[项目外包] PC软件小工具开发:USB转CAN通信软件
1505|3
 楼主| nicholasldf 发表于 2020-2-18 17:08 | 显示全部楼层 |阅读模式
价格:20000 元
需求: 开发一个PC软件小工具,,用于控制USB转CAN工具,完成与电路板单片机的CAN协议通信。
主要功能比较简单,有以下几项:
客户信息设置和下载;
客户配置设置和下载;
传感器设置和下载;
单片机固件升级功能;
特殊需求:要求深圳本地合作方,以便上门调试,,我们公司在西丽大学城地铁站附近。
QQ:379673688
PC tools requirement
1.      PC tools design GUI to setfollowing:
A.     Customer configuration.
B.     PGNs
C.     Customer info.
D.     Sensor configuration.
2.      PC tools create a config scriptthat able to download of configuration.
3.      PC tools with USB2CAN that ableto load the following:
B.     PGNs.
C.     Customer info.
Example:  J1939_PGN_CustomerConfigLoading
PGN(hex)
Priority
Data
FF07
This is to setthe PGN info for sensors and diagnostic.
Byte 0:Customer PGN (temperature), default FF (means not used). This is only one byte.
Byte 1:Customer PGN (Switch), default FF (means not used). This is only one byte.
Byte 2:Customer PGN (Diagnostic), default FF (means not used). This is only one byte.
Byte 3:Customer PGN (Pressure Port0), default FF (means not used).
Byte 4:Customer PGN (Pressure Port1)
Byte 5:Customer PGN (Pressure Port2)
Byte 6:Customer PGN (Pressure Port2)
If this PGN isnot called, the messages will be broadcast based on the default PGN.
Example:  J1939_PGN_SensorConfigLoading
Items totransfer
-         PortID(0,1,2,3)
-         PortType(0=Pressure, 1=Temperature, 2=Switch)
-         SensorCharacteristic(0=normal, 1=ratio/metric)
-         SensorTable(20values)
-             Voltage
-             Sensor map value
-             1.2567
-             25.00
-             1.5678
-             28.65
-             1.7564
-             29.32
-             2.0000
-             30.01
SensorConfig
PGN(hex)
Priority
Data
FF08
PortID
PortType
SCharacter
SensorTable
PGN(hex)
Priority
Data
FF09
PortID
TableRow
Voltage
Map value
4.      PC tools with USB2CAN that ableto Firmware upgrade.
Reference <Client_FW_Update_Protocol.pdf>.
 楼主| nicholasldf 发表于 2020-2-26 17:04 | 显示全部楼层
QQ:379673688
科胜电子 发表于 2020-3-11 16:23 | 显示全部楼层
联系我 qq 2424623056
xxyyzz123 发表于 2020-3-11 21:14 | 显示全部楼层
QQ:379673688 ...
打电话聊,15889507053
曾经在白芒村住了1年,艰苦的生活。
