PC软件小工具开发:USB转CAN通信软件
本帖最后由 nicholasldf 于 2020-2-18 17:09 编辑需求: 开发一个PC软件小工具,,用于控制USB转CAN工具,完成与电路板单片机的CAN协议通信。
主要功能比较简单,有以下几项:
客户信息设置和下载;
客户配置设置和下载;
传感器设置和下载;
单片机固件升级功能;
特殊需求:要求深圳本地合作方,以便上门调试,,我们公司在西丽大学城地铁站附近。
QQ:379673688
PC tools requirement
1. PC tools design GUI to setfollowing:A. Customer configuration.B. PGNsC. Customer info.D. Sensor configuration.
2. PC tools create a config scriptthat able to download of configuration.
3. PC tools with USB2CAN that ableto load the following:A. Customer configuration.B. PGNs.C. Customer info.D. Sensor configuration.
Example:J1939_PGN_CustomerConfigLoading
PGN(hex)PriorityData
01234567
FF076
This is to setthe PGN info for sensors and diagnostic. Byte 0:Customer PGN (temperature), default FF (means not used). This is only one byte.Byte 1:Customer PGN (Switch), default FF (means not used). This is only one byte.Byte 2:Customer PGN (Diagnostic), default FF (means not used). This is only one byte.Byte 3:Customer PGN (Pressure Port0), default FF (means not used). Byte 4:Customer PGN (Pressure Port1)Byte 5:Customer PGN (Pressure Port2)Byte 6:Customer PGN (Pressure Port2)If this PGN isnot called, the messages will be broadcast based on the default PGN.
Example:J1939_PGN_SensorConfigLoadingItems totransfer- PortID(0,1,2,3)- PortType(0=Pressure, 1=Temperature, 2=Switch)- SensorCharacteristic(0=normal, 1=ratio/metric)- SensorTable(20values)
- Voltage- Sensor map value
- 1.2567- 25.00
- 1.5678- 28.65
- 1.7564- 29.32
- 2.0000- 30.01
SensorConfig
01234567
FF086PortIDPortTypeSCharacter
SensorTable
01234567
FF096PortIDTableRowVoltageMap value
4. PC tools with USB2CAN that ableto Firmware upgrade. Reference <Client_FW_Update_Protocol.pdf>.
QQ:379673688 联系我 qq 2424623056 nicholasldf 发表于 2020-2-26 17:04
QQ:379673688 ...
打电话聊,15889507053
曾经在白芒村住了1年,艰苦的生活。
页:
[1]
