jing880311 发表于 2019-12-20 17:01
关于多个定时器同时使用
现在是用了两个定时器
TIM5用来发脉冲
TIM3是1ms的定时,每隔1ms去修改TIM5的ARR值,感觉设置的都正确,但是实际测试发的脉冲个数不对,请问是什么原因呢?
TIM3的初始化
void MX_TIM3_Init(void)   // 1ms
    TIM_ClockConfigTypeDef sClockSourceConfig;
    TIM_MasterConfigTypeDef sMasterConfig;
    htim3.Instance = TIM3;
    htim3.Init.Prescaler = 0;
    htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
    htim3.Init.Period = 83999;
    htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
    if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
      Error_Handler();
    sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
    if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
      Error_Handler();
    sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
    sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
    if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
      Error_Handler();
    __HAL_TIM_ENABLE(&htim3);
}TIM5的初始化/*84M*/
void MX_TIM5_Init(void)
htim5.Instance = TIM5;
htim5.Init.Prescaler = 0;
htim5.Init.CounterMode = TIM_COUNTERMODE_UP;
htim5.Init.Period = Tim5_CCR/init_speed-1;
htim5.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
if (HAL_TIM_Base_Init(&htim5) != HAL_OK)
    Error_Handler();
if (HAL_TIM_ConfigClockSource(&htim5, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
if (HAL_TIMEx_MasterConfigSynchronization(&htim5, &sMasterConfig) != HAL_OK)
    Error_Handler();
__HAL_TIM_ENABLE(&htim5);
      TIM5 ->CR1 |= 0x0080;
}TIM3中断函数
void TIM3_IRQHandler(void)
    CPU_IntDis();   //CPU_CRITICAL_ENTER;
    OSIntEnter();
    HAL_TIM_IRQHandler(&htim3);
                TIM3->ARR = 83999;
                        if(speed_up1==1)
                              if(vx1<speed_max)
                                        vx1 += (float)slope_val/1000;
                                        if(vx1>speed_max)
                                                      vx1 = speed_max;
                                                      speed_up1 = 0;
                                        timer5ARR = Tim5_CCR/vx1;
                        if(speed_down1==1)
                              if(vx1>cutoff_speed)
                                        vx1 -= (float)slope_val/1000;
                                        if(vx1<=cutoff_speed)
                                                vx1 = cutoff_speed;
                                                speed_down1 = 0;
                                                MOTOR_mov_flag = 0;
    CPU_IntEn();
    OSIntExit();
}TIM5中断函数void TIM5_IRQHandler(void)
    OSIntEnter();
    HAL_TIM_IRQHandler(&htim5);
                TIM5->ARR = timer5ARR;
                HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_1);
                turns_pulse_nums++;
                if(MOTOR_mov_flag)
                        if(turns_pulse_nums>=distance_R*8)
                              MOTOR_mov_over = 1;
                              speed_down1 = 1;
                              MOTOR_mov_flag = 0;
    CPU_IntEn();
    OSIntExit();
}后来改成TIM3定时0.1ms,有改善,这样的到底要怎么处理呢?
airwill 发表于 2019-12-22 18:24
看情况是异步性问题吧
看情况是异步性问题吧
不太理解,能具体说一下吗?还有这个可以解决吗?
jing880311 发表于 2020-1-2 15:39
不知道怎么结贴,是我的定时器设置不对,越界了,
页: [1]
查看完整版本: 关于多个定时器同时使用
