roc2two 发表于 2019-11-2 14:46
【零知ESP8266教程】快速入门19 使用NTP服务器获取网络时间
上次的分享,我们获取了一枚天气信息,但是呢,信息最重要的属性之一就是时效性,如何去确认我们信息的时效性呢,简单,保持自己时间的准确喽。Time is valuable thing!时间对我们是很重要的。通常,我们需要进行时间校准(PS:在很多时候,你细心留意就发现时间是错误的),一般就可以用NTP服务器进行获取时间信息,下面使用零知-ESP8266上进行NTP时间的获取。一、硬件
电脑,windows系统
零知ESP8266开发板
micro-usb线
二、
(1)打开零知开源开发软件,选择零知ESP8266开发板,界面如图所示:(2)电脑连接零知ESP8266开发板(3)烧写程序:
①可以直接选择软件中的示例程序
②也可以上传以下代码:/*
* TimeNTP_ESP8266WiFi.ino
* Example showing time sync to NTP time source
* This sketch uses the ESP8266WiFi library
#include <TimeLib.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
const char ssid[] = "xx";//your network SSID (name)
const char pass[] = "xx";       // your network password
// NTP Servers:
static const char ntpServerName[] = "cn.ntp.org.cn";
//static const char ntpServerName[] = "time.nist.gov";
//static const char ntpServerName[] = "time-a.timefreq.bldrdoc.gov";
//static const char ntpServerName[] = "time-b.timefreq.bldrdoc.gov";
//static const char ntpServerName[] = "time-c.timefreq.bldrdoc.gov";
const int timeZone = 8; //BeiJing in China
// const int timeZone = 1;   // Central European Time
//const int timeZone = -5;// Eastern Standard Time (USA)
//const int timeZone = -4;// Eastern Daylight Time (USA)
//const int timeZone = -8;// Pacific Standard Time (USA)
//const int timeZone = -7;// Pacific Daylight Time (USA)
WiFiUDP Udp;
unsigned int localPort = 8888;// local port to listen for UDP packets
time_t getNtpTime();
void digitalClockDisplay();
void printDigits(int digits);
void sendNTPpacket(IPAddress &address);
void setup()
Serial.begin(9600);
while (!Serial) ; // Needed for Leonardo only
delay(250);
Serial.println("TimeNTP Example");
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
Serial.print("IP number assigned by DHCP is ");
Serial.println(WiFi.localIP());
Serial.println("Starting UDP");
Udp.begin(localPort);
Serial.print("Local port: ");
Serial.println(Udp.localPort());
Serial.println("waiting for sync");
setSyncProvider(getNtpTime);
setSyncInterval(300);
time_t prevDisplay = 0; // when the digital clock was displayed
void loop()
if (timeStatus() != timeNotSet) {
    if (now() != prevDisplay) { //update the display only if time has changed
      prevDisplay = now();
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(".");
Serial.print(month());
Serial.print(".");
Serial.print(year());
Serial.println();
// utility for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if (digits < 10)
    Serial.print('0');
Serial.print(digits);
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
IPAddress ntpServerIP; // NTP server's ip address
while (Udp.parsePacket() > 0) ; // discard any previously received packets
Serial.println("Transmit NTP Request");
// get a random server from the pool
WiFi.hostByName(ntpServerName, ntpServerIP);
Serial.print(ntpServerName);
Serial.print(": ");
Serial.println(ntpServerIP);
sendNTPpacket(ntpServerIP);
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
    int size = Udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      Udp.read(packetBuffer, NTP_PACKET_SIZE);// read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =(unsigned long)packetBuffer << 24;
      secsSince1900 |= (unsigned long)packetBuffer << 16;
      secsSince1900 |= (unsigned long)packetBuffer << 8;
      secsSince1900 |= (unsigned long)packetBuffer;
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
Serial.println("No NTP Response :-(");
return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer = 0b11100011;   // LI, Version, Mode
packetBuffer = 0;   // Stratum, or type of clock
packetBuffer = 6;   // Polling Interval
packetBuffer = 0xEC;// Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer = 49;
packetBuffer = 0x4E;
packetBuffer = 49;
packetBuffer = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
}然后验证,并且上传到开发板。四、结果然后对照自己的时间:赶紧动手检查看看自己的时间对不对呢?
我先校准自己的。顺便问你们一句:有没有发现自己的时间变快了呢?(细思极恐)
页: [1]
查看完整版本: 【零知ESP8266教程】快速入门19 使用NTP服务器获取网络时间
