter;
[*]extern struct Sci_send_data data;
[*]extern char receiver_data_buff;
[*]void MySci_init();
[*]bool MySci_send(char *Ptr,char length);
[*]#endif /* MySci_H_ */
[*]    标题:MySci.c
[*]    软件平台:CCS v5.2
[*]    主频:60M
[*]       描述:串口通信,波特率38400,自动中断发送,不必多余的等待
[*]注意:如果用fifo,就不用判断SciaRegs.SCIRXST.bit.RXRDY,此位不会生效
[*]      基于2803x C/C++ Header Files V1.21
[*]    author:小船
[*]    data:2013-01-22
[*]#include"MySci.h"
[*]struct Sci_send_data data;
[*]char receiver_data_buff;
[*]char receiver_counter = 0;
[*]interrupt void rece_isr();
[*]interrupt void tx_isr();
[*]/*配置GPIO*/
[*]    EALLOW;
[*]    GpioCtrlRegs.GPAPUD.bit.GPIO28 = 0;
[*]    GpioCtrlRegs.GPAPUD.bit.GPIO29 = 0;
[*]    GpioCtrlRegs.GPAQSEL2.bit.GPIO28 = 3;
[*]    GpioCtrlRegs.GPAMUX2.bit.GPIO28 = 1;
[*]    GpioCtrlRegs.GPAMUX2.bit.GPIO29 = 1;
[*]    EDIS;
[*]/*配置fifo*/
[*]    SciaRegs.SCIFFTX.all=0xC060;
[*]    SciaRegs.SCIFFRX.all=0x0021;//fifo接收到一个字节就中断
[*]    SciaRegs.SCIFFCT.all=0x0;
[*]/*配置sci*/
[*]    SciaRegs.SCICCR.all = 0x0007;
[*]    SciaRegs.SCICTL1.all = 0x0063;
[*]    //SciaRegs.SCICTL2.bit.TXINTENA = 1;
[*]    SciaRegs.SCICTL2.bit.RXBKINTENA = 1;
[*]    SciaRegs.SCIHBAUD    = 0x0000;// 38400 baud @LSPCLK = 15MHz (60 MHz SYSCLK).
[*]    SciaRegs.SCILBAUD    = 0x0030;
[*]    SciaRegs.SCIFFTX.bit.TXFIFOXRESET=1;
[*]    SciaRegs.SCIFFRX.bit.RXFIFORESET=1;
[*]    /*配置中断*/
[*]    EALLOW;
[*]    PieVectTable.SCITXINTA = &tx_isr; //注册中断向量表
[*]    PieVectTable.SCIRXINTA = &rece_isr;
[*]    PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   //使能PIE
[*]    PieCtrlRegs.PIEIER9.bit.INTx1=1;   //使能int9.1
[*]    PieCtrlRegs.PIEIER9.bit.INTx2=1;   //使能int9.2
[*]    IER |= (1<<8);//使能int9
[*]    EINT;
[*]    EDIS;
[*]    data.length=0;
[*]    data.AddPtr=0;
[*]if(SciaRegs.SCIFFTX.bit.TXFFIENA==1)
[*]return false;
[*]else
[*]data.AddPtr = Ptr;
[*]data.length = length;
[*]SciaRegs.SCIFFTX.bit.TXFFIENA=1;
[*]return true;
[*]if( data.length)
[*]SciaRegs.SCITXBUF = *data.AddPtr++;
[*]data.length--;
[*]else
[*]SciaRegs.SCIFFTX.bit.TXFFIENA=0;
[*]SciaRegs.SCIFFTX.bit.TXFFINTCLR=1;
[*]PieCtrlRegs.PIEACK.all |= PIEACK_GROUP9;
[*]if(SciaRegs.SCIRXST.bit.RXERROR)
[*]while(1);
[*]if( receiver_counter != RECEIVER_BUFF_SIZE)
[*]receiver_data_buff = SciaRegs.SCIRXBUF.bit.RXDT;
[*]SciaRegs.SCIFFRX.bit.RXFFOVRCLR=1;   // Clear Overflow flag
[*]SciaRegs.SCIFFRX.bit.RXFFINTCLR=1;   // Clear Interrupt flag
复制代码
页: [1]
查看完整版本: 一个DSP TMS320 F28035的串口驱动程序
