【MM32 eMiniBoard测评报告】+ 4、串口发送
今晚搞了一下串口1发送:原理图:
代码:
void UartInit_Loop(void)
//GPIO¶Ë¿ÚÉèÖÃ
UART_InitTypeDef UART_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_UART1, ENABLE); //ʹÄÜUART1
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);//¿ªÆôGPIOAʱÖÓ
//UART1 NVIC ÅäÖÃ
//UART ³õʼ»¯ÉèÖÃ
GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
UART_InitStructure.UART_BaudRate = 115200;//´®¿Ú²¨ÌØÂÊ
UART_InitStructure.UART_WordLength = UART_WordLength_8b;//×Ö³¤Îª8λÊý¾Ý¸ñʽ
UART_InitStructure.UART_StopBits = UART_StopBits_1;//Ò»¸öֹͣλ
UART_InitStructure.UART_Parity = UART_Parity_No;//ÎÞÆæÅ¼Ð£Ñéλ
UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;//ÎÞÓ²¼þÊý¾ÝÁ÷¿ØÖÆ
UART_InitStructure.UART_Mode = UART_Mode_Rx | UART_Mode_Tx; //ÊÕ·¢Ä£Ê½
UART_Init(UART1, &UART_InitStructure); //³õʼ»¯´®¿Ú1
UART_Cmd(UART1, ENABLE); //ʹÄÜ´®¿Ú1
//UART1_TX GPIOA.9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //¸´ÓÃÍÆÍìÊä³ö
GPIO_Init(GPIOA, &GPIO_InitStructure);//³õʼ»¯GPIOA.9
//UART1_RX GPIOA.10³õʼ»¯
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//¸¡¿ÕÊäÈë
GPIO_Init(GPIOA, &GPIO_InitStructure);//³õʼ»¯GPIOA.10
printf("UART OK!\r\n");
void uart_send(UART_TypeDef* UARTx,char c)
UART_SendData(UARTx,(uint16_t)c);
while(1)
if(UART_GetITStatus(UARTx, UART_IT_TXIEN))
UART_ClearITPendingBit(UARTx, UART_IT_TXIEN);
break;
int main(void)
long int i;
LED_Init(); //³õʼ»¯ÓëLEDÁ¬½ÓµÄÓ²¼þ½Ó¿Ú
UartInit_Loop();//UART1µÄ·¢ËÍ£¬¿ÉÒÔͨ¹ý´®¿ÚÈí¼þ´òÓ¡UART OK
while(1) //ÎÞÏÞÑ»·
//Uart2RxTest(UART2);//UART1µÄ½ÓÊÕ£¬ÔÚ´®¿ÚÈí¼þÖÐÊäÈë×Ö·û£¬¿ÉÒÔͨ¹ý´òÓ¡ÑéÖ¤½ÓÊÕµÄÊý¾ÝÊÇ·ñÕýÈ·
uart_send(UART1,0x55);
for(i=0;i<1300000;i++);
效果图:
工程:
你试试我那个串口助手,可以接收数据自动插入换行
谢谢!我试试 KEIL把编码调一下,再复制发到论坛就不会乱码啦{:mad:} 试了用寄存器直接操作,也是这样,估计就是这样的吧。哎,好奇特。 官方寄存器的例子也是这样的。好神奇,还有官方库函数的例子寄存器名字也弄错了。串口例子的官方库函数版本中uart.c文件内CSR寄存器成员写成了ISR成员,虽然宏是一样的,但是没法说啊,应该是第一版,有BUG在所难免,希望后面更新后,能把这些错误更正了,顺便检查一下串口到底是什么问题,是硬件问题还是软件操作流程不科学导致的。
页:
[1]
